Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP fro Eclipse Applications with a View
TPTP fro Eclipse Applications with a View [message #106569] Thu, 26 July 2007 01:25 Go to next message
Originally posted by: vibhoodh_srikar.yahoo.co.in
I am very new to the TPTP...I have a RCP Application with a View..(Tree
Viewer)..I want to run the application and record the events performed on
tree view.. and want to replay it...
How can I do this...Can you please provide the appropriate links for
testing RCP application with a View...Is it possible to check the code
coverage after replaying it...
Please help me in testing my RCP application... with TPTP
Srikar
Re: TPTP fro Eclipse Applications with a View [message #106596 is a reply to message #106569] Thu, 26 July 2007 06:17 Go to previous messageGo to next message
Originally posted by: cl.silistix.com
TPTP AGR doesn't support RCP applications or code coverage.
If your RCP application is based on features you can export and deploy
them into a clean install of the eclipse runtime and use that to test
your features. You will also need to install the features into the
eclipse IDE you will be using to record your test cases.
This should help you:
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html
Good luck,
Craig
Vibhoodh wrote:
> View..(Tree Viewer)..I want to run the application and record the events
> performed on tree view.. and want to replay it...
> Srikar
Re: TPTP fro Eclipse Applications with a View [message #106609 is a reply to message #106569] Thu, 26 July 2007 08:11 Go to previous message
Hi Vibhoodh,
I am assuming you are referring to automated GUI testing using the
Automated GUI Recorder (AGR). The AGR currently does not support
recording and playback of RAP or stand-alone SWT applications. The AGR
currently
supports Eclipse applications, with support for RAP applications in
enhancement:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=114159
Feel free to comment/contribute/monitor this enhancement.
Paul
"Vibhoodh" <vibhoodh_srikar@yahoo.co.in> wrote in message
news:8f394b1f428185d48e01d9adda2c5edf$1@www.eclipse.org...
> Srikar
Previous Topic:Recognizing automated GUI test results in Ant
Next Topic:AGR suites in JUnit
Current Time: Sun Nov 16 00:07:15 EST 2025
Powered by FUDForum. Page generated in 0.03882 seconds
