Crosstable problem after BIRT 4.2 upgrade [message #1065823] |
Thu, 27 June 2013 11:31  |
I upgraded my BIRT lib from 3.7 to 4.2.2 and now my crosstables created with DE API doesnt work. The problem is the measure doesnt get its content property.
I add the measure to the table with the following code snippet:
MeasureViewHandle mvh = xtabHandle.insertMeasure(measure, 0);
This is before the creation of the dimensions (i tried to put it after them with no luck). And i dont do anything else, this was enough in BIRT 3.7 but in 4.2.2 the data and the binding is not created for the measure.
This is the measure of the generated report:
<property name="measures">
<extended-item extensionName="MeasureView" id="29">
<property name="measure">someMeasure3</property>
<property name="detail">
<extended-item extensionName="AggregationCell" id="30">
<property name="aggregationOnRow">some_dimension_03/some_level3</property>
<property name="aggregationOnColumn">other_dimension_03/other_level3</property>
</extended-item>
</property>
<property name="header">
<extended-item extensionName="CrosstabCell" id="31">
<property name="content">
<label id="32">
<property name="style">measureHeader</property>
<text-property name="text">count of measure</text-property>
</label>
</property>
</extended-item>
</property>
</extended-item>
</property>
And no binding is created for the measure at all.
Did anything changed in 4.2.2 which i should be aware of ,or my code was completely wrong in 3.7 also and i just had luck that it worked.
Thanks for the help,
David
Re: Crosstable problem after BIRT 4.2 upgrade [message #1066756 is a reply to message #1065823] |
Thu, 04 July 2013 04:53   |
Hi Michael,
Unfortunately the issue is still there in 4.3. I have downloaded a new Eclipse Kepler (with BIRT of course) and tried this report (from another forum post):
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
<property name="units">in</property>
<method name="beforeFactory"><![CDATA[importPackage( Packages.org.eclipse.birt.report.model.api );
importPackage( Packages.org.eclipse.birt.report.item.crosstab.core.util);
importPackage( Packages.org.eclipse.birt.report.item.crosstab.core.de);
importPackage( Packages.org.eclipse.birt.report.item.crosstab.core);
try{
reportDesignHandle = reportContext.getReportRunnable().designHandle.getDesignHandle();
elementFactory = reportDesignHandle.getElementFactory();
cubeHandle = reportDesignHandle.getCubes().get(0);
xtab = CrosstabExtendedItemFactory.createCrosstabReportItem(reportDesignHandle, cubeHandle, "MyCrosstab" );
reportDesignHandle.getBody().add(xtab);
reportItem = xtab.getReportItem( );
xtabHandle = reportItem;
dimensionX = cubeHandle.getDimension(params["RowDimension"].value);
dimensionY = cubeHandle.getDimension(params["ColumnDimension"].value);
levelX = dimensionX.getDefaultHierarchy().getLevel(0)
levelY = dimensionY.getDefaultHierarchy().getLevel(0)
//Insert X Dimension
dvh = xtabHandle.insertDimension(dimensionX, ICrosstabConstants.ROW_AXIS_TYPE, 0);
levelViewHandle =dvh.insertLevel(levelX, 0);
cellHandle = levelViewHandle.getCell( );
eii = xtabHandle.getModelHandle( );
bindingColumn = StructureFactory.newComputedColumn( eii, levelX.getName( ) );
bindingHandle = eii.addColumnBinding( bindingColumn,false );
bindingColumn.setDataType( levelX.getDataType( ) );
exp = "dimension['" + dimensionX.getName()+"']['"+levelX.getName()+"']";
bindingColumn.setExpression( exp);
dataHandle = elementFactory.newDataItem( levelX.getName( ) );
dataHandle.setResultSetColumn( bindingHandle.getName( ) );
cellHandle.addContent( dataHandle );
//Insert Y Dimension
dvh = xtabHandle.insertDimension(dimensionY, ICrosstabConstants.COLUMN_AXIS_TYPE, 0);
levelViewHandle =dvh.insertLevel(levelY, 0);
bindingColumn = StructureFactory.newComputedColumn( eii, levelY.getName( ) );
bindingColumn.setDataType( levelY.getDataType( ) );
exp = "dimension['" + dimensionY.getName()+"']['"+levelY.getName()+"']";
dataHandle = elementFactory.newDataItem( levelY.getName( ) );
//Measures
measure = cubeHandle.getMeasure(params["Measure"].value);
mvh.getCell().getContents().get(0).setProperty("style", "mydata");
mvh.addHeader( );
labelHandle = elementFactory.newLabel( null );
labelHandle.setText( measure.getName() );
mvh.getHeader( ).addContent( labelHandle );
//Note that styles are imported so they do not need to be applied
}catch(e){
//importPackage( Packages.java.io );
//out = new PrintWriter( new FileWriter( "c:/test7/xtabevents.txt", true ) );
//out.println(e);
//out.close();
]]></method>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<parameters>
<scalar-parameter name="ColumnDimension" id="37">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="paramType">simple</property>
<property name="controlType">list-box</property>
<property name="mustMatch">true</property>
<property name="fixedOrder">true</property>
<property name="distinct">true</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
<list-property name="selectionList">
<structure>
<property name="value">Group</property>
<property name="label">Country</property>
</structure>
<structure>
<property name="value">Group1</property>
<property name="label">Product Line</property>
</structure>
<structure>
<property name="value">Group2</property>
<property name="label">Date</property>
</structure>
</list-property>
</scalar-parameter>
<scalar-parameter name="RowDimension" id="38">
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</scalar-parameter>
<scalar-parameter name="Measure" id="39">
</structure>
<structure>
<property name="value">SALES</property>
<property name="label">Sales</property>
</structure>
<structure>
<property name="value">PROFIT</property>
<property name="label">Profit</property>
</structure>
</list-property>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="7">
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver</property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">COUNTRY</property>
<property name="displayName">COUNTRY</property>
</structure>
<structure>
<property name="columnName">PRODUCTLINE</property>
<property name="displayName">PRODUCTLINE</property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<property name="displayName">ORDERDATE</property>
</structure>
<structure>
<property name="columnName">SALES</property>
<property name="displayName">SALES</property>
</structure>
<structure>
<property name="columnName">PROFIT</property>
<property name="displayName">PROFIT</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTLINE</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SALES</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PROFIT</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">COUNTRY</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">PRODUCTLINE</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">SALES</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">PROFIT</property>
</structure>
</list-property>
<property name="queryText">select c.country, p.productline, o.orderdate, sum(od.priceeach*od.quantityordered) as Sales, sum((od.priceeach-p.buyprice)*od.quantityordered) as Profit
from customers c, products p, orders o, orderdetails od
where o.ordernumber = od.ordernumber
and od.productcode = p.productcode
and o.customernumber = c.customernumber
group by c.country, p.productline, o.orderdate</property>
</oda-data-set>
</data-sets>
<cubes>
<tabular-cube name="Data Cube" id="9">
<property name="dimensions">
<tabular-dimension name="Group" id="14">
<property name="defaultHierarchy">NewTabularHierarchy</property>
<property name="hierarchies">
<tabular-hierarchy name="NewTabularHierarchy" id="15">
<property name="levels">
<tabular-level name="COUNTRY" id="16">
</tabular-level>
</property>
</tabular-hierarchy>
</property>
</tabular-dimension>
<tabular-dimension name="Group1" id="17">
<property name="defaultHierarchy">NewTabularHierarchy1</property>
<tabular-hierarchy name="NewTabularHierarchy1" id="18">
<tabular-level name="PRODUCTLINE" id="19">
</tabular-level>
</property>
</property>
<tabular-dimension name="Group2" id="20">
<property name="isTimeType">true</property>
<property name="defaultHierarchy">NewTabularHierarchy2</property>
<tabular-hierarchy name="NewTabularHierarchy2" id="21">
<tabular-level name="year" id="22">
<property name="dataType">integer</property>
<property name="dateTimeLevelType">year</property>
<list-property name="attributes">
<structure>
<property name="name">DateTime</property>
<property name="dataType">date-time</property>
</structure>
</list-property>
</tabular-level>
<tabular-level name="quarter" id="23">
<property name="dateTimeLevelType">quarter</property>
<structure>
</structure>
</list-property>
</tabular-level>
<tabular-level name="month" id="24">
<property name="dateTimeLevelType">month</property>
<structure>
</structure>
</list-property>
</tabular-level>
</property>
</property>
</property>
<property name="measureGroups">
<tabular-measure-group name="Summary Field" id="10">
<tabular-measure name="SALES" id="11">
<expression name="measureExpression">dataSetRow["SALES"]</expression>
</tabular-measure>
</property>
</tabular-measure-group>
<tabular-measure-group name="Summary Field1" id="12">
<tabular-measure name="PROFIT" id="13">
<expression name="measureExpression">dataSetRow["PROFIT"]</expression>
</tabular-measure>
</property>
</property>
<property name="dataSet">Data Set</property>
</tabular-cube>
</cubes>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
<style name="table-header" id="40">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="41">
</style>
<style name="table-detail" id="42">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="43">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="44">
</style>
<style name="special-header" id="45">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="46">
</style>
<style name="crosstab-header" id="47">
</style>
<style name="mydata" id="48">
<property name="color">#004080</property>
<structure name="numberFormat">
<property name="category">Currency</property>
<property name="pattern">$ #,##0.00</property>
</structure>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.25in</property>
<property name="bottomMargin">0.25in</property>
<property name="rightMargin">0.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
</report>
I had this result in the web viewer ( it was worse in the preview):
https://dl.dropboxusercontent.com/u/54730350/web_viewer.PNG
Is this code outdated? Or is there any workaround for this?
David
FUDForum. Page generated in 0.08319 seconds
