Home » Newcomers » Newcomers » cannot launch test xsl-transformation
cannot launch test xsl-transformation [message #1065804] Thu, 27 June 2013 10:28 Go to next message
hello everyone
i am new to eclipse, and installed the following:
-Eclipse Standard/SDK
-com.orangevolt.eclipse.xslt.feature
Having created to trivial testfiles, such as
-source.xml
-transformer.xsl
After having set the run-configuration and performed the run-command, i got displayed the following errormessage:
"An internal error occurred during: "Launching samples".
String index out of range: -1"
What is missing?
Thanks for every advise.
Sam
Re: cannot launch test xsl-transformation [message #1066027 is a reply to message #1065804] Sat, 29 June 2013 02:31 Go to previous message
You might want to check with orangevolt's author, or at least check your Error Log view for more information.
Previous Topic:I have lost the Menue Iteam Team
Next Topic:what plugin for xsl transformation?
Current Time: Sat Jul 26 20:48:12 EDT 2025
Powered by FUDForum. Page generated in 0.08570 seconds
