Home » Eclipse Projects » Remote Application Platform (RAP) » Clientscripting: Trigger traverse programmatically
Clientscripting: Trigger traverse programmatically [message #1064346] Tue, 18 June 2013 15:59 Go to next message
We do single-sourcing. Our application features extensive validation of user input, for example: Consider a field used to input dates. This field has a maximum lenght of 4 and only digits are allowed. Also, if the input is correct and the maximum number of digits is entered, the focus should be set to the next field.
In RCP this is done using various listeners. As this is very bad for performance (every keystroke would be transfered to the server) we build some generic javascript functions which can validate the given input against a regex. This functions are registered once as a ressource. The code of the clientlistener is just a call of these functiones with the regex as a parameter.
The validation works well, but we do not know how to implement the automatic traverse.
We did not find documentation for the javascript part, so we couldn't check if we can fire a traverse event in javascript.
How could a automatic traverse with clientscripting work?
thanks in advance
Re: Clientscripting: Trigger traverse programmatically [message #1064455 is a reply to message #1064346] Wed, 19 June 2013 07:24 Go to previous messageGo to next message
Hi Stefan,
traversal is not yet supported by the clientscripting, but I think it
should be generally possible. We plan to extend the clientscripting
component in 2.2 and traversal could be a powerful addition for this
component. Feel free to open an enhancement request.
There's a wiki page [1] for the clientscripting, that is also referenced
on the incubator page.
Ralf
[1] http://wiki.eclipse.org/RAP/ClientScripting
Ralf Sternberg
Twitter: @EclipseRAP
Re: Clientscripting: Trigger traverse programmatically [message #1064604 is a reply to message #1064455] Thu, 20 June 2013 04:17 Go to previous messageGo to next message
I know about the clientscripting wiki, but i did mean documentation on the "general" javascript-part. We thought we could trigger the focus-event ourselves using the general javascript-api of the objects.
As Tim wrote on the eclipsesource-blog:
http://eclipsesource.com/blogs/2013/06/07/rap-client-scripting-phase-ii-33/
we could pass the next widget to the widget which features automatic traversal in RCP. All we would have to do is trigger the focus-event on the passed widget as a click would do.
Would this be a possible solution?
[Updated on: Thu, 20 June 2013 04:19] by Moderator
Re: Clientscripting: Trigger traverse programmatically [message #1065086 is a reply to message #1064604] Mon, 24 June 2013 05:48 Go to previous messageGo to next message
Hi.
I think the correct solution would be to implement setFocus or
forceFocus for ClientScripting. Since this seems to be a common use case
I will try to get this done as soon as possible and then post a snippet
in this thread.
Greetings,
Tim
Am 20.06.2013 10:17, schrieb Stefan M:
Tim Buschtöns
Re: Clientscripting: Trigger traverse programmatically [message #1065523 is a reply to message #1065086] Wed, 26 June 2013 06:10 Go to previous messageGo to next message
> in this thread.
Done. Controls now have a "forceFocus" method[1]. The demo application
in org.eclipse.rap.clientscripting.demo bundle has been updated. Example:
Java:
WidgetDataWhiteList.addKey( "next" );
text.setData( "next", WidgetUtil.getId( next ) );
text.addListener( SWT.XXX, clientListener );
JavaScript:
rap.getObject( event.widget.getData( "next" ) ).forceFocus();
[1]
http://wiki.eclipse.org/RAP/Incubator/ClientScripting#Methods_on_Controls
> Greetings,
> Tim
Tim Buschtöns
Re: Clientscripting: Trigger traverse programmatically [message #1067608 is a reply to message #1065523] Tue, 09 July 2013 10:47 Go to previous message
Thank you for your quick reaction.
I implemented the solution now in our application, it works fine.
Stefan
Previous Topic:Migrating to RAP 2.1-RC3: Extending behaviour of DateTime widget
Next Topic:Has ScrollBar different behaviour in SWT and RWT?
Current Time: Wed Jul 23 15:33:46 EDT 2025
Powered by FUDForum. Page generated in 0.04119 seconds
