Home » Modeling » Epsilon » [ETL] Generated model can't be read or modified(Cross-references between models seem invalid in the editor)
[ETL] Generated model can't be read or modified [message #1065509] Wed, 26 June 2013 04:54 Go to next message
I am currently experimenting with epsilon, so excuse me if this is a noob question...
I have a toy project in which I have two meta-models called MMA and MMB.
MMB is designed to provide additionnal data to MMA without subclassing existing concepts (for performance reasons we want to avoid copying the input model).
The basic approach is to have concept B from MMB thats relate to a concept A from MMA by a "ref" property. I've created an ETL module that creates B instances to wrap every A instances.
Now the problem is: when I open the generated model file (with either exeed or emf editor), the cross-reference is empty. When I open the file as text, the cross-reference is here (it seems valid XMI) but the editor fails to show it or even modify it...
I've been strugling on that for a couple of days, I can find workarounds to not have this design but no real solution to the problem... Am I doing anything wrong in the meta-model definition or in the rules?
I attached the zip containing a simplified minimal version of my problem. ma.xmi is the source model and mb is the generated one.
Thanks in advance
[EDIT] My eclipse version is Eclipse modelling "Juno Service Release 2". In fact is the one downloaded from the epsilon website.
  • Attachment: tests.zip
    (Size: 3.10KB, Downloaded 138 times)
[Updated on: Wed, 26 June 2013 04:57] by Moderator
Re: [ETL] Generated model can't be read or modified [message #1065515 is a reply to message #1065509] Wed, 26 June 2013 05:14 Go to previous messageGo to next message
Hi Gaëtan,
I'm afraid I can't reproduce this. If I register mma.ecore and mmb.ecore and then open mb.xmi using Exeed, references to ma.xmi seem to be working fine.
Dimitris
Re: [ETL] Generated model can't be read or modified [message #1065517 is a reply to message #1065515] Wed, 26 June 2013 05:45 Go to previous messageGo to next message
Ok, I started with a fresh new eclipse app (just restarted in the same workspace) and it worked...
Then:
a) I tried my original project (not the simplified one I sent) => it worked.
b) I registered the EPackeges of my original problem (I realized I had forgotten to do it) => The error reappeared.
Then I restarted the eclipse again, went through the same process and everything went ok. I could not reproduce the problem.
Looking at error log view, I get some message "Unhandled event loop exception" from "plugin org.eclipse.ui" when the problem occurs.
Conclusion:
It seems to be some kind of weird instability inside my eclipse, not related to epsilon...
I'll see how it behaves in the next few days.
Thanks for the quick reply.
Re: [ETL] Generated model can't be read or modified [message #1065518 is a reply to message #1065517] Wed, 26 June 2013 05:56 Go to previous messageGo to next message
BTW, this investigations raised 2 questions regarding epsilon:
- About the "Register EPackages":
Does it keep ecore files inside my workspace project registered after a reboot?
Do I need to re-register after a change in the model (it looks like not but just to be sure)?
Can I un-register an EPackage? How?
- About XMI serialization:
I see that Epsilon serialization relies heavily on XPath elements referencing (instead of xmi:id). While this is perfectly valid, it seems to be discouraged (see link below, point 7):
<kttp://>java.dzone.com/articles/10-common-emf-mistakes
I'm no EMF expert so I don't know what's the best thing to do, certainly having Ids everywhere will pollute the model (especially when using HUTN).
But in the cases where it would be usefull, is there any way to force Epsilon using Ids when saving a model?
Best regards
Re: [ETL] Generated model can't be read or modified [message #1065528 is a reply to message #1065518] Wed, 26 June 2013 07:16 Go to previous messageGo to next message
Hi Gaëtan,
Please see comments below.
Yes
No
Yes. You can do this through Preferences->Epsilon->EMF Registry (you may need to restart your Eclipse after removing an Ecore model from the list)
It really depends on the use case.
Yes. If the name of your model in the launch configuration is X, the following line should do the trick
X.resource.useXmiIds = true;
Dimitris
Re: [ETL] Generated model can't be read or modified [message #1065538 is a reply to message #1065528] Wed, 26 June 2013 08:10 Go to previous message
Thanks a lot dimitris!
BR,
Gaëtan
Previous Topic:[ETL] Specify metamodels in transformation for content assist/validation
Next Topic:How do I add derived (cached) EOL operations to my EMF model?
Current Time: Sun Jul 27 09:40:38 EDT 2025
Powered by FUDForum. Page generated in 0.04501 seconds
