Home » Modeling » ATL » cannot transform all suppliers in dependency
cannot transform all suppliers in dependency [message #1065401] Tue, 25 June 2013 10:57 Go to next message
I used this rule for dependency and the thing is that for some dependencies in the created output model, it transforms both clients and suppliers and for some, it only transforms clients. When I check with the debug, it shows the suppliers are not empty. Can any one guess what is wrong here?
has Stereotype is a helper which is defined before as follow:
helper context MM!Element def: hasStereotype(name : String) : Boolean =
not self.getAppliedStereotype(name).oclIsUndefined();
rule RelatedTo {
from s:MM!Dependency (s.hasStereotype('MyProfile::RelatedTo'))
to t: MM2!Dependency (
name <- s.name -> debug ('name'),
client <- s.client -> debug ('client'),
supplier <- s.supplier -> debug ('supplier')
tt: MM2! RelatedTo (base_Dependency <- t)
Re: cannot transform all suppliers in dependency [message #1065409 is a reply to message #1065401] Tue, 25 June 2013 11:29 Go to previous messageGo to next message
What do you mean by "transforming clients and customers"?
Are the "client" and "supplier" only String attributes or rather references to other elements?
In the second case, if they are not transformed this probably means that you have currently no rule matching them in your transformation.
Re: cannot transform all suppliers in dependency [message #1065422 is a reply to message #1065409] Tue, 25 June 2013 12:07 Go to previous messageGo to next message
Each dependency has two properties which shows the client elements and the suppliers.
Re: cannot transform all suppliers in dependency [message #1065432 is a reply to message #1065422] Tue, 25 June 2013 12:35 Go to previous messageGo to next message
Well, thus it depends of the type of elements "client" and "supplier".
You should double-check the rules that are creating them and ensure that they are correct.
Re: cannot transform all suppliers in dependency [message #1065434 is a reply to message #1065432] Tue, 25 June 2013 12:43 Go to previous messageGo to next message
Thank you very much for your reply.
How should be the general form for transforming a dependency? I behaved clients and suppliers as the properties in the class when I want to transform them.
Thanks again
Re: cannot transform all suppliers in dependency [message #1065508 is a reply to message #1065434] Wed, 26 June 2013 04:45 Go to previous messageGo to next message
There is no "general" way of developing a transformation, this depends on the source and target metamodels you are using as well as on the actual mapping you want to implement between them.
Re: cannot transform all suppliers in dependency [message #1067472 is a reply to message #1065508] Mon, 08 July 2013 16:53 Go to previous messageGo to next message
I have the same problem with dependency and associations. In my transformation, I want to copy the dependency with its supplier/clients. I used the same rule for dependency and I have separate rules for transforming client and suppliers. With "supplier <- source.supplier", in the output model, the supplier in the transformed dependency is empty. what is the reason for that? any suggestion?
Re: cannot transform all suppliers in dependency [message #1075575 is a reply to message #1067472] Mon, 29 July 2013 13:05 Go to previous message
If you check the console, it says the inter reference model is forbidden. to resolve this problem, you can use resolveTemp. Although in some cases ATL can resolve this problem.
Previous Topic:problem in helper
Next Topic:inject a meta model using eNS_URI()
Current Time: Thu Jul 24 21:34:26 EDT 2025
Powered by FUDForum. Page generated in 0.28339 seconds
