Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] ClassCastException String cast to JSONObject
[Texo] ClassCastException String cast to JSONObject [message #1065375] Tue, 25 June 2013 09:32 Go to next message
Hi Martin,
I've got a ClassCastException which came from nowhere... I don't really understand why this happens, since I don't know what I changed compared to the last running version. I'm using the Texo version with qualifier 201304010838.
So this is the stack trace:
java.lang.ClassCastException: java.lang.String cannot be cast to org.json.JSONObject
	at org.eclipse.emf.texo.json.BaseJSONModelConverter.convertSingleEReference(BaseJSONModelConverter.java:261)
	at org.eclipse.emf.texo.json.BaseJSONModelConverter.convertContent(BaseJSONModelConverter.java:228)
	at org.eclipse.emf.texo.json.BaseJSONModelConverter.doConvert(BaseJSONModelConverter.java:113)
	at org.eclipse.emf.texo.json.BaseJSONModelConverter.convertManyEReference(BaseJSONModelConverter.java:376)
	at org.eclipse.emf.texo.json.BaseJSONModelConverter.convertContent(BaseJSONModelConverter.java:220)
	at org.eclipse.emf.texo.json.BaseJSONModelConverter.convert(BaseJSONModelConverter.java:105)
	at org.eclipse.emf.texo.server.service.json.JSONServiceContext.getRequestData(JSONServiceContext.java:94)
	at org.eclipse.emf.texo.server.service.UpdateInsertModelOperation.internalExecute(UpdateInsertModelOperation.java:45)
	at org.eclipse.emf.texo.server.service.ModelOperation.execute(ModelOperation.java:59)
	at org.eclipse.emf.texo.server.web.WebServiceHandler.doPost(WebServiceHandler.java:111)
	at org.eclipse.emf.texo.server.web.WebServiceServlet.doPost(WebServiceServlet.java:65)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
	at de.test.cmp.filter.DatabaseSwitchFilter.doFilter(DatabaseSwitchFilter.java:42)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:936)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1004)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
	at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
	at java.lang.Thread.run(Thread.java:722)
The interessting thing is that the String that is to be cast is "null". It isn't null, but it has the value "null".
I would be glad, if you had a hint, how this could happen.
Best regards
Bastian
Re: [Texo] ClassCastException String cast to JSONObject [message #1065385 is a reply to message #1065375] Tue, 25 June 2013 10:03 Go to previous messageGo to next message
Hi Bastian,
Can you check/debug the upstream/source of the json. Where is the json created? In a the jsonresource or the json
eobject store? How does it arrive on the server.
That would give more clues.
gr. Martin
On 06/25/2013 03:32 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> The interessting thing is that the String that is to be cast is "null". It isn't null, but it has the value "null". I
> Best regards
> Bastian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] ClassCastException String cast to JSONObject [message #1065495 is a reply to message #1065385] Wed, 26 June 2013 03:09 Go to previous messageGo to next message
So I debugged a lot and I now know this situation happens, if there is a single reference from one object to another which should be set null.
As an example:
{"update":[{"id":"{SN must be set}","_eclass":"plane|Instance","db_version":1,"db_Id":1649,"_id":"1649","description":"Description","part":{"_eclass":"plane|Part","db_Id":26,"_id":"26","_proxy":true,"_uri":"http://localhost:8080/test2/jsonws/plane|Part/26#","_title":""},"manufacturer":{"_eclass":"plane|Customer","db_Id":217,"_id":"217","_proxy":true,"_uri":"http://localhost:8080/test2/jsonws/plane|Customer/217#","_title":"Custom"},"children":[],"_uri":"http://localhost:8080/test2/jsonws/plane|Instance/1649#","aVersion":"null","_title":"{SN must be set}"}],"_eclass":"request|ActionType","delete":[],"insert":[],"_title":"{SN must be set}"}
Where the reference aVersion is null. aVersion should be an EObject, but is treated as a String.
Just this moment I got a similar error. There seems to be a null value which is mapped as "null" (String) and therefore cannot be transformed.
java.lang.NumberFormatException: For input string: "null"
	at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
	at java.lang.Long.parseLong(Long.java:441)
	at java.lang.Long.valueOf(Long.java:540)
	at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.createELongObjectFromString(EcoreFactoryImpl.java:953)
	at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.createFromString(EcoreFactoryImpl.java:158)
	at org.eclipse.emf.texo.provider.IdProvider.convertIdStringToId(IdProvider.java:150)
	at org.eclipse.emf.texo.server.service.RetrieveModelOperation.internalExecute(RetrieveModelOperation.java:162)
	at org.eclipse.emf.texo.server.web.WebServiceHandler.doGet(WebServiceHandler.java:89)
	at org.eclipse.emf.texo.server.web.WebServiceServlet.doGet(WebServiceServlet.java:57)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
	at de.kisters.praesto.filter.DatabaseSwitchFilter.doFilter(DatabaseSwitchFilter.java:42)
The json strings are created in the JSONEObjectStore. I'm pretty confused, because these errors came from nowhere...
I really hope to find the reason for that.
Best regards
Bastian
Re: [Texo] ClassCastException String cast to JSONObject [message #1065906 is a reply to message #1065495] Fri, 28 June 2013 04:31 Go to previous messageGo to next message
Hi Bastian,
Sorry to ask, but can you debug the serialization code, to see why/where it happens?
The single ereferences are converted in the BaseModelJSONConverter.convertSingleEReference method. There is an if
statement to handle null:
final T value = (T) eGet(source, eReference);
if (value == null) {
target.put(jsonPropName, JSONObject.NULL);
gr. Martin
On 06/26/2013 09:09 AM, Bastian Wagenfeld wrote:
> As an example: {"update":[{"id":"{SN must be
> Best regards
> Bastian
The Netherlands
Re: [Texo] ClassCastException String cast to JSONObject [message #1065955 is a reply to message #1065906] Fri, 28 June 2013 09:22 Go to previous message
that's right, it sets JSONObject.NULL, but in BaseJSONModelConverter.convertSingleEReference the value is from type String. Maybe somewhere JSONObject.NULL.toString() is used. I fixed it (for now) with just checking, if it's a String or equals "null". That isn't very clean, but it's ok for my use cases...
Maybe my data model was just corrupted. I'll try to do some researches on it after the weekend.
It's just odd that this happened suddenly. I didn't experience it before, altough I persisted null about a million times Smile
I thought it could have been something like a classloader issue. Were two different JSONObject.NULL "classes" were loaded. But this is just a shot in the dark.
I'll have a closer look at this.
Thanks for your help so far Smile
Best regards
Bastian
Previous Topic:[Texo] Using BLOBs
Next Topic:Is there a headless feature for running MWE2 workflows?
Current Time: Sat Jul 26 03:10:59 EDT 2025
Powered by FUDForum. Page generated in 0.04166 seconds
