Home » Modeling » UML2 » what is the root for all UML models?
icon5.gif  what is the root for all UML models? [message #1065278] Tue, 25 June 2013 04:28 Go to next message
[Updated on: Tue, 25 June 2013 05:25] by Moderator
Re: what is the root for all UML models? [message #1065427 is a reply to message #1065278] Tue, 25 June 2013 12:29 Go to previous messageGo to next message
It could be uml:Package or uml:Model or uml:Profile, depending on the kind of top level package it has.
The serialization format is a different question: if your model has no stereotypes applied, it will be uml:Package, uml:Model etc:
<uml:Package xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML" xmlns:xmi="http://www.omg.org/spec/XMI/20110701" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmi:version="20110701" xmi:id="_0" name="customers" URI="I-sandbox-test/customers">
   <packageImport xmi:id="_packageImport.0" />
   <packagedElement xmi:type="uml:Class" xmi:id="Customer" name="Customer">
   </packagedElement>
   <profileApplication xmi:id="_profileApplication.0">
      <eAnnotations xmi:id="_profileApplication.0-_http2F2Fwww.eclipse.org2Fuml22F2.0.02FUML" source="http://www.eclipse.org/uml2/2.0.0/UML">
         <references xmi:type="ecore:EPackage" href="platform:/plugin/com.abstratt.kirra.mdd.core/models/kirra.uml#_http2F2Fwww.eclipse.org2Fuml22F2.0.02FUML-kirra" />
      </eAnnotations>
      <appliedProfile href="platform:/plugin/com.abstratt.kirra.mdd.core/models/kirra.uml#_0" />
   </profileApplication>
</uml:Package>
If it has stereotypes applied, then the stereotype applications will be top-level as well, and since XML admits only one root element, a xmi:XMI element becomes the XML root element, to wrap the proper root elements:
<xmi:XMI xmlns:xmi="http://www.omg.org/spec/XMI/20110701" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:kirra="models/kirra" xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML" xmi:version="20110701" xsi:schemaLocation="models/kirra platform:/plugin/com.abstratt.kirra.mdd.core/models/kirra.uml#_http2F2Fwww.eclipse.org2Fuml22F2.0.02FUML-kirra">
   <uml:Package xmi:id="_0" name="customers" URI="I-sandbox-test/customers">
      </packagedElement>
         </eAnnotations>
   </uml:Package>
   <kirra:Entity xmi:id="_1" base_Class="Customer" />
</xmi:XMI>
I am not 100% positive, but it may be possible to serialize multiple top-level packages in a file, and that would require a root wrapper element as well.
Also, UML2 supports different serialization formats/versions of XMI that may behave differently.
Rafael
http://abstratt.com
[Updated on: Tue, 25 June 2013 12:35] by Moderator
Re: what is the root for all UML models? [message #1065435 is a reply to message #1065427] Tue, 25 June 2013 12:45 Go to previous message
In my case it's UML:Model.
Thank you for all.
Previous Topic:How to get "tagged values" from an attribute of class in UML2.0
Next Topic:Reference beetween Package and class
Current Time: Fri Nov 07 18:19:46 EST 2025
Powered by FUDForum. Page generated in 0.09609 seconds
