Home » Newcomers » Newcomers » Birt - Dataset picks wrong Database(Sql Query in Dataset won't parse because the wrong Database is picked)
Birt - Dataset picks wrong Database [message #1065171] Mon, 24 June 2013 10:58 Go to next message
When using the All-In-One Birt;
Basically I've setup 2 databases (named a1 & a2) with the same table name ("t_1") in both DB's but with differing field names.
The "data sets" seem to only show the fields from the first database (i.e. "a1") with the named table even though the connection is set to the second database (i.e. "a2").
Also trying to use the database name as a precix isn't accepted by the parser.
I really believe this is a bug but perhaps somebody has experienced this and has an answer??
Re: Birt - Dataset picks wrong Database [message #1065200 is a reply to message #1065171] Mon, 24 June 2013 14:24 Go to previous message
> name ("t_1") in both DB's but with differing field names. The "data
> parser.
> and has an answer??
There is a dedicated Eclipse BIRT forum.
Previous Topic:Get Plugins and Updates from Artifactory
Next Topic:Java: Multidimensional Array Initialization Formatting
Current Time: Thu Jul 24 19:24:39 EDT 2025
Powered by FUDForum. Page generated in 0.28674 seconds
