Home » Modeling » EMF » [Teneo] using C3P0: $Proxy10 cannot be cast to oracle.sql.CLOB
[Teneo] using C3P0: $Proxy10 cannot be cast to oracle.sql.CLOB [message #1065054] Mon, 24 June 2013 03:37 Go to next message
I'm trying to use the C3P0 connection pool, but I'm receiving this error when trying to load an object holding a Clob (Oracle database):
- $Proxy10 cannot be cast to oracle.sql.CLOB
Does anyone know how to solve this?
Re: [Teneo] using C3P0: $Proxy10 cannot be cast to oracle.sql.CLOB [message #1065117 is a reply to message #1065054] Mon, 24 June 2013 08:30 Go to previous messageGo to next message
Hi Ricky,
I found this one:
https://hibernate.atlassian.net/browse/HHH-5659
but not sure if related, depends on the hb version.
Can you print the complete stack trace?
gr. Martin
On 06/24/2013 09:37 AM, Ricky de Klerck wrote:
> (Oracle database):
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] using C3P0: $Proxy10 cannot be cast to oracle.sql.CLOB [message #1065149 is a reply to message #1065117] Mon, 24 June 2013 09:55 Go to previous messageGo to next message
This is the complete stack trace:
org.hibernate.exception.GenericJDBCException: An SQLException was provoked by the following failure: java.lang.ClassCastException: $Proxy10 cannot be cast to oracle.sql.CLOB
	at org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:54)
	at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:125)
	at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:110)
	at org.hibernate.engine.jdbc.internal.proxy.AbstractStatementProxyHandler.continueInvocation(AbstractStatementProxyHandler.java:129)
	at org.hibernate.engine.jdbc.internal.proxy.CallableStatementProxyHandler.continueInvocation(CallableStatementProxyHandler.java:49)
	at org.hibernate.engine.jdbc.internal.proxy.AbstractProxyHandler.invoke(AbstractProxyHandler.java:81)
	at $Proxy5.setClob(Unknown Source)
	at smartapps.docgen4o.controller.LinkVariablesController$1.execute(LinkVariablesController.java:77)
	at org.hibernate.jdbc.WorkExecutor.executeWork(WorkExecutor.java:54)
	at org.hibernate.internal.SessionImpl$1.accept(SessionImpl.java:1850)
	at org.hibernate.internal.SessionImpl$1.accept(SessionImpl.java:1847)
	at org.hibernate.engine.jdbc.internal.JdbcCoordinatorImpl.coordinateWork(JdbcCoordinatorImpl.java:211)
	at org.hibernate.internal.SessionImpl.doWork(SessionImpl.java:1868)
	at org.hibernate.internal.SessionImpl.doWork(SessionImpl.java:1854)
	at smartapps.docgen4o.controller.LinkVariablesController.getColumnsForSqlStatement(LinkVariablesController.java:70)
	at smartapps.docgen4o.controller.DocumentSqlStatementController.getLinkVariablesForSqlStatement(DocumentSqlStatementController.java:205)
	at smartapps.docgen4o.controller.DocumentSqlStatementController.getAllLinkVariables(DocumentSqlStatementController.java:197)
	at smartapps.docgen4o.developerperspective.workbench.widgets.edit.SQLEditComposite.initLinkedVariables(SQLEditComposite.java:612)
	at smartapps.docgen4o.developerperspective.workbench.widgets.edit.SQLEditComposite.<init>(SQLEditComposite.java:403)
	at smartapps.docgen4o.developerperspective.document.DocumentEditPage.createStatementComposite(DocumentEditPage.java:592)
	at smartapps.docgen4o.developerperspective.document.DocumentEditPage$6.doubleClick(DocumentEditPage.java:533)
	at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:845)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:843)
	at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1462)
	at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1246)
	at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:249)
	at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:246)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:307)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at smartapps.docgen4o.application.Application.start(Application.java:20)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.sql.SQLException: An SQLException was provoked by the following failure: java.lang.ClassCastException: $Proxy10 cannot be cast to oracle.sql.CLOB
	at com.mchange.v2.sql.SqlUtils.toSQLException(SqlUtils.java:106)
	at com.mchange.v2.sql.SqlUtils.toSQLException(SqlUtils.java:65)
	at com.mchange.v2.sql.SqlUtils.toSQLException(SqlUtils.java:62)
	at com.mchange.v2.c3p0.impl.NewPooledConnection.handleThrowable(NewPooledConnection.java:369)
	at com.mchange.v2.c3p0.impl.NewProxyCallableStatement.setClob(NewProxyCallableStatement.java:2590)
	at org.hibernate.engine.jdbc.internal.proxy.AbstractStatementProxyHandler.continueInvocation(AbstractStatementProxyHandler.java:122)
	... 52 more
Caused by: java.lang.ClassCastException: $Proxy10 cannot be cast to oracle.sql.CLOB
	at oracle.jdbc.driver.OraclePreparedStatement.setClobInternal(OraclePreparedStatement.java:6749)
	at oracle.jdbc.driver.OracleCallableStatement.setClob(OracleCallableStatement.java:4869)
	at oracle.jdbc.driver.OraclePreparedStatementWrapper.setClob(OraclePreparedStatementWrapper.java:160)
	at com.mchange.v2.c3p0.impl.NewProxyCallableStatement.setClob(NewProxyCallableStatement.java:2576)
	... 57 more
Re: [Teneo] using C3P0: $Proxy10 cannot be cast to oracle.sql.CLOB [message #1065273 is a reply to message #1065149] Tue, 25 June 2013 04:17 Go to previous messageGo to next message
Hi Ricky,
And which version of Hb are you on?
gr. Martin
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> ... 52 more
> ... 57 more
The Netherlands
Re: [Teneo] using C3P0: $Proxy10 cannot be cast to oracle.sql.CLOB [message #1065281 is a reply to message #1065273] Tue, 25 June 2013 04:38 Go to previous message
These versions:
Hibernate 4.1.1
Teneo Hibernate 2.0.1
Previous Topic:Containment and eOpposite
Next Topic:EMF Support for xsd:whitespace
Current Time: Wed Jul 30 23:39:30 EDT 2025
Powered by FUDForum. Page generated in 0.24189 seconds
