Home » Modeling » EMF » Upgrade of Xcore SDK produces strange errors
Upgrade of Xcore SDK produces strange errors [message #1062065] Wed, 05 June 2013 11:54 Go to next message
I upgraded to the latest Xcore SDK (1.1.0.v20130529-0713) and now I get following errors:
When I use 'String' or 'boolean' as attribute type then the Xcore source editor gives me this error message: "A generic type in this context must refer to a classifier or a type parameter"
When I wrap the String like this
type String wraps String
then the error disappears.
The second type of error is that the @GenModel annotation is not known anymore and the error "Couldn't resolve reference to XAnnotationDirective 'GenModel'." appears in the tooltip.
For this error I found no workaround.
What went wrong in my installation?
Is there a dependency which must exist?
All problems began when I tried to install the e4 tools into my Eclipse. But I use a target platform for developing my plug-ins so the e4 tools should not influence the Xcore target platform file or am I missing something?
With regards,
Udo
Re: Upgrade of Xcore SDK produces strange errors [message #1062095 is a reply to message #1062065] Wed, 05 June 2013 19:08 Go to previous messageGo to next message
Udo,
There have been quite a few changes in how Xtext does indexing and some
lock-step changes in Xbase on which Xcore depends, so it's important to
have updated the Xtext SDK as well (and there are no version range
dependencies for these builds that enforces updating Xtext when you
update Xcore). Perhaps something as simple as a clean build would
rebuild the Xtext index, or perhaps you need to update your Xtext SDK as
well...
On 05/06/2013 5:54 PM, Udo Walker wrote:
> missing something?
> With regards,
> Udo
Re: Upgrade of Xcore SDK produces strange errors [message #1062140 is a reply to message #1062095] Thu, 06 June 2013 04:11 Go to previous messageGo to next message
Hi Ed,
thanks for the tip with the "no version-range dependencies".
My target platform versions are still set to "0.0.0" to get the newest versions. But the versions in my plug-in dependencies were either not set at all or set to the wrong minimum version so the version combination of org.eclipse.xtext.xbase.lib and org.eclipse.emf.ecore.xcore.lib was random and did not work. I fixed the versions and now it works again.
With regards,
Udo
Re: Upgrade of Xcore SDK produces strange errors [message #1065099 is a reply to message #1062065] Mon, 24 June 2013 07:27 Go to previous messageGo to next message
So setting the plugin dependencies to the exact version numbers has solved this issue for you? I'm facing exactly the same thing but I just cant get it working to recognize the type. It also happens that when I use this "type-wraps" workaround the code will be generated in the src folder not in the src-gen.
Re: Upgrade of Xcore SDK produces strange errors [message #1065111 is a reply to message #1065099] Mon, 24 June 2013 08:10 Go to previous messageGo to next message
Tamas,
The best I can suggest is getting consistent versions of Xcore and
Xbase/Xtext from the Kepler repo...
Re: Upgrade of Xcore SDK produces strange errors [message #1065120 is a reply to message #1065111] Mon, 24 June 2013 08:48 Go to previous messageGo to next message
I have downloaded freshly both xcore and xtext/xtend from the kepler update site and the errors still appear.
Re: Upgrade of Xcore SDK produces strange errors [message #1065138 is a reply to message #1065120] Mon, 24 June 2013 09:29 Go to previous messageGo to next message
Tamas,
Does a clean build fix the problem?
Re: Upgrade of Xcore SDK produces strange errors [message #1065161 is a reply to message #1065138] Mon, 24 June 2013 10:18 Go to previous messageGo to next message
No, it doesn't solve it.
Re: Upgrade of Xcore SDK produces strange errors [message #1065172 is a reply to message #1065161] Mon, 24 June 2013 11:08 Go to previous messageGo to next message
Tamas,
Is this happening in a self-hosted IDE launch or directly in your main
Eclipse IDE?
Re: Upgrade of Xcore SDK produces strange errors [message #1065709 is a reply to message #1065172] Thu, 27 June 2013 04:37 Go to previous messageGo to next message
I had the same problem. I could fix it by adding:
 org.eclipse.emf.ecore.xcore.lib;visibility:=reexport,
to the required plugins in the Manifest file.
Hendrik.
Re: Upgrade of Xcore SDK produces strange errors [message #1066402 is a reply to message #1065709] Tue, 02 July 2013 08:59 Go to previous messageGo to next message
adding:
did not solve the same problem for me.
New kepler modeling edition, new xcore sdk, new xcore project
Re: Upgrade of Xcore SDK produces strange errors [message #1066410 is a reply to message #1066402] Tue, 02 July 2013 09:47 Go to previous messageGo to next message
Albert,
I think there's a bug for which I'm working on a fix. But there's no
bugzilla open yet. Please open one with the steps so I can be sure I'm
fixing exactly the problem you're seeing.
On 02/07/2013 3:35 PM, Albert ündorf wrote:
> adding:
Re: Upgrade of Xcore SDK produces strange errors [message #1066661 is a reply to message #1066410] Wed, 03 July 2013 11:25 Go to previous messageGo to next message
I also have this bug. I opened some closed projects in my ws and can't get around the bug. (opened projects work with this annotation work).
Is the any progress or can someone post a link to the bug?
Re: Upgrade of Xcore SDK produces strange errors [message #1066729 is a reply to message #1066661] Thu, 04 July 2013 02:51 Go to previous messageGo to next message
Sandro,
No one has opened a bugzilla yet, so while I think I spotted a problem
and appear to have fixed it, it would be good to verify that it's the
problem others are seeing, so a bugzilla with steps would help.
Re: Upgrade of Xcore SDK produces strange errors [message #1071175 is a reply to message #1066729] Fri, 19 July 2013 09:53 Go to previous messageGo to next message
works now with emf-xcore-SDK-N201307100733 and the following dependencies:
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
org.eclipse.xtext.xbase.lib;visibility:=reexport,
Re: Upgrade of Xcore SDK produces strange errors [message #1071181 is a reply to message #1071175] Fri, 19 July 2013 10:02 Go to previous message
Sandro,
Yes, I believe I fixed the root cause of the problem via
https://bugs.eclipse.org/bugs/show_bug.cgi?id=412753 for both the
maintenance stream and the development stream.
> dependencies:
Previous Topic:Drag'n drop (or cut & paste) programmatically
Next Topic:Access an EMF package from the Ecore file.
Current Time: Sat Jul 26 08:14:19 EDT 2025
Powered by FUDForum. Page generated in 0.07383 seconds
