Home » Eclipse Projects » Eclipse Scout » Search form in second table page disappear
Search form in second table page disappear [message #1065092] Mon, 24 June 2013 06:52 Go to next message
Hi there
Currently, I work myself through the CRM-Tutorial of Scout. When I'm creating the second page with Persons and add a search form, like the Company-Page has, it isn't visible. The person-search form is visible for a small amount of seconds and then disappears. If I remove the company-search form, the person-search form is working fine. The code is the same as in the tutorial.
What could be a possible reason for that behavior?
Re: Search form in second table page disappear [message #1065122 is a reply to message #1065092] Mon, 24 June 2013 08:50 Go to previous messageGo to next message
This is a known bug. I suggest you switch to the Kepler release of Scout (3.9.0) because that bug has been fixed in Scout 3.9.0.
Re: Search form in second table page disappear [message #1065143 is a reply to message #1065092] Mon, 24 June 2013 09:44 Go to previous message
Remo von Arx wrote on Mon, 24 June 2013 06:52
Hi there
I guess that you are using Eclipse 4.x (either Juno 4.2 or Kepler 4.3) with Scout 3.9. Do you use the SWT UI for your client?
If so, this is a known E4 bug that should be fixed with the Service Release 1 (SR1) of Eclipse Kepler 4.3.1.
Please refer to my previous forum posts [1], [2] and also the important one [3] if you'd like to switch from E4 to E3.x
[1] http://www.eclipse.org/forums/index.php/t/449568/
[2] http://www.eclipse.org/forums/index.php/t/458838/
[3] http://www.eclipse.org/forums/index.php/t/489223/
Previous Topic:Browser bypasses authentication step
Next Topic:Minimize SearchForms
Current Time: Sun Jul 27 02:23:54 EDT 2025
Powered by FUDForum. Page generated in 0.27006 seconds
