Home » Newcomers » Newcomers » Programmatically close file in text editor?
Programmatically close file in text editor? [message #1065030] Sun, 23 June 2013 12:40 Go to next message
I have a TextEditor open and it displays text from several files.
How can I programmatically close one of these files?
Thanks for your help.
Re: Programmatically close file in text editor? [message #1065032 is a reply to message #1065030] Sun, 23 June 2013 13:11 Go to previous messageGo to next message
On 23-06-2013 18:40, Eclipse Explorer wrote:
> Hello,
You dont have to write a program for that,
The have a build in key, just for that purpose
It's: ALT+F4
Re: Programmatically close file in text editor? [message #1065033 is a reply to message #1065032] Sun, 23 June 2013 13:29 Go to previous messageGo to next message
Thanks Luuk,
I realize that I can use key combinations, or click the "x" in the editor. However, the logic for the code that I am writing requires that I close the file programmatically.
Re: Programmatically close file in text editor? [message #1065034 is a reply to message #1065033] Sun, 23 June 2013 14:55 Go to previous messageGo to next message
On 23-06-2013 19:29, Eclipse Explorer wrote:
> Thanks Luuk,
Ok,
what language do you want to program this in?
and on what OS?
If its Windows, take look at AutoIt
(http://www.autoitscript.com/site/autoit/)
Re: Programmatically close file in text editor? [message #1065039 is a reply to message #1065034] Sun, 23 June 2013 23:30 Go to previous messageGo to next message
You should call IWorkbenchPage.html#closeEditor() .
http://help.eclipse.org/indigo/topic/org.eclipse.platform.doc.isv/reference/api/org/eclipse/ui/IWorkbenchPage.html
Re: Programmatically close file in text editor? [message #1065156 is a reply to message #1065039] Mon, 24 June 2013 10:07 Go to previous messageGo to next message
Hi Nitin,
When the editor has several pages (files) open, I only want to close one of the pages.
The snippet that you provided closes all the pages.
Re: Programmatically close file in text editor? [message #1065157 is a reply to message #1065156] Mon, 24 June 2013 10:12 Go to previous messageGo to next message
It's not possible to close a single page of a MultiPageEditorPart without that editor having done a significant amount of work to allow it, and presumably, giving you an API of its own to do so. There's no standard way to do so.
Re: Programmatically close file in text editor? [message #1065162 is a reply to message #1065157] Mon, 24 June 2013 10:33 Go to previous messageGo to next message
Hi Nitin,
It's not a multipage editor; it's an extension from org.eclipse.ui.editors.text.TextEditor.
An analogy is the Java Editor. If you have several java files open, and delete one of these files in the Package Explorer, "Eclipse" no longer displays the file that you deleted in the Java editor. I am attempting to accomplish this programmatically.
Once again, thank you for your help.
Re: Programmatically close file in text editor? [message #1065382 is a reply to message #1065162] Tue, 25 June 2013 09:58 Go to previous message
If that's the case, you should look more closely at the JavaDoc page I linked. There are methods for closing specific editor parts.
Previous Topic:Java: Multidimensional Array Initialization Formatting
Next Topic:JUnit plugin
Current Time: Sat Aug 30 19:36:42 EDT 2025
Powered by FUDForum. Page generated in 0.19149 seconds
