Home » Modeling » TMF (Xtext) » What is wrong with my simple grammar ?
What is wrong with my simple grammar ? [message #1064902] Fri, 21 June 2013 10:59 Go to next message
I'm trying to define a grammar able to support writing the following text:
--NECST HEADER Scripts
#NESCT START
#NECST MIDDLE [free_text1][free_text2]
    --NECST ONE Script
    --NECST TWO Script
#NECST EXIT
For that, I have define the following grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals hidden (NECST_PARAM)
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:{Model}
	'--NECST HEADER Scripts'
	(commentNecst+=CommandNecst*)?
	scripts+=Script+;
CommandNecst:
	'#NECST' command=ENUM_COMMANDNECST param+=NECST_PARAM*;
enum ENUM_COMMANDNECST : START|MIDDLE|EXIT;
Script:
	'--NECST' script=ENUM_SCRIPT 'Script'
enum ENUM_SCRIPT : ONE|TWO|THREE;
terminal NECST_PARAM : '[' -> ']';
But, I am not able to type anything after the first line.
What is wrong ?
Re: What is wrong with my simple grammar ? [message #1064907 is a reply to message #1064902] Fri, 21 June 2013 11:15 Go to previous messageGo to next message
the problem is the hidden statement it should include ws and others. besides ws in keywords is a bad idea
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals hidden (NECST_PARAM,WS, ML_COMMENT, SL_COMMENT)
Model:{Model}
	'--NECST' 'HEADER' 'Scripts'
	scripts+=Script+;
CommandNecst:
Script:
Re: What is wrong with my simple grammar ? [message #1064924 is a reply to message #1064907] Fri, 21 June 2013 12:31 Go to previous messageGo to next message
Great Christian, Thanks !
I am now able to write the beginning of my file, except the final "#NECST EXIT".
Can you give me a tip for this issue ?
Re: What is wrong with my simple grammar ? [message #1064939 is a reply to message #1064924] Fri, 21 June 2013 13:57 Go to previous messageGo to next message
your grammar says the file ends with scripts
Re: What is wrong with my simple grammar ? [message #1064950 is a reply to message #1064939] Fri, 21 June 2013 17:02 Go to previous messageGo to next message
Ok, so I've tried the following:
Model:{Model}
	commandNecst+=CommandNecst*
	script+=Script+
	e=Exit
CommandNecst:
enum ENUM_COMMANDNECST : START|MIDDLE;
Exit:
	'#NECST' 'EXIT'
Script:
enum ENUM_SCRIPT : ON|TWO|THREE;
But after having typed some "Script", the content assist keeps proposing me other "Script" but no "Exit" rule;and I don't know how to do so.
Any Idea ?
Re: What is wrong with my simple grammar ? [message #1064958 is a reply to message #1064950] Fri, 21 June 2013 18:07 Go to previous messageGo to next message
you have to define content assist for custom datatype rules yourself by implementing the corresponding method in the proposalprovider
alternatively you can change the datatype rule to a real parser rule e.g.
Exit:
{Exit} '#NECST' 'EXIT'
Re: What is wrong with my simple grammar ? [message #1064969 is a reply to message #1064958] Sat, 22 June 2013 04:12 Go to previous message
Thank you very much Christian, that works fine now !
Previous Topic:Xtext validation on closed files
Next Topic:LLVM Suport
Current Time: Fri Jul 25 19:32:31 EDT 2025
Powered by FUDForum. Page generated in 0.05304 seconds
