Home » Language IDEs » Java Development Tools (JDT) » how do get the Eclipse version number?(how to relate what Eclipse shows to the bugzilla version numbers)
how do get the Eclipse version number? [message #1064911] Fri, 21 June 2013 11:33 Go to next message
In bugzilla, I see version numbers for Eclipse like 4.2.2 and 4.3.
But when I'm running the Mac OS version of Eclipse IDE for Java Developers, and I click to open the About window, that window shows version "Juno Service Release 2". Looking further at the Installation details, it shows
Eclipse IDE for Java Developers 1.5.2.20130211-1820 epp.package.java null
So how does one relate this information to numbers like those used in bugzilla for Eclipse?
Paul
Re: how do get the Eclipse version number? [message #1064914 is a reply to message #1064911] Fri, 21 June 2013 11:49 Go to previous messageGo to next message
Paul,
Look in the installation details Features tab. The Eclipse Platform
feature should provide the details you need.
> details, it shows
> Paul
Re: how do get the Eclipse version number? [message #1064916 is a reply to message #1064914] Fri, 21 June 2013 12:00 Go to previous messageGo to next message
Thank you for the quick reply Ed.
I found this --
Eclipse Platform
Version: 4.2.1.v20130118-173121-9MF7GHYdG0B5kx4E_SkfZV-1mNjVATf67ZAb7
Build id: M20130204-1200
So this would imply that I'm running 4.2.1.
Am I correct in understanding that there is a 4.2.2 out there, and possibly a 4.3?
Or are they not public yet?
Because when I click under Help to Check for Updates, it says there are no updates available.
Thanks again,
Paul
Re: how do get the Eclipse version number? [message #1064981 is a reply to message #1064916] Sat, 22 June 2013 08:52 Go to previous messageGo to next message
The current service release SR2 (4.2.2) happens to contain version 4.2.1 of the org.eclipse.platform feature.
4.3 will go public next Wednesday.
For components of the Eclipse SDK, bugzilla version numbers correspond to these annual release versions.
For other components you'd have to drill into the installation details of that particular feature to find their version numbers.
You already noticed that the Eclipse Packaging Project (e.g. "Eclipse IDE for Java Developers") has its own versions.
Re: how do get the Eclipse version number? [message #1064982 is a reply to message #1064981] Sat, 22 June 2013 09:01 Go to previous messageGo to next message
To be honest, this is still rather confusing,
but thanks for the info.
There are a few bugs that bugzilla says are fixed in 4.3,
so I'm looking forward to next week's release.
Thanks.
Re: how do get the Eclipse version number? [message #1065009 is a reply to message #1064982] Sun, 23 June 2013 06:22 Go to previous messageGo to next message
Paul,
Yes, it is a bit confusing being the software is composed from so many
components, each of which is individually versioned and it's especially
hard to manage the incrementing of the micro version level (third
number) because there's little tool support to tell you when you should
increment it after making a change...
> There are a few bugs that bugzilla says are fixed in 4.3, so I'm
> Thanks.
Re: how do get the Eclipse version number? [message #1065809 is a reply to message #1065009] Thu, 27 June 2013 10:33 Go to previous messageGo to next message
Last week, Stephan said that 4.3 would be made public on the following Wednesday.
Today is Thursday. I just checked for updates and Eclipse is still saying that there are none.
Was 4.3 made public? If yes, why is Eclipse "Check for Updates" saying there are none?
Thanks.
Re: how do get the Eclipse version number? [message #1065827 is a reply to message #1065809] Thu, 27 June 2013 11:39 Go to previous messageGo to next message
Paul,
It depends on which repo you point Eclipse to when searching for
updates. All the latest stuff is in the kepler repo. I'm not sure it's
a good idea to try to update Eclipse itself to a new version, but maybe
that works...
> Wednesday.
> there are none?
> Thanks.
Re: how do get the Eclipse version number? [message #1066206 is a reply to message #1065827] Mon, 01 July 2013 10:35 Go to previous messageGo to next message
Hi Ed,
I just posted a new thread asking this question again because I never got an email saying that anyone had posted a reply to my question last week. Then I found your reply.
Are you saying that 4.2.2 can not be updated to 4.3.
That doesn't sound right?
Can you please be more specific about what urls are needed to get 4.3 and how they need to be setup.
Paul
Re: how do get the Eclipse version number? [message #1066223 is a reply to message #1066206] Mon, 01 July 2013 11:09 Go to previous message
Paul,
You can try to update the IDE as a whole, but in the past that didn't
work well. It might work fine... It seems safer to download the 4.3
package that most closely matches your needs and install any of the
other things you need/want into that.
On 01/07/2013 4:35 PM, Paul Levin wrote:
> Hi Ed,
> Are you saying that 4.2.2 can not be updated to 4.3. That doesn't
> sound right?
> Paul
Previous Topic:how to change realtime inspect window's foreground font color?
Next Topic:Eclipse is not finding new updates
Current Time: Fri Jul 25 16:07:04 EDT 2025
Powered by FUDForum. Page generated in 0.05909 seconds
