Home » Archived » BIRT » populate a lsitbox or radio button
populate a lsitbox or radio button [message #1064840] Fri, 21 June 2013 06:26 Go to next message
sir,i have to customize report as shown in attached image and i attached a jsp and report design in sample db here for u r reference
for example :
one set of radio button and populate a list box or text box
item wise ---->A,B,C,D,E
main type---->A,b,c,d
another set of radio button and populate a list box or text box
country-->A,B,C,D,E
city---->A,B,C,D,E
if i select A From ITEM WISE and then I select B from COUNTRY result will be produced
and then again if i select A From ITEM WISE and then I select B from city result will be produced----
i have thought to pass parameter by url or by on click event but am struggling a lot
my question is how to pass parameter for this report in custom parameter page to hide/show the appropriate one based on the radio button value.
can u provide solution for this by sample db with jsp?
thank u in advance
[Updated on: Fri, 21 June 2013 06:41] by Moderator
Re: populate a lsitbox or radio button [message #1065153 is a reply to message #1064840] Mon, 24 June 2013 10:04 Go to previous message
kindly reply for this post
thank in advance
Previous Topic:Dataset results are incomplete
Next Topic:Birt Tutorial for EMF CDO
Current Time: Sat Jul 19 04:42:30 EDT 2025
Powered by FUDForum. Page generated in 0.04371 seconds
