Home » Modeling » EMF » [EMF] EContentAdapter
[EMF] EContentAdapter [message #1064818] Fri, 21 June 2013 04:33 Go to next message
I am working on a patch for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=405483
Now I notice something interesting in EContentAdapter; The adapter can
self-adapt to the containment hierarchy of an EObject, Resource or
Resourceset. While self-adapting the 'target' of the adapter is set to
whatever object was 'last' self-adapted, by calling basicSetTarget(target).
I wonder why this is? I understand the adapter is shared, but what's the
point of replacing the target? If there are many targets, there are
actually no-targets...
Now for the EContentAdapter, It doesn't seem to matter. (None of the
code is calling getTarget(), except some code in EAdapterList.didRemove
but I keep wondering what is the purpose of the target in an AdapterImpl
considering that's overwritten continuously in the EContentAdapter ?
For bug 405483 or better for implementations which extend
CDOLazyContentAdapter, it would be nice to rely on the 'target' being
the root object of the hierarchy. Interestingly enough,
CDOLazyContentAdapter tracks the root in another field:
private WeakReference<CDOObject> adaptedRoot;
Thank you,
Christophe Bouhier
Re: [EMF] EContentAdapter [message #1064825 is a reply to message #1064818] Fri, 21 June 2013 04:49 Go to previous messageGo to next message
Christophe,
Comments below.
On 21/06/2013 10:33 AM, Christophe Bouhier wrote:
> can self-adapt to the containment hierarchy of an EObject, Resource or
> the point of replacing the target? If there are many targets, there
> are actually no-targets...
Yes, it's a bit questionable.
> EAdapterList.didRemove but I keep wondering what is the purpose of the
> target in an AdapterImpl considering that's overwritten continuously
There really isn't much point other than to reproduce consistent but
arguably useless behavior. Potentially more purposeful would be to
extend org.eclipse.emf.common.notify.impl.SingletonAdapterImpl but that
didn't exist at the time.
Yes, arguably the first object to which it was attached is most
logically the "target".
> Interestingly enough, CDOLazyContentAdapter tracks the root in another
> field:
> Thank you,
> Christophe Bouhier
Re: [EMF] EContentAdapter [message #1064833 is a reply to message #1064825] Fri, 21 June 2013 05:50 Go to previous message
Thanks Ed.
On 21-06-13 10:49, Ed Merks wrote:
> Christophe,
> Comments below.
>> Hi,
>> field:
>> Thank you,
>> Christophe Bouhier
Previous Topic:Show EMF Validation problems in Eclipse problems view
Next Topic:[SOLVED] Parts of EMF Plugin are not deployed on startup
Current Time: Sun Jul 27 04:16:54 EDT 2025
Powered by FUDForum. Page generated in 0.02915 seconds
