Eclipse 3.7 with NatTable 0.9 to Eclipse 4.2 with Nattable 1.0.0 [message #1064680] |
Thu, 20 June 2013 10:08  |
Hello!
i moved my application from Eclipse 3.7 with NatTable 0.9 to Eclipse 4.2 with NatTable 1.0.0;
the bundles i created with my customized table were not touched/changed while moving to the newer versions.
so in 3.7 al was fine, now i get the exception below.
important notice:
the application starts as usual, also the table gets rendered ok.
i can add and remove columns, add filters etc.
the only thing i can NO MORE do is 'choose columns' - open the dialog which lets you choose the columns to display, thats where the exception gets raised...
java.lang.ClassNotFoundException: lumo.widgets.table.ColumnCategoriesModelProvider
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at java.io.ObjectInputStream.resolveClass(Unknown Source)
at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.readObject(Unknown Source)
at org.eclipse.nebula.widgets.nattable.util.ObjectCloner.deepCopy(ObjectCloner.java:41)
at org.eclipse.nebula.widgets.nattable.columnCategories.gui.AvailableColumnCategoriesProvider.<init>(AvailableColumnCategoriesProvider.java:34)
at org.eclipse.nebula.widgets.nattable.columnCategories.gui.ColumnCategoriesDialog.populateAvailableTree(ColumnCategoriesDialog.java:156)
at org.eclipse.nebula.widgets.nattable.columnCategories.gui.ColumnCategoriesDialog.populateDialogArea(ColumnCategoriesDialog.java:85)
at org.eclipse.nebula.widgets.nattable.columnChooser.gui.AbstractColumnChooserDialog.createDialogArea(AbstractColumnChooserDialog.java:56)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:760)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.nebula.widgets.nattable.columnCategories.ChooseColumnsFromCategoriesCommandHandler.doCommand(ChooseColumnsFromCategoriesCommandHandler.java:65)
at org.eclipse.nebula.widgets.nattable.columnCategories.ChooseColumnsFromCategoriesCommandHandler.doCommand(ChooseColumnsFromCategoriesCommandHandler.java:1)
at org.eclipse.nebula.widgets.nattable.command.AbstractLayerCommandHandler.doCommand(AbstractLayerCommandHandler.java:19)
at org.eclipse.nebula.widgets.nattable.layer.AbstractLayer.doCommand(AbstractLayer.java:154)
at org.eclipse.nebula.widgets.nattable.layer.AbstractLayerTransform.doCommand(AbstractLayerTransform.java:102)
at org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer.doCommandOnChildLayer(GridLayer.java:109)
at org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer.doCommandOnChildLayers(GridLayer.java:96)
at org.eclipse.nebula.widgets.nattable.layer.CompositeLayer.doCommand(CompositeLayer.java:137)
at org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer.doCommand(GridLayer.java:178)
at org.eclipse.nebula.widgets.nattable.NatTable.doCommand(NatTable.java:516)
at org.eclipse.nebula.widgets.nattable.ui.menu.MenuItemProviders$14$1.widgetSelected(MenuItemProviders.java:468)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at at.biooffice.application.Application.start(Application.java:44)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
!ENTRY org.eclipse.ui 4 0 2013-06-20 15:48:31.099
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.nebula.widgets.nattable.columnCategories.gui.AvailableColumnCategoriesProvider.hideEntries(AvailableColumnCategoriesProvider.java:43)
at org.eclipse.nebula.widgets.nattable.columnCategories.gui.ColumnCategoriesDialog.populateAvailableTree(ColumnCategoriesDialog.java:157)
the class lumo.widgets.table.ColumnCategoriesModelProvider is in the same bundle, even in the same package (!) as my customized table class!
the stacktrace tells (me) nothing as at.biooffice.application.Application.start(Application.java:44) is simply
final int returnCode = PlatformUI.createAndRunWorkbench(display,
new ApplicationWorkbenchAdvisor());
you guys are my last hope to get this thing working again...
thanks in advance
lumo
EDIT: if you need any more information let me know
see screenshot
[Updated on: Thu, 20 June 2013 10:29] by Moderator
Re: Eclipse 3.7 with NatTable 0.9 to Eclipse 4.2 with Nattable 1.0.0 [message #1065400 is a reply to message #1065389] |
Tue, 25 June 2013 10:53   |
i have a FieldInfoCollection (collection of informations on fields displayed in table and formular)
from this flat collection i generate my ColumnCategoriesModel.
it creates a Java-Object tree representation of my Data (from flat table)
eg: Person with Address:
Person.firstName
Person.lastName
Person.Address.street
Person.Address.country
etc...
this is built into the tree:
Person
+firstName
+lastName
->Address
+street
+country
here is my ColumnCategoriesModelProvider:
package lumo.widgets.table;
import java.util.HashMap;
public class ColumnCategoriesModelProvider extends ColumnCategoriesModel {
private static final long serialVersionUID = 1001L;
public ColumnCategoriesModelProvider(FieldInfoCollection fiCollection) {
String cls = fiCollection.get(0).getSimpleClassName();
Node root = addRootCategory(cls);
Map<String, Node> mapping = new HashMap<String, Node>();
List<FieldInfo> infos = fiCollection.getAll();
for (int i = 0; i < infos.size(); i++) {
FieldInfo fi = infos.get(i);
String nodeName = cls+"."+fi.getInternal();
String[] split = nodeName.split("\\.");
Node parentCategory = root;
for (int j = 0; j < split.length; j++) {
if (j < split.length - 1) {
// its no leaf yet
Node n = mapping.get(split[j].toLowerCase());
if (n == null) {
n = addCategory(parentCategory, ColumnCategoriesModelProvider.capitaliseFirstLetter(split[j]));
mapping.put(split[j].toLowerCase(), n);
parentCategory = n;
} else {
addColumnsToCategory(parentCategory, fi.getIndex());
break;
while (parentCategory!=root) {
parentCategory = parentCategory.getParent();
public static String capitaliseFirstLetter(String string) {
return string.substring(0, 1).toUpperCase() + string.substring(1);
* Method to join array elements of type string
* @author lumo
* @param inputArray
* Array which contains strings
* @param toIndex
* to the position of the array - stops here
* @param glueString
* String between each array element
* @return String containing all array elements seperated by glue string
public static String implode(String[] inputArray, int toIndex,
String glueString) {
String output = "";
if (toIndex >= inputArray.length) {
throw new IndexOutOfBoundsException(
"You tried to Implode an Array to an Index, which is outside of the Size of the given Array.");
if (inputArray.length > 0) {
StringBuilder sb = new StringBuilder();
sb.append(inputArray[0]);
for (int i = 1; i <= toIndex; i++) {
sb.append(glueString);
sb.append(inputArray[i]);
output = sb.toString();
return output;
i am open to any other solutions!
FUDForum. Page generated in 0.06269 seconds
