Home » Modeling » TMF (Xtext) » Xtext Grammar - Exclusion of a specific Rule
Xtext Grammar - Exclusion of a specific Rule [message #1064689] Thu, 20 June 2013 10:47 Go to next message
So I have the following rules:
HtmlAcceptedElement:
	BinaryElements | Image | Link | Text
and
BinaryElements:
	Bold | Italic | Underline | Paragraph
now I want for Bold to do the following:
Bold:
	'b' (htmlaccelement+=HtmlAcceptedElement)+ '/b'
but I want to don't allow Bold rule to be inside this: (htmlaccelement+=HtmlAcceptedElement)+
is this possible? to say somehow HtmlAcceptedElement except Bold ?
Thanks in advance!
Re: Xtext Grammar - Exclusion of a specific Rule [message #1064691 is a reply to message #1064689] Thu, 20 June 2013 10:49 Go to previous messageGo to next message
HtmlAcceptedElementSpezial returns HtmlAcceptedElement:
BinaryElementsSpezial | Image | Link | Text
BinaryElementsSpezial returns BinaryElements:
Bold:
'b' (htmlaccelement+=HtmlAcceptedElementSpezial )+ '/b'
Re: Xtext Grammar - Exclusion of a specific Rule [message #1064692 is a reply to message #1064691] Thu, 20 June 2013 10:52 Go to previous messageGo to next message
so is not an easier way? because then I have to do the same for italic and all others
and thanks for the quick answer!
Re: Xtext Grammar - Exclusion of a specific Rule [message #1064703 is a reply to message #1064692] Thu, 20 June 2013 11:07 Go to previous messageGo to next message
Hat about a check?
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Xtext Grammar - Exclusion of a specific Rule [message #1064715 is a reply to message #1064703] Thu, 20 June 2013 12:07 Go to previous messageGo to next message
Sorry, I don't get what you mean. What check? Or if you suggest to check in the grammar, how exactly is done that ?
Re: Xtext Grammar - Exclusion of a specific Rule [message #1064722 is a reply to message #1064715] Thu, 20 June 2013 12:29 Go to previous messageGo to next message
No i Mean to solve it with Semantic validaton (javavalidator) instead of solving it in grammar
Re: Xtext Grammar - Exclusion of a specific Rule [message #1064740 is a reply to message #1064722] Thu, 20 June 2013 14:34 Go to previous messageGo to next message
yes i could do that, but then the suggestion (ctrl+space) will still show what I don't need (the Bold again)
Re: Xtext Grammar - Exclusion of a specific Rule [message #1064746 is a reply to message #1064740] Thu, 20 June 2013 14:54 Go to previous messageGo to next message
you could try to fix content assist but this might be even more work than introducing the additional rules as i suggested before.
Update: i dont know if there is a nice place to hook into content assist maybe
org.eclipse.xtext.ui.editor.contentassist.AbstractContentProposalProvider.createProposals(ContentAssistContext, ICompletionProposalAcceptor)
could serve as starting point.
[Updated on: Thu, 20 June 2013 15:00] by Moderator
Re: Xtext Grammar - Exclusion of a specific Rule [message #1064748 is a reply to message #1064746] Thu, 20 June 2013 15:01 Go to previous messageGo to next message
in the additional rules is a flaw imagine that you have the following use case: b i <<here>> /i /b or i b <<here>> /b /i
at <<here>> i can add again b (or i) and /b (or /i) that I don't want. This assuming what you proposed plus:
BinaryElementsSpezialItalic | Image | Link | Text
BinaryElementsSpezialItalic returns BinaryElements:
Bold | Underline | Paragraph
Italic:
'i' (htmlaccelement+=HtmlAcceptedElementSpezialItalic )+ '/i'
Thanks for all the effort!
Re: Xtext Grammar - Exclusion of a specific Rule [message #1064749 is a reply to message #1064748] Thu, 20 June 2013 15:10 Go to previous messageGo to next message
Sorry i dont know any out of the box solutions for this usecase.
and you are right the rules might explode.
unfortunately ParserBasedContentAssistContextFactory does not seem to have nice hooks for filtering.
and i dont know how easy skipping elements works on later states. (org.eclipse.xtext.ui.editor.contentassist.AbstractContentProposalProvider.createProposals(ContentAssistContext, ICompletionProposalAcceptor))
or even later.
Re: Xtext Grammar - Exclusion of a specific Rule [message #1064796 is a reply to message #1064689] Fri, 21 June 2013 03:30 Go to previous message
You could write a separate rule for elements that can appear inside a
'Bold'. I would not recommend this, as the user would get an error from
the parser (unexpected token) instead of a helpful message (e.g. 'bold
not allowed within bold'). So rather be generous in the grammar and
cover these constraints with validation rules.
Am 20.06.13 16:47, schrieb Edwin Tuzar:
> and
> BinaryElements:
> Bold:
> (htmlaccelement+=HtmlAcceptedElement)+ is this possible? to say somehow
> Thanks in advance!
> Best regards,
Previous Topic:Performing automatic corrections
Next Topic:How to test global scoping / xtext index
Current Time: Sat Jul 26 10:55:14 EDT 2025
Powered by FUDForum. Page generated in 0.58334 seconds
