Home » Eclipse Projects » EclipseLink » entitymanager problem merge(merge() problem)
entitymanager problem merge [message #1064551] Wed, 19 June 2013 16:45 Go to next message
I have a problem with the entitymanager
times and need your help.
I just want to save time and merge two tables each time
the tables have 1to n relationship
my trouble at the entitymsnsger.merge (table1). tabellle1 which is updated. table2 but does not update
many thanks for your help
public void save(Object1 object1, List<Object2> object2List) {
// TODO Auto-generated method stub
try {
Tabelle1 tabelle1 = new Tabelle1();
tabelle1.setNummer(object1.getNnummer());
tabelle1.setName(object1.getName());
tabelle1.setLokal(object1.getLokal());
List<Tabelle2> tabelle2List= new ArrayList<Tabelle2>();
if (object2List!= null) {
for (Object2 Object2new : object2List) {
Tabelle2 tabelle2 = new Object2new ();
tabelle2.setNummer(jobCondidate.getNummer());
tabelle2.setName(jobCondidate.getName());
tabelle2.setNickname(jobCondidate.getNickname());
tabelle2.add(tabelle2new );
// add list von tabelle2 to tabelle1
tabelle1.setBewerbers(tabelle2);
try {
// Update tabelle1
Tabelle1 tabelle1new= entityManager.find(Tabelle1 .class, tabelle1.getNummer());
if (tabelle1new== null) {
// transaction type=JTA : container managed transaction
entityManager.persist(Tabelle1 );
} else {
entityManager.merge(Tabelle1 );
} catch (Exception e) {
e.getMessage();
} catch (ClassCastException e) {
System.out.println("Class Cast Exception");
e.printStackTrace();
} catch (IllegalArgumentException e) {
System.out.println("Illegal Argument Exception");
System.out.println("Generic Exception");
Re: entitymanager problem merge [message #1065394 is a reply to message #1064551] Tue, 25 June 2013 10:33 Go to previous message
Ensure you set cascade merge in your mapping.
Previous Topic:How to access Primary Key instance of entity relationship?
Next Topic:OPEN - Disable delete an entity when is its linked in relationships
Current Time: Wed Jul 23 14:03:57 EDT 2025
Powered by FUDForum. Page generated in 0.03869 seconds
