Home » Modeling » QVT-Relations » QVT expressivity
QVT expressivity [message #1064432] Wed, 19 June 2013 05:00 Go to next message
I wanted to ask some questions about the expressivity of QVT that seems to me to be a little bit limited compared to other M2M languages (I may be wrong):
1- In defining a domain, in QVT, it seems we can only select one object of one type (c: UML::Class) we cannot for example select all tuples (c1:UMLClass, c2:UMLClass) as a single domain. Of course we can declare two distinct domains for each element, but if we could make a first filtering on the (c1, c2) couples, we could reduce the number of candidate tuples for the rule. If we could write something like:
checkonly domain
source c1:UML::Class,
source c2:UML::Class:
when{
-- domain-level pre-condition
c1<>c2;
when{
-- relation-level pre-condition
2- All the examples from the QVT spec and from the MediniQVT tutorials use meta-models that are designed following a special pattern:
"the contained elements (for example classes) have a reference (myPackage) to the container (package)."
No example is given with a container that has a collection of references (non eOpposite) to its contained elements. How this is delt with in QVT?
Re: QVT expressivity [message #1064437 is a reply to message #1064432] Wed, 19 June 2013 05:16 Go to previous messageGo to next message
Hi Skander
IMHO you have hit on an area where the QVTr (and QVTc and QVTo)
specifications are at best vague. I think that an additional 'rooting'
condition needs to be available for specification by the invoking
context, and a much clearer semantics of collection matching is required.
I would tentatively expect that if you apply a transformation defined on
C=>D to a Collection(C) that the result will be a Collection(D).
In UMLX where I tried to support collection matching, you would specify
Collection(C)[2] as the input type so that the transformation would be
applied to all distinct permutations of two Cs.
I currently have student working on realizing a QVTr to qVTc to QVTu to
QVTm to QVTi to OCL to Java chain. I expect that the precision of
Collection matching is something that we get to in about a year's time.
Ed Willink
On 19/06/2013 11:00, Skander Turki wrote:
> (I may be wrong):
> checkonly domain source c1:UML::Class,
> when{
> c1<>c2;
> when{ -- relation-level pre-condition
> with in QVT?
> Thanks
Re: QVT expressivity [message #1064461 is a reply to message #1064437] Wed, 19 June 2013 07:59 Go to previous messageGo to next message
In fact, the QVT-R (chapter 7) in the spec in quite brief. I think it should be developed in a separate spec. I don't understand why these implementation issues are part of the spec (I mean the the compilation chain).
Do you know if another version of the spec is under development?
Re: QVT expressivity [message #1064471 is a reply to message #1064461] Wed, 19 June 2013 08:29 Go to previous messageGo to next message
Hi Skander
If you compare the QVT spec with the OCL spec it is immediately clear
how much is missing. If you study the OCL spec, it doesn't stand for
much close examination. These specifications are really hard to right.
The forthcoming UML 2.5 specification makes a major step forward with
the underlying models being normative and the resulting text (50%
autogenerated) being fairly consistent and only informative.
For OCL I am trying to get closer to 100% auto-generated and to reuse
the autogeneration technology for QVT. But don't expect to see a better
QVT specification for at least a couple of years.
Ed Willink
> chain).
Re: QVT expressivity [message #1064499 is a reply to message #1064471] Wed, 19 June 2013 10:01 Go to previous messageGo to next message
Thanks a lot. I know it's easier to criticize.
Re: QVT expressivity [message #1782560 is a reply to message #1064499] Mon, 26 February 2018 08:33 Go to previous messageGo to next message
I have the following relations:
    top relation ModelToSqlScript {
        checkonly domain dm dataModel : Model {
        enforce domain sql sqlScript : SQLScript {
        where {
            ClassToTableDefinition(dataModel, sqlScript);
    relation ClassToTableDefinition {
            classes = clazz : Clazz {
                model = owningModel : Model{},
                name = className : String{}
            statements = TableDefinition {
                name = ''+className
classes and statements are OrderedSets.
The transformation is failed with the exception:
java.lang.ClassCastException: org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to java.base/java.util.List
	at org.eclipse.emf.ecore.util.EcoreEList.set(EcoreEList.java:457)
	at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSettingDelegateMany.dynamicSet(EStructuralFeatureImpl.java:1744)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(BasicEObjectImpl.java:1127)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1101)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
	at org.eclipse.ocl.pivot.internal.PropertyImpl.initValue(PropertyImpl.java:1681)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.BasicQVTiExecutor.internalExecuteSetStatement(BasicQVTiExecutor.java:413)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.QVTiIncrementalExecutor.internalExecuteSetStatement(QVTiIncrementalExecutor.java:348)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.QVTiEvaluationVisitor.visitSetStatement(QVTiEvaluationVisitor.java:538)
	at org.eclipse.qvtd.pivot.qvtimperative.impl.SetStatementImpl.accept(SetStatementImpl.java:1074)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.BasicQVTiExecutor.internalExecuteMapping(BasicQVTiExecutor.java:324)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.QVTiEvaluationVisitor.visitMapping(QVTiEvaluationVisitor.java:412)
	at org.eclipse.qvtd.pivot.qvtimperative.impl.MappingImpl.accept(MappingImpl.java:506)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.BasicQVTiExecutor.internalExecuteMappingCall(BasicQVTiExecutor.java:310)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.QVTiIncrementalExecutor.internalExecuteInvocation(QVTiIncrementalExecutor.java:245)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.QVTiIncrementalExecutor.access$0(QVTiIncrementalExecutor.java:242)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.QVTiIncrementalExecutor$InterpretedInvocationConstructor.internalExecuteInvocation(QVTiIncrementalExecutor.java:92)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.QVTiIncrementalExecutor$InterpretedInvocationConstructor.access$0(QVTiIncrementalExecutor.java:91)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.QVTiIncrementalExecutor$InterpretedInvocation.execute(QVTiIncrementalExecutor.java:111)
	at org.eclipse.qvtd.runtime.internal.evaluation.AbstractIntervalInternal.flush(AbstractIntervalInternal.java:216)
	at org.eclipse.qvtd.runtime.internal.evaluation.AbstractInvocationManagerInternal.flush(AbstractInvocationManagerInternal.java:96)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.BasicQVTiExecutor.internalExecuteTransformation(BasicQVTiExecutor.java:448)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.QVTiEvaluationVisitor.visitImperativeTransformation(QVTiEvaluationVisitor.java:387)
	at org.eclipse.qvtd.pivot.qvtimperative.impl.ImperativeTransformationImpl.accept(ImperativeTransformationImpl.java:167)
	at org.eclipse.ocl.pivot.internal.evaluation.AbstractEvaluationVisitor.visit(AbstractEvaluationVisitor.java:290)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.BasicQVTiExecutor.executeInternal(BasicQVTiExecutor.java:179)
	at org.eclipse.qvtd.pivot.qvtimperative.evaluation.BasicQVTiExecutor.execute(BasicQVTiExecutor.java:175)
	at org.eclipse.qvtd.debug.launching.QVTiLaunchConfigurationDelegate$1.run(QVTiLaunchConfigurationDelegate.java:113)
	at org.eclipse.ocl.examples.debug.vm.utils.SafeRunner$SameThreadRunner.run(SafeRunner.java:31)
	at org.eclipse.ocl.examples.debug.vm.utils.SafeRunner$1.run(SafeRunner.java:24)
	at org.eclipse.ocl.examples.debug.vm.utils.ShallowProcess.run(ShallowProcess.java:40)
	at org.eclipse.ocl.examples.debug.vm.utils.ShallowProcess.run(ShallowProcess.java:31)
	at org.eclipse.qvtd.debug.launching.QVTiLaunchConfigurationDelegate$3.run(QVTiLaunchConfigurationDelegate.java:158)
	at java.base/java.lang.Thread.run(Thread.java:844)
I have no idea how to describe collection relations...
Re: QVT expressivity [message #1782561 is a reply to message #1782560] Mon, 26 February 2018 08:43 Go to previous messageGo to next message
Here is an alternative relations:
            classes = classList : OrderedSet{}
            statements = classList
        checkonly domain dm clazz : Clazz {
        enforce domain sql td : TableDefinition {
            name = ''+className
But they raise the following exception:
Incompatible types OrderedSet(dm::Clazz)*1, OrderedSet(sql::DirectSQLStatement)*1 for sqlScript.statements := classList
DirectSQLStatement is a superclass of TableDefinition.
How to call ClassToTableDefinition explicitly?
Re: QVT expressivity [message #1782563 is a reply to message #1782560] Mon, 26 February 2018 08:51 Go to previous messageGo to next message
The QVT specification is fairly thin for Collections with RelToCore suffering major omissions. Eclipse QVTd is therefore prototyping the missing language design.
For an imperative transformation, the typical way of working is:
- transform each parent
- while transforming a parent transform its children
A parent transformation therefore pulls all child transformation results.
In contrast a declarative transformation works more independently
- transform each child
- while transforming a child set its transformed parent
A child transformation therefore pokes its result on the parent.
The QVT specification, and I suspect other languages, ignore the ordering of Collections.
An imperative transformation is likely to preserve ordering. A declarative transformation exploiting a multiprocessor will not naturally respect ordering.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=490172 and https://bugs.eclipse.org/bugs/show_bug.cgi?id=525710 outline some of my thoughts on how to re-instate ordering for a QVTr transformation.
Ed Willink
Re: QVT expressivity [message #1782566 is a reply to message #1782563] Mon, 26 February 2018 09:19 Go to previous messageGo to next message
Thanks for answer!
My target metamodel is auto-generated from an Xtext-grammar. So it lacks parent (owner) references.
Is it possible to use QVTd with such models now? And will it possible in future? Or I have to define parent references?
Actually I don't need to preserve exact order of a target collection's elements. I think that ordering by name, id or some other property is a good option too, in some use cases.
Is forAll operation supported now? I don't understand how to use it.
Re: QVT expressivity [message #1782570 is a reply to message #1782566] Mon, 26 February 2018 10:05 Go to previous messageGo to next message
QVT extends OCL so all opposites are always defined albeit implicitly. See http://www.eclipse.org/modeling/mdt/ocl/docs/publications/OCL2016Opposites/Opposites.pdf
In any QVTr you should be able to reference the opposite of parent.children as aChild.Parent.
In Eclipse QVTd the qualified navigation syntax is also supported so, IIRC, you can also do aChild.children[Parent]
You seem to be trying to use ATL syntax.
For simple unidirectional transformations, ATL is perhaps 25% more compact than QVTr lexically since it doesn't have the multi-directional when/where overhead. Instead it has the generally implicit resolveTemp to magically convert. resolveTemp, a horrible name, is great when it works, but confusing when it doesn't and then hard to use. For simple transformations ATL and QVTr are rather similar except that QVTr requires that all resolveTemp's are explicit when/where clauses.
ATL cannot handle arbitrarily complex transformations that require multiple passesdeclarativelt, e.g. pass1 constructTree, pass2 resolveReferences. A manual exposition as two passes and a non-declarative step to sequence the passes. QVTr can since it defines the final truth; how to get there is just an implementation problem, which for Eclipse QVTd involves local and global dependency analyses and partitioning relations into micro-mappings to synthesize the multiple passes automatically. This is demonstrated by the ATL2QVTr transformation that is work in progress.
Your earlier problem is soluble today by the declarative poke (syntax unchecked):
relation child2child {
domain left leftChild : Child { parent = leftParent; };
domain right rightChild : Child { parent = rightParent; };
when { parent2parent(leftParent, rightParent); }
After thinking about it, the imperative pull could be supported by:
relation parent2parent {
domain left leftParent: Parent{ children = leftChildren; };
domain right rightParent: Parent{ children = rightChildren; };
where { child2child(leftChildren, rightChildren); } -- this is not valid for QVT 1.3
It just requires the declared relation child2child(L,R) to be automatically available for an element-wise iteration of child2child(Collection(L),Collection(R)).
If you scan RelToCore in the QVT spec, you will find a couple of relations that iterate over child2child(L,R) within a children2children(Collection(L),Collection(R)). Clearly this could be a first class language capability. But it needs some careful thought to avoid unpleasant ambiguities when user collections are needed.
NB "where" is a dreadful keyword. It should be "then".
Ed Willink
Re: QVT expressivity [message #1782586 is a reply to message #1782570] Mon, 26 February 2018 12:24 Go to previous messageGo to next message
RelToCore contains a lot of interesting examples. Especially ++ operator. I need time to examine it.
I'm trying to implement a minimal working example. Here is a test model:
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="model1">
  <eClassifiers xsi:type="ecore:EClass" name="cls1">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="attr11"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="attr12"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="cls2">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="attr21"/>
  </eClassifiers>
</ecore:EPackage>
Here is my first attempt:
import ECORE : 'http://www.eclipse.org/emf/2002/Ecore';
transformation Test(left:ECORE, right:ECORE)
    top relation ClassToClass {
        checkonly domain left lclass : EClass {
        enforce domain right rclass : EClass {
            name = className+'Copy'
    top relation AttributeToAttribute {
        lparent : ECORE::EClass;
        rparent : ECORE::EClass;
        checkonly domain left lattr : EAttribute {
--            eContainingClass is not changeable
--            eContainingClass = lparent,
            eAttributes[EClass] = lparent,
            name = attrName : String{}
        enforce domain right rattr : EAttribute {
--            eContainingClass = rparent,
            eAttributes[EClass] = rparent,
            name = attrName+'Copy'
        when {
            ClassToClass(lparent, rparent);
EAttribute's eContainingClass is unsettable. So I try to refer to an owning class using eAttributes[EClass], and I get a syntax error. It seems that square brackes are not supported.
When I refer to an owning class using EClass I get the following error:
Ambiguous resolution:
	Property : ecore::EStructuralFeature::EClass # ecore::EClass::eAllStructuralFeatures
	Property : ecore::EAttribute::EClass # ecore::EClass::eAttributes
	Property : ecore::EAttribute::EClass # ecore::EClass::eAllAttributes
	Property : ecore::EAttribute::EClass # ecore::EClass::eIDAttribute
Here is my second attempt:
        attrList : OrderedSet(ECORE::EAttribute);
        attrList2 : OrderedSet(ECORE::EAttribute);
            name = className : String{},
            eStructuralFeatures = attrList
            name = className+'Copy',
            eStructuralFeatures = attrList2
        where {
            AttributeToAttribute(attrList, attrList2);
But it raise the following exception:
java.lang.UnsupportedOperationException
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.AbstractScheduleManager.addRegionError(AbstractScheduleManager.java:136)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.MappingAnalysis.getReferenceNode(MappingAnalysis.java:655)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.ExpressionAnalyzer.visitVariableExp(ExpressionAnalyzer.java:1020)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.ExpressionAnalyzer.visitVariableExp(ExpressionAnalyzer.java:1)
	at org.eclipse.ocl.pivot.internal.VariableExpImpl.accept(VariableExpImpl.java:440)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.ExpressionAnalyzer.analyze(ExpressionAnalyzer.java:115)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.MappingAnalysis$QVTcoreExpressionAnalyzer.visitNavigationAssignment(MappingAnalysis.java:164)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.MappingAnalysis$QVTcoreExpressionAnalyzer.visitPropertyAssignment(MappingAnalysis.java:189)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.MappingAnalysis$AbstractQVTcoreExpressionAnalyzer.visitPropertyAssignment(MappingAnalysis.java:1)
	at org.eclipse.qvtd.pivot.qvtcore.impl.PropertyAssignmentImpl.accept(PropertyAssignmentImpl.java:599)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.MappingAnalysis.analyzeAssignmentValues(MappingAnalysis.java:320)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.MappingAnalysis.analyze(MappingAnalysis.java:302)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.TransformationAnalysis.analyze(TransformationAnalysis.java:71)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.AbstractScheduleManager.analyzeTransformation(AbstractScheduleManager.java:212)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.QVTcoreScheduleManager.analyzeTransformation(QVTcoreScheduleManager.java:37)
	at org.eclipse.qvtd.compiler.internal.qvtm2qvts.AbstractScheduleManager.analyzeTransformations(AbstractScheduleManager.java:219)
	at org.eclipse.qvtd.compiler.AbstractCompilerChain$QVTm2QVTsCompilerStep.execute(AbstractCompilerChain.java:232)
	at org.eclipse.qvtd.compiler.AbstractCompilerChain.qvtm2qvti(AbstractCompilerChain.java:568)
	at org.eclipse.qvtd.compiler.QVTrCompilerChain.compileQVTrAS(QVTrCompilerChain.java:214)
	at org.eclipse.qvtd.compiler.QVTrCompilerChain.compile(QVTrCompilerChain.java:204)
	at org.eclipse.qvtd.debug.launching.QVTrLaunchConfigurationDelegate.buildForLaunch(QVTrLaunchConfigurationDelegate.java:78)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:917)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:801)
	at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
	at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:60)
I'm using QVTd 0.15.0.v20180131-0705
Re: QVT expressivity [message #1782624 is a reply to message #1782586] Tue, 27 February 2018 04:17 Go to previous messageGo to next message
Your first attempt seems to avoid the simple solution: eContainingClass = lparent
An explicit eContainingClass exists so you do not need to use an opposite syntax.
(My earlier "IIRC, you can also do aChild.children[Parent]" comment was not correct. If aChild.Parent is ambiguous you may disambiguate it by using aChild.Parent[children].)
Your second attempt uses the multi-where that I commented earlier is not valid in QVTr, although I see increasing utility for it.
I trust that you are aware the Eclipse QVTd is currently version 0.15 with very few users. You are demonstrating how much work is needed to make it user friendly.
Ed Willink
Re: QVT expressivity [message #1782630 is a reply to message #1782624] Tue, 27 February 2018 04:48 Go to previous message
I can't use eContainingClass, because it's marked changeable="false" in Ecore metamodel. So I get the following exception:
java.lang.IllegalArgumentException: The feature 'eContainingClass' is not a valid changeable feature
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eOpenSet(BasicEObjectImpl.java:1141)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(BasicEObjectImpl.java:1119)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(BasicEObjectImpl.java:1112)
	at org.eclipse.emf.ecore.impl.EAttributeImpl.eSet(EAttributeImpl.java:327)
The following transformation doesn't work. I get the syntax error:
Multiple markers at this line
- mismatched input '[' expecting '='
- mismatched input 'eAttributes' expecting '}'
            EClass[eAttributes] = lparent,
            EClass[eAttributes] = rparent,
        when {
Previous Topic:Announce QVTd 0.14.0
Next Topic:Measuring execution time and memory usage of QVTD transformation
Current Time: Thu Jul 24 22:36:25 EDT 2025
Powered by FUDForum. Page generated in 1.10323 seconds
