Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] How to know attributes of an object in order to make update/insert requests?(Json WS )
[Texo] How to know attributes of an object in order to make update/insert requests? [message #1063808] Fri, 14 June 2013 06:51 Go to next message
I'm thinking of the following usage scenario (based on the standard Library Example):
1. User sees a webpage where e.g. all 'Books' are displayed
--> At the beginning there may be none
2. User clicks on a Button "Add Book", now I have to know what attributes and or references there are that a Book can possibly have so I can display UI for the user to insert all these features.
How would I get this kind of information?
Re: [Texo] How to know attributes of an object in order to make update/insert requests? [message #1063930 is a reply to message #1063808] Sun, 16 June 2013 03:01 Go to previous messageGo to next message
Hi Micha,
So you can render the UI dynamically on the client you mean?
Currently there is no webservice to get model information. But I think it really makes sense to also have this.
Can you enter a bugzilla for it?
gr. Martin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] How to know attributes of an object in order to make update/insert requests? [message #1064004 is a reply to message #1063930] Mon, 17 June 2013 04:54 Go to previous messageGo to next message
Hello Martin,
thanks for the reply, I added a Bugzilla. This is helpful if you want to make an HTML UI independently from your texo project. For example solely client based with javascript or another server project that is independent from the Texo project. Or is there a way to achieve this already?
Micha
Re: [Texo] How to know attributes of an object in order to make update/insert requests? [message #1064279 is a reply to message #1064004] Tue, 18 June 2013 10:16 Go to previous message
Hi Micha,
No other way at the moment I am afraid...
gr. Martin
On 06/17/2013 10:54 AM, Micha-Jamie Guthmann wrote:
> Hello Martin,
> Best regards,
> Micha
The Netherlands
Previous Topic:[EMF Store] A resource lock?
Next Topic:Using EObjectStore to select column values
Current Time: Sat Jul 26 08:12:07 EDT 2025
Powered by FUDForum. Page generated in 0.08184 seconds
