Home » Modeling » EMF » [Teneo] idBag ID generator(configurable ID generator for idBag)
[Teneo] idBag ID generator [message #1063911] Sat, 15 June 2013 01:31 Go to next message
Can the ID generator for idBag be made configurable?
I am using Teneo 1.2.0.v201202122052.
I want to change the ID generator for idBag to sequence. If I run 2 JVMs, and they write to the same collection in parallel, we get a unique constraint violation exception.
I looked at AbstractAssociationMapper in method
	protected Element addCollectionElement
The generator is hard coded to increment.
if (idBag != null) {
			final String generator = (idBag.getGenerator() == null ? "increment"
					: idBag.getGenerator());
			final String type = (idBag.getType() == null ? "long" : idBag
					.getType());
			// if (false && idBag.getTable() != null) {
			// collectionElement.addAttribute("table", idBag.getTable());
			final Element collectionIdElement = collectionElement
					.addElement("collection-id");
			collectionIdElement.addAttribute("column",
					hbmContext.getIdbagIDColumnName());
			collectionIdElement.addAttribute("type", type);
			collectionIdElement.addElement("generator").addAttribute("class",
					generator);
Re: [Teneo] idBag ID generator [message #1063929 is a reply to message #1063911] Sun, 16 June 2013 02:52 Go to previous messageGo to next message
Hi R Deepak,
Afaik the Idbag annotation has a generator attribute which can be use to set the generator, have you tried that?
gr. Martin
> .getType());
> generator);
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] idBag ID generator [message #1064172 is a reply to message #1063929] Tue, 18 June 2013 01:18 Go to previous messageGo to next message
Hi Martin
Martin Taal wrote on Sun, 16 June 2013 02:52
Hi R Deepak,
The model I am using is too big and complex. So, I have not tuned individual collections. May not be a viable option for me..
I have used the global option
teneo.mapping.map_all_lists_as_idbag
Will it work if I modify AbstractAssociationMapper and change increment to sequence?
Deepak
Re: [Teneo] idBag ID generator [message #1064247 is a reply to message #1064172] Tue, 18 June 2013 07:57 Go to previous messageGo to next message
Hi Deepak,
You can not override the abstract class but you can override one of its subclasses and override specific methods. Check
out the source code. Then you can tell Teneo to use your class with this mechanism:
http://wiki.eclipse.org/Teneo/Hibernate/Extensions
gr. Martin
On 06/18/2013 07:18 AM, R Deepak wrote:
> Hi Martin
>> Hi R Deepak,
> me..
> Thanks
> Deepak
The Netherlands
Re: [Teneo] idBag ID generator [message #1064249 is a reply to message #1064247] Tue, 18 June 2013 08:06 Go to previous messageGo to next message
Martin Taal wrote on Tue, 18 June 2013 07:57
Hi Deepak,
The subclasses calling the method "addCollectionElement" include:
ManyAttributeMapper
ManyExternalReferenceMapper
ManyToManyMapper
OneToManyMapper
TypedEReferenceMapper
Should I override all these and replace it using extensionManager.registerExtension()?
Re: [Teneo] idBag ID generator [message #1064275 is a reply to message #1064249] Tue, 18 June 2013 10:15 Go to previous messageGo to next message
Hi Deepak,
Probably only the ManyToMany and OneToMany as only these one use the idbag.
gr. Martin
>> Hi Deepak,
>> Check out the source code. Then you can tell Teneo to use your class with this mechanism:
> ManyAttributeMapper
> ManyToManyMapper
> OneToManyMapper
The Netherlands
Re: [Teneo] idBag ID generator [message #1064384 is a reply to message #1064275] Wed, 19 June 2013 00:41 Go to previous message
It works..
Thanks Martin.
Previous Topic:JSON Resources from EMF ?
Next Topic:[EMF/GMF] - Performance issue on load and save model.
Current Time: Wed Jul 23 08:48:51 EDT 2025
Powered by FUDForum. Page generated in 0.08603 seconds
