Home » Modeling » TMF (Xtext) » Xtext runtime tries to access internet at application startup(Xtext runtime tries to access internet at application startup)
Xtext runtime tries to access internet at application startup [message #1064227] Tue, 18 June 2013 06:37 Go to next message
Dear colleagues,
in our Xtext grammar we 'import "http://www.eclipse.org/emf/2002/Ecore" as ecore'.
Now we detected that - at startup - the Xtext runtime tries to access exactly that address. The platform for our application however has no internet access.
Is there a way to disable internet access of the Xtext runtime?
kind regards
Franz-Josef
Re: Xtext runtime tries to access internet at application startup [message #1064303 is a reply to message #1064227] Tue, 18 June 2013 11:01 Go to previous messageGo to next message
That should not be the case, when the EcorePackage is correctly
registered. Could you file a bug with a stacktrace and maybe a
reproducible example?
Am 18.06.13 12:37, schrieb FJ Stöver:
> Dear colleagues,
> as ecore'.
> internet access.
> kind regards
> Franz-Josef
Re: Xtext runtime tries to access internet at application startup [message #1064431 is a reply to message #1064303] Wed, 19 June 2013 04:52 Go to previous messageGo to next message
Good morning Jan,
Thank you for your prompt reply.
registered.
For registration we use the generated code in BaseStandaloneSetupGenerated.java:
 if (!Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().containsKey("ecore"))
 Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(
 "ecore", new org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl());
That seemed to be ok, and we tried to replace in the grammar
by
import "platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore"
which gave the warning "Fix the bogus package import; import 'http://www.eclipse.org/emf/2002/Ecore'".
When compiling the grammar however it gave the error "Couldn't resolve reference to EPackage 'platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore' ..."
Any idea how to go the 'import from platform' approach ?
Whatever: If the 'import from platform' approach is not successful, or the problem persists, then the next well probably be to produce a repro.
kind regards Franz-Josef
Re: Xtext runtime tries to access internet at application startup [message #1064435 is a reply to message #1064431] Wed, 19 June 2013 05:08 Go to previous messageGo to next message
Please note that we are running our Xtext applications not from an OSGI container, but rather standalone or hosted by jBoss.
Franz-Josef
Re: Xtext runtime tries to access internet at application startup [message #1064503 is a reply to message #1064431] Wed, 19 June 2013 10:16 Go to previous messageGo to next message
That's the registration of the ResourceFactory, but I mean the
registration of the EcorePackage. It should happen automatically as soon
as you access the EcorePackage.eINSTANCE, but you can of course do it
explicitly:
org.eclipse.emf.ecore.impl.EcorePackageImpl.init()
Am 19.06.13 10:52, schrieb FJ Stöver:
> Good morning Jan,
> registered.
> if
> by
Re: Xtext runtime tries to access internet at application startup [message #1064504 is a reply to message #1064435] Wed, 19 June 2013 10:26 Go to previous messageGo to next message
The http: import should give no trouble provided you register the Ecore
package, which happens automatically if you just touch the EcorePackage
class by accessing EcorePackage.eINSTANCE.
For your own models you may need to use platform:/resource which Xtext
no longer likes but at least continues to tolerate. For instance one of
my grammars has:
import
"platform:/resource/org.eclipse.ocl.examples.xtext.base/model/BaseCST.ecore"
as base
import
"platform:/resource/org.eclipse.ocl.examples.xtext.essentialocl/model/EssentialOCLCST.ecore"
as essentialocl
import
"platform:/resource/org.eclipse.ocl.examples.pivot/model/Pivot.ecore" as
pivot
import
"platform:/resource/org.eclipse.qvtd.pivot.qvtbase/model/QVTbase.ecore"
as qvtbase
import
"platform:/resource/org.eclipse.qvtd.pivot.qvtcorebase/model/QVTcoreBase.ecore"
as qvtcorebase
import
"platform:/resource/org.eclipse.qvtd.pivot.qvtcore/model/QVTcore.ecore"
as qvtcore
import
"platform:/resource/org.eclipse.qvtd.xtext.qvtcore/model/QVTcoreCST.ecore"
Ed Willink
> Franz-Josef
Re: Xtext runtime tries to access internet at application startup [message #1064584 is a reply to message #1064503] Thu, 20 June 2013 02:30 Go to previous messageGo to next message
Jan,
A better idiom for forcing package initialization is
XyzPackage.eINSTANCE.eClass(); it's better to write code that assumes
the generated Impls are private.
> soon as you access the EcorePackage.eINSTANCE, but you can of course
> do it explicitly:
>> Good morning Jan,
>> registered.
>> if
>> by
Re: Xtext runtime tries to access internet at application startup [message #1064619 is a reply to message #1064584] Thu, 20 June 2013 05:14 Go to previous messageGo to next message
In terms of readability, my solution feels a bit more explicit. Yours
would definitively need a comment that you are just doing it for a
magical side-effect in order not to be removed in the next refactoring.
I'd prefer an even more explicit statement (involving the
EPackage.Registry), but then we are likely introducing some obsolete
action.
Am 20.06.13 08:30, schrieb Ed Merks:
> Jan,
>> do it explicitly:
>>> Good morning Jan,
>>> registered.
>>> if
>>> by
Re: Xtext runtime tries to access internet at application startup [message #1064632 is a reply to message #1064619] Thu, 20 June 2013 06:43 Go to previous messageGo to next message
Dear colleagues !
Thank you for the valuable comments; I'll do my best to integrate it into our software.
Meanwhile we have found out more:
* If we have one Xtext parser instance everything works fine, and we observe no internet traffic. So I assume that package registration seems to be ok - though I'll look into your suggestions to improve the software.
* If we have two Xtext parser instances then we observe Internet traffic ! Seems like they influence each other. We looked for static fields in our source, and in the Xtext generated sources, but didn't find anything.
Any ideas ?
kind regards
Franz-Josef
Re: Xtext runtime tries to access internet at application startup [message #1064633 is a reply to message #1064619] Thu, 20 June 2013 06:41 Go to previous messageGo to next message
Jan,
EPackage.Registry.INSTANCE.getEPackage(XyzPackage.eNS_URI) works too.
Accessing model implementation classes shouldn't be encouraged...
> refactoring. I'd prefer an even more explicit statement (involving the
> action.
>> Jan,
>>> do it explicitly:
>>>> Good morning Jan,
>>>> registered.
>>>> if
>>>> "ecore", new
>>>> by
>>>> repro.
Re: Xtext runtime tries to access internet at application startup [message #1064635 is a reply to message #1064632] Thu, 20 June 2013 06:56 Go to previous message
Maybe a breakpoint in
org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URI, Map<?,
?>) would help track it down.
On 20/06/2013 12:43 PM, FJ Stöver wrote:
> Dear colleagues !
> into our software.
> software.
> find anything.
> Any ideas ?
> kind regards
> Franz-Josef
Previous Topic:Accessing global constant data
Next Topic:After linking|Scoping but before Generator and second language
Current Time: Fri Jul 25 06:58:13 EDT 2025
Powered by FUDForum. Page generated in 0.15540 seconds
