Applying Stereotype to model element [message #1062597] |
Sun, 09 June 2013 12:34  |
I am facing a strange behavior of QVT-O when executing a transformation.
In this in-place transformation, I want to apply a stereotype to a model element. If I run the transformation in the debug-mode, the stereotype is applied correctly. If I run the transformation in the normal-mode, it seems as if the stereotype is applied correctly, but actually in the resulting uml model it is not applied.
Is there any reason for this behavior ?
Unfortunately, I am not allowed to attach files, so I will post the transformation, the profile, and the input-model in the following.
If you need further information please let me know.
Thank you in advance for your help.
The qvt-o transformation:
modeltype UML uses 'XXXX://www.eclipse.org/uml2/4.0.0/UML';
transformation PostProcessingTransformation(inout model:UML);
main() {
model.objects()[Comment]-> map transformComment();
mapping Comment::transformComment(){
self.getApplicableStereotypes() -> forEach(stereotype){
self.applyStereotype(stereotype);
The uml profile:
<uml:Profile xmi:version="20110701" xmlns:xmi="XXXX://www.omg.org/spec/XMI/20110701" xmlns:ecore="XXX://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML" xmi:id="_gQJ_YNDsEeKkjoP3cZvJTg" name="Profile" metaclassReference="_k3_GINDsEeKkjoP3cZvJTg" metamodelReference="_gQJ_YdDsEeKkjoP3cZvJTg">
<eAnnotations xmi:id="_p2IbINDsEeKkjoP3cZvJTg" source="http://www.eclipse.org/uml2/2.0.0/UML">
<contents xmi:type="ecore:EPackage" xmi:id="_p2IbIdDsEeKkjoP3cZvJTg" name="Profile" nsURI="XXXX:///schemas/Profile/_p2Gl8NDsEeKkjoP3cZvJTg/0" nsPrefix="Profile">
<eAnnotations xmi:id="_p2KQUNDsEeKkjoP3cZvJTg" source="PapyrusVersion">
<details xmi:id="_p2KQUdDsEeKkjoP3cZvJTg" key="Version" value="0.0.1"/>
<details xmi:id="_p2KQUtDsEeKkjoP3cZvJTg" key="Comment" value=""/>
<details xmi:id="_p2KQU9DsEeKkjoP3cZvJTg" key="Copyright" value=""/>
<details xmi:id="_p2KQVNDsEeKkjoP3cZvJTg" key="Date" value="2013-06-09"/>
<details xmi:id="_p2KQVdDsEeKkjoP3cZvJTg" key="Author" value="Thorsten Koch"/>
</eAnnotations>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_p2IbItDsEeKkjoP3cZvJTg" name="Stereotype1">
<eAnnotations xmi:id="_p2IbI9DsEeKkjoP3cZvJTg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_lUHogNDsEeKkjoP3cZvJTg"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_p2IbJNDsEeKkjoP3cZvJTg" name="base_Comment" ordered="false" lowerBound="1">
<eType xmi:type="ecore:EClass" href="http://www.eclipse.org/uml2/4.0.0/UML#//Comment"/>
</eStructuralFeatures>
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_p2IbJtDsEeKkjoP3cZvJTg" name="Stereotype2">
<eAnnotations xmi:id="_p2IbJ9DsEeKkjoP3cZvJTg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_mTbJYNDsEeKkjoP3cZvJTg"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_p2IbKNDsEeKkjoP3cZvJTg" name="base_Comment" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_p2IbKtDsEeKkjoP3cZvJTg" name="Stereotype3">
<eAnnotations xmi:id="_p2IbK9DsEeKkjoP3cZvJTg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_nBUxMNDsEeKkjoP3cZvJTg"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_p2IbLNDsEeKkjoP3cZvJTg" name="base_Comment" ordered="false" lowerBound="1">
</eClassifiers>
</contents>
</eAnnotations>
<elementImport xmi:id="_k3_GINDsEeKkjoP3cZvJTg" alias="Comment">
<importedElement xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Comment"/>
</elementImport>
<packageImport xmi:id="_gQJ_YdDsEeKkjoP3cZvJTg">
<importedPackage xmi:type="uml:Model" href="pathmap://UML_METAMODELS/UML.metamodel.uml#_0"/>
</packageImport>
<packageImport xmi:id="_gQJ_YtDsEeKkjoP3cZvJTg">
<importedPackage xmi:type="uml:Model" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_lUHogNDsEeKkjoP3cZvJTg" name="Stereotype1">
<ownedAttribute xmi:id="_n3aEoNDsEeKkjoP3cZvJTg" name="base_Comment" association="_n3arsNDsEeKkjoP3cZvJTg">
<type xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Comment"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_mTbJYNDsEeKkjoP3cZvJTg" name="Stereotype2">
<ownedAttribute xmi:id="_ol_o8NDsEeKkjoP3cZvJTg" name="base_Comment" association="_ol_o8dDsEeKkjoP3cZvJTg">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_nBUxMNDsEeKkjoP3cZvJTg" name="Stereotype3">
<ownedAttribute xmi:id="_oRdjYNDsEeKkjoP3cZvJTg" name="base_Comment" association="_oReKcNDsEeKkjoP3cZvJTg">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_n3arsNDsEeKkjoP3cZvJTg" name="E_Stereotype1_Comment1" memberEnd="_n3arsdDsEeKkjoP3cZvJTg _n3aEoNDsEeKkjoP3cZvJTg">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_n3arsdDsEeKkjoP3cZvJTg" name="extension_Stereotype1" type="_lUHogNDsEeKkjoP3cZvJTg" aggregation="composite" association="_n3arsNDsEeKkjoP3cZvJTg"/>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_oReKcNDsEeKkjoP3cZvJTg" name="E_Stereotype3_Comment1" memberEnd="_oReKcdDsEeKkjoP3cZvJTg _oRdjYNDsEeKkjoP3cZvJTg">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_oReKcdDsEeKkjoP3cZvJTg" name="extension_Stereotype3" type="_nBUxMNDsEeKkjoP3cZvJTg" aggregation="composite" association="_oReKcNDsEeKkjoP3cZvJTg"/>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_ol_o8dDsEeKkjoP3cZvJTg" name="E_Stereotype2_Comment1" memberEnd="_ol_o8tDsEeKkjoP3cZvJTg _ol_o8NDsEeKkjoP3cZvJTg">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_ol_o8tDsEeKkjoP3cZvJTg" name="extension_Stereotype2" type="_mTbJYNDsEeKkjoP3cZvJTg" aggregation="composite" association="_ol_o8dDsEeKkjoP3cZvJTg"/>
</packagedElement>
</uml:Profile>
The input model
<uml:Model xmi:version="20110701" xmlns:xmi="XXXX://www.omg.org/spec/XMI/20110701" xmlns:ecore="XXXX://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML" xmi:id="_daUAkNEhEeKkjoP3cZvJTg" name="Model">
<packagedElement xmi:type="uml:Package" xmi:id="_daUAkdEhEeKkjoP3cZvJTg" name="Interaction1">
<ownedComment xmi:id="_daUAktEhEeKkjoP3cZvJTg">
<body>Stereotype3;</body>
</ownedComment>
<ownedComment xmi:id="_daUAk9EhEeKkjoP3cZvJTg">
<body>Stereotype1;</body>
</ownedComment>
<packagedElement xmi:type="uml:Class" xmi:id="_daUAlNEhEeKkjoP3cZvJTg" name="Lifeline"/>
<packagedElement xmi:type="uml:Class" xmi:id="_daUAldEhEeKkjoP3cZvJTg" name="Lifeline2"/>
<packagedElement xmi:type="uml:Class" xmi:id="_daUAltEhEeKkjoP3cZvJTg" name="Lifeline1"/>
<packagedElement xmi:type="uml:Class" xmi:id="_daUAl9EhEeKkjoP3cZvJTg" name="Lifeline0"/>
<profileApplication xmi:id="_daUAmNEhEeKkjoP3cZvJTg">
<eAnnotations xmi:id="_daUAmdEhEeKkjoP3cZvJTg" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href="../profile/model.profile.uml#_p2IbIdDsEeKkjoP3cZvJTg"/>
</eAnnotations>
<appliedProfile href="../profile/model.profile.uml#_gQJ_YNDsEeKkjoP3cZvJTg"/>
</profileApplication>
</packagedElement>
</uml:Model>
[Updated on: Mon, 10 June 2013 09:02] by Moderator
Re: Applying Stereotype to model element [message #1062943 is a reply to message #1062597] |
Tue, 11 June 2013 09:48   |
I continued testing and found another inconsistency between the run and the debug mode regarding the application of stereotypes.
I used the following transformation:
modeltype UML uses uml('http://www.eclipse.org/uml2/4.0.0/UML');
transformation NewTransformation1(in SysMLProfile : UML, out model : UML);
main() {
var prof : Profile := SysMLProfile.objectsOfType(Profile)![name = "PortAndFlows"];
var stereo : Stereotype = SysMLProfile.objectsOfType(Stereotype)![name = "FlowPort"];
assert fatal (prof = stereo.profile);
var model : Model := object Model {name := 'model'};
var cls : Class := object Class {name := 'class'};
model.ownedType += cls;
var prop : Property := object Port {name := 'prop'};
cls.ownedAttribute += prop;
model.applyProfile(stereo.profile);
prop.getApplicableStereotypes()-> forEach(stereotype){
log("applicable stereotype:", stereotype.name);
prop.applyStereotype(stereo);
prop.getAppliedStereotypes()-> forEach(stereotype){
log("applied stereotype:", stereotype.name);
If I run this transformation run in the debug mode, I get the following logging output:
applicable stereotype:, data: FlowProperty
applicable stereotype:, data: FlowPort
Diagnostic OK source=org.eclipse.m2m.qvt.oml.execution code=0 OK data=[]
[QVTO Stack trace:]
And if the run it in the normal mode, I get the following logging output:
applied stereotype:, data: FlowPort
As the logging output indicates, the stereotype is applied only once.
Re: Applying Stereotype to model element [message #1062974 is a reply to message #1062943] |
Tue, 11 June 2013 10:57   |
Please raise a Bugzilla.
Ed Willink
> UML);
> main() {
> "PortAndFlows"];
> [QVTO Stack trace:]
FUDForum. Page generated in 6.66274 seconds
