ASTParser setEnvironment classpath problems [message #1064051] |
Mon, 17 June 2013 08:40  |
Hello everyone.
I readed blogs and tutorials to activate bindings on the JDT AST tree with "external" project (not eclipse plugin). But I have some difficulties with the classpath when passing the setEnvironment to the parser.
This is the simple class that I want to parse:
import org.apache.log4j.Logger;
public class LogTest {
private static Logger LOG = Logger.getLogger(LogTest.class);
But when I parse this code with ASTParser, I have those compilations problems:
Pb(390) The import org.apache cannot be resolved
Pb(2) Logger cannot be resolved to a type
Pb(50) Logger cannot be resolved
So, by those errors, the log4j jar library was not found by the compiler.
Here the method I used to load/parse the AST tree:
public static void testJDTParser() {
String javaFile = "C:\\workspace\\BasicProjet\\src\\LogTest.java";
ASTParser parser = ASTParser.newParser(AST.JLS4);
parser.setKind(ASTParser.K_COMPILATION_UNIT);
char[] content = ... //LOADING FILE javaFile INTO CHAR[].
parser.setSource(content);
@SuppressWarnings("unchecked")
Map<String, String> options = JavaCore.getOptions();
options.put(JavaCore.COMPILER_COMPLIANCE, JavaCore.VERSION_1_6);
options.put(JavaCore.COMPILER_CODEGEN_TARGET_PLATFORM,
options.put(JavaCore.COMPILER_SOURCE, JavaCore.VERSION_1_6);
String unitName = "BasicProjet/LogTest.java";
parser.setUnitName(unitName);
String[] sources = { "C:\\workspace\\BasicProjet" };
String[] classPaths = { "C:\\workspace\\BasicProjet\\lib" };
parser.setEnvironment(classPaths, sources,
new String[] { "UTF-8" }, true);
parser.setBindingsRecovery(true);
parser.setResolveBindings(true);
parser.setCompilerOptions(options);
parser.setStatementsRecovery(true);
CompilationUnit result = (CompilationUnit) parser.createAST(null);
IProblem[] problems = result.getProblems();
for (IProblem problem : problems) {
LOG.debug(problem.toString());
if (result.getAST().hasBindingsRecovery()) {
LOG.warn("Binding activated.");
//Get the "LOG" field of the class LogTest parsed.
TypeDeclaration typeDeclaration =
(TypeDeclaration)result.types().get(0);
FieldDeclaration field = typeDeclaration.getFields()[0];
ITypeBinding binding = field.getType().resolveBinding();
//binding is null here.
LOG.debug("..");
The bindings are activated, the message "Binding activated." show up in the console.
The paths are valid. The librairy log4j is in the "lib" directory.
I tried with other librairies (JUnit, commons-io, commons-lang, etc) with the same result.
Dev environment:
Windows XP SP3 (32 bits)
Eclipse JDT Core 3.8.3
Librairies in buildpath of the project containing this testJDTParser() method:
<classpathentry kind="lib" path="lib/org.eclipse.jdt.core_3.8.3.v20130121-145325.jar"/>
<classpathentry kind="lib" path="lib/org.eclipse.core.runtime_3.8.0.v20120521-2346.jar"/>
<classpathentry kind="lib" path="lib/org.eclipse.equinox.common_3.6.100.v20120522-1841.jar"/>
<classpathentry kind="lib" path="lib/org.eclipse.core.resources_3.8.1.v20121114-124432.jar"/>
<classpathentry kind="lib" path="lib/org.eclipse.core.jobs_3.5.200.v20120521-2346.jar"/>
<classpathentry kind="lib" path="lib/org.eclipse.osgi_3.8.2.v20130124-134944.jar" sourcepath="lib/org.eclipse.osgi.source_3.8.2.v20130124-134944.jar"/>
<classpathentry kind="lib" path="lib/org.eclipse.core.contenttype_3.4.200.v20120523-2004.jar"/>
<classpathentry kind="lib" path="lib/org.eclipse.osgi.services_3.3.100.v20120522-1822.jar" sourcepath="lib/org.eclipse.osgi.services.source_3.3.100.v20120522-1822.jar"/>
<classpathentry kind="lib" path="lib/org.eclipse.osgi.util_3.2.300.v20120913-144807.jar"/>
<classpathentry kind="lib" path="lib/org.eclipse.equinox.preferences_3.5.1.v20121031-182809.jar"/>
How can I tell the ASTParser where to find the external librairies ?
Note: I can't use the IProject/IWorkspace, i'm not using a Eclipse Plugin.
Thank you.
Francois.
Re: ASTParser setEnvironment classpath problems [message #1753932 is a reply to message #1064113] |
Mon, 13 February 2017 00:52  |
How to use a wildcard in the classpath to add multiple jars
java -cp "lib/*" -jar %MAINJAR%
where %MAINJAR% is the jar file to launch via its internal manifest.
If you need only specific jars, you will need to add them individually. The classpath string does not accept generic wildcards like Jar*, *.jar, hiber* etc.
Example
The following entry does not work:
java -cp "Halo.jar;lib/*.jar" ni.package.MainClass
Correct entry is :
java -cp "Halo.jar;lib/*" ni.package.MainClass
Anto
FUDForum. Page generated in 0.03271 seconds
