Home » Modeling » EMF » Newbie question: not all classes of the ecore available in the editor
Newbie question: not all classes of the ecore available in the editor [message #1064001] Mon, 17 June 2013 04:40 Go to next message
I am new to EMF and trying to learn by means of a tutorial (the forum prevents me from posting the link Sad it's a tutorial from the University of Kiel, part of the "Eclipse Practical (winter term 2012/13)").
My ecore model corresponds to a turing machine modelled as a finite state machine. So basically I have the classes "TuringMachine" and the classes "State" and "Transition". Each TuringMachine has at least one State and 0-n transitions.
I generated the genmodel and from it the .edit and .editor code. According to my tutorial I am now supposed to use the editor to create an instance of a the turingmachine.ecore model.
Using the "Example EMF Model Creation Wizard " --> "Turingmachine Model" I created a new instance named myTM.turingmachine and chose a turingmachine-Object to be the root of the instance. Now as I try to create new States and Transitions, the context menue provides only "State" as possible new child of the turingmachine root object (see attached screenshot). But how can I create new Transitions?
I tried to add another class to my ecore model, to see if it will be displayed in the context menu. And same problem occurs: the new class is not available in the context menu, the only possible child of the root object is "State".
Thanks, Sabina
Re: Newbie question: not all classes of the ecore available in the editor [message #1064077 is a reply to message #1064001] Mon, 17 June 2013 09:51 Go to previous messageGo to next message
Sabina,
Does a TuringMachine as a containment reference of type Transition?
Perhaps it's a State that has that type of containment reference. By
default the generated editors will only have creation commands for each
object's containment reference.
On 17/06/2013 2:17 PM, Sabina EH wrote:
> I am new to EMF and trying to learn by means of a tutorial (the forum prevents me from posting the link :( it's a tutorial from the University of Kiel, part of the "Eclipse Practical (winter term 2012/13)").
> Thanks, Sabina
Re: Newbie question: not all classes of the ecore available in the editor [message #1064190 is a reply to message #1064077] Tue, 18 June 2013 03:36 Go to previous messageGo to next message
Thank you, Ed. The reference from TuringMachine to Transition is no containment reference. But form State there is a containment reference called "outgoingTransitions" to Transition.
It seems to have been some Eclipse problem (bug?). What now worked for me is the following: I made a backup of my .ecore file. Then I deleted the whole project in Eclipse and created it again from scratch. I added the (unchanged) .ecore file, generated the .genmodel and from it the the code. Now it works!
Anyways, thanks a lot.
Sabina
  • Attachment: editor2.jpg
    (Size: 77.90KB, Downloaded 169 times)
Re: Newbie question: not all classes of the ecore available in the editor [message #1064194 is a reply to message #1064190] Tue, 18 June 2013 04:00 Go to previous message
Sabina,
Comments below.
So I'd expect the create action for a transition to be on the context
menu for a State.
Probably it works the same as before. In this image you show the State
being selected, in the other, you showed the TuringMachine being
selected. Each has a different context menu with different create actions.
> Sabina
Previous Topic:No name when attribute=class name
Next Topic:[Teneo] On delete child, parent id is set to null before actual delete statement
Current Time: Sat Jul 26 00:29:48 EDT 2025
Powered by FUDForum. Page generated in 0.07349 seconds
