Home » Eclipse Projects » Eclipse Scout » Permissions
Permissions [message #1063937] Sun, 16 June 2013 06:33 Go to next message
Hi. I'm trying to learn my self Eclipse Scout.
I have gone thorugh all tutorials and is now on the tutorials about miniCrm/Permissions. Here I have some problems. When I run this part of code for loading all permissions:
if (getRoleNr() == null) {
    ArrayList<String> rows = new ArrayList<String>();
    BundleClassDescriptor[] permissions = SERVICES.getService(IPermissionService.class).getAllPermissionClasses();
    for (int i = 0; i < permissions.length; i++) {
      if (permissions[i].getBundleSymbolicName().contains("minicrm")) {
	rows.add(permissions[i].getSimpleClassName());
      else {
	// Skip bookmark permissions and other permissions that are not specific to our application
    Collections.sort(rows);
    Object[][] data = new Object[rows.size()][1];
    for (int i = 0; i < rows.size(); i++) {
      data[i][0] = rows.get(i);
    return data;
  else {
    return SERVICES.getService(IAdministrationOutlineService.class).getPermissionTableData(getRoleNr());
This part of code:
Don't find minicrm in the SERVICES.getService(IPermissionService.class).getAllPermissionClasses();
Why? Can someone help me.
Re: Permissions [message #1063981 is a reply to message #1063937] Mon, 17 June 2013 02:46 Go to previous messageGo to next message
Thank you for providing feedback on the tutorial.
I have tried to reproduce it myself. Executing your code snippet in my workspace, I got like you, no minicrm Permission in the permissions arrray:
BundleClassDescriptor[] permissions == [
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.NoAccessPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.DeleteUserBookmarkPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.CopyToClipboardPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.RemoteServiceAccessPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.ReadUserBookmarkPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.PublishUserBookmarkPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.UpdateServiceConfigurationPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.CreateCustomColumnPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.DeleteGlobalBookmarkPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.UpdateGlobalBookmarkPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.UpdateCustomColumnPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.DeleteCustomColumnPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.CreateUserBookmarkPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.UpdateUserBookmarkPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.ReadGlobalBookmarkPermission@org.eclipse.scout.rt.shared],
BundleClassDescriptor[org.eclipse.scout.rt.shared.security.CreateGlobalBookmarkPermission@org.eclipse.scout.rt.shared]
The problem is that the new SDK do not create the Permission in a security subpackage. My permissions objects are here:
org.eclipsescout.demo.minicrm.shared.ui.desktop.form.CreateCompanyPermission,
org.eclipsescout.demo.minicrm.shared.ui.desktop.form.ReadCompanyPermission,
org.eclipsescout.demo.minicrm.shared.ui.desktop.form.UpdateCompanyPermission
Side note: In my workspace I do not have any permission for Person (maybe I skipped this step, when I went to the tutorial).
The runtime still assumes that the Permissions are in a security subpackage. See the implementation of
org.eclipse.scout.rt.server.services.common.security.PermissionService#acceptClassName(Bundle, String) :
protected boolean acceptClassName(Bundle bundle, String className) {
  return isCandidate(className);
And org.eclipse.scout.rt.server.services.common.security.PermissionService#isCandidate(String) :
@Deprecated
protected boolean isCandidate(String className) {
  return className.indexOf("Permission") >= 0 && className.indexOf(".security.") >= 0;
To solve this you can:
1. Move the Permission objects
The full qualified name of the class need to contain ".security.".
2. Register a service implementing IPermissionService
This service should not ignore Permission objects that are not in a security subpackage. (you can extend PermissionService if you want).
Do not hesitate if you need more help.
I think we need to file a bug, because the implementation of the default PermissionService is not acceptable. Or we solve this as part of Bug 410625
Re: Permissions [message #1063992 is a reply to message #1063981] Mon, 17 June 2013 03:56 Go to previous messageGo to next message
The issue is described in Bug 410561 (planned for SR1).
The default PermissionService will be changed, such that Permissions not in the security package are found as well. Until then one of the two solutions described by Jeremie has to be applied.
Re: Permissions [message #1064005 is a reply to message #1063981] Mon, 17 June 2013 05:00 Go to previous message
Jeremie Bresson wrote on Mon, 17 June 2013 08:46
I have extended the tutorial to add the custom permission service. See: Permissions > PermissionService
I hope this helps.
index.php/fa/15281/0/
Previous Topic:How to add more actionable Icons at the icons bar?
Next Topic:Announcement: Moving Scout Kepler M4 to M6 to Eclipse archive
Current Time: Sat Jul 26 03:25:10 EDT 2025
Powered by FUDForum. Page generated in 0.04303 seconds
