eol standalone uml example [message #1063877] |
Fri, 14 June 2013 12:29  |
I'm looking at the examples provided in the repository. Specifically I'm checking org.eclipse.epsilon.examples.standalone.eol.EolStandaloneUmlExample.java but when I try to run it, the following exception appears. Any tips?
http://www.eclipse.org/uml2/4.0.0/UML
Exception in thread "main" Internal error: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found. [file:/C:%5CUsers%5CPatricia%5CDocuments%5CUNIVERSIDAD%5CPFC%5CEclipse_1%5Corg.eclipse.epsilon.examples.standalone%5Csrc%5Corg%5Ceclipse%5Cepsilon%5Cexamples%5Cstandalone%5Cmodels%5Cexample.uml, 2, 214]
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors[XMLLoadImpl.java:77]
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load[XMLLoadImpl.java:185]
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad[XMLResourceImpl.java:240]
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load[ResourceImpl.java:1505]
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load[ResourceImpl.java:1284]
at org.eclipse.epsilon.emc.emf.EmfModel.loadModelFromUri[EmfModel.java:254]
at org.eclipse.epsilon.emc.emf.EmfModel.loadModel[EmfModel.java:167]
at org.eclipse.epsilon.eol.models.CachedModel.load[CachedModel.java:147]
at org.eclipse.epsilon.emc.emf.EmfModel.load[EmfModel.java:151]
at org.eclipse.epsilon.examples.standalone.EpsilonStandaloneExample.createEmfModelByURI[EpsilonStandaloneExample.java:102]
at org.eclipse.epsilon.examples.standalone.eol.EolStandaloneUmlExample.getModels[EolStandaloneUmlExample.java:29]
at org.eclipse.epsilon.examples.standalone.EpsilonStandaloneExample.execute[EpsilonStandaloneExample.java:55]
at org.eclipse.epsilon.examples.standalone.eol.EolStandaloneUmlExample.main[EolStandaloneUmlExample.java:16]
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found. [file:/C:%5CUsers%5CPatricia%5CDocuments%5CUNIVERSIDAD%5CPFC%5CEclipse_1%5Corg.eclipse.epsilon.examples.standalone%5Csrc%5Corg%5Ceclipse%5Cepsilon%5Cexamples%5Cstandalone%5Cmodels%5Cexample.uml, 2, 214]
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI[XMLHandler.java:2586]
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix[XMLHandler.java:2417]
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType[XMLHandler.java:1294]
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject[XMLHandler.java:1463]
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement[XMLHandler.java:1014]
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement[XMIHandler.java:77]
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement[XMLHandler.java:996]
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement[XMLHandler.java:707]
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement[XMIHandler.java:163]
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement[AbstractSAXParser.java:501]
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement[XMLDTDValidator.java:767]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement[XMLDocumentFragmentScannerImpl.java:1363]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook[XMLDocumentScannerImpl.java:1318]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next[XMLDocumentFragmentScannerImpl.java:3103]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next[XMLDocumentScannerImpl.java:922]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next[XMLDocumentScannerImpl.java:648]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument[XMLDocumentFragmentScannerImpl.java:511]
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse[XML11Configuration.java:808]
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse[XML11Configuration.java:737]
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse[XMLParser.java:119]
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse[AbstractSAXParser.java:1205]
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse[SAXParserImpl.java:522]
at javax.xml.parsers.SAXParser.parse[SAXParser.java:395]
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load[XMLLoadImpl.java:175]
... 11 more
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:185)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
at org.eclipse.epsilon.emc.emf.EmfModel.loadModelFromUri(EmfModel.java:254)
at org.eclipse.epsilon.emc.emf.EmfModel.loadModel(EmfModel.java:167)
at org.eclipse.epsilon.eol.models.CachedModel.load(CachedModel.java:147)
at org.eclipse.epsilon.emc.emf.EmfModel.load(EmfModel.java:151)
at org.eclipse.epsilon.examples.standalone.EpsilonStandaloneExample.createEmfModelByURI(EpsilonStandaloneExample.java:102)
at org.eclipse.epsilon.examples.standalone.eol.EolStandaloneUmlExample.getModels(EolStandaloneUmlExample.java:29)
at org.eclipse.epsilon.examples.standalone.EpsilonStandaloneExample.execute(EpsilonStandaloneExample.java:55)
at org.eclipse.epsilon.examples.standalone.eol.EolStandaloneUmlExample.main(EolStandaloneUmlExample.java:16)
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found. (file:/C:%5CUsers%5CPatricia%5CDocuments%5CUNIVERSIDAD%5CPFC%5CEclipse_1%5Corg.eclipse.epsilon.examples.standalone%5Csrc%5Corg%5Ceclipse%5Cepsilon%5Cexamples%5Cstandalone%5Cmodels%5Cexample.uml, 2, 214)
... 13 more
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found. (file:/C:%5CUsers%5CPatricia%5CDocuments%5CUNIVERSIDAD%5CPFC%5CEclipse_1%5Corg.eclipse.epsilon.examples.standalone%5Csrc%5Corg%5Ceclipse%5Cepsilon%5Cexamples%5Cstandalone%5Cmodels%5Cexample.uml, 2, 214)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2586)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2417)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1294)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1463)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1014)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:996)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:707)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:501)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(XMLDTDValidator.java:767)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1363)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(XMLDocumentScannerImpl.java:1318)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:3103)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:922)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
... 11 more
FUDForum. Page generated in 0.26049 seconds
