[CDO 4.2M5] Security Model & H2 DB [message #1063874] |
Fri, 14 June 2013 11:45 |
Hi Eike,
We currently use CDO 4.2M5 and when we enable securityManager on server
side we get the following exception when exporting local resources to
the CDO repository while when the securityManager is not enabled it
works fine :
org.eclipse.emf.cdo.util.CommitException: Rollback in DBStore:
org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Unique
index or primary key violation: "I1371221176297_3 ON
PUBLIC.CDO_PACKAGE_UNITS(ID)"; SQL statement:
INSERT INTO cdo_package_units VALUES (?, ?, ?, ?) [23505-168]
at
org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillSystemTables(MetaDataManager.java:262)
at
org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillSystemTables(MetaDataManager.java:291)
at
org.eclipse.emf.cdo.server.internal.db.MetaDataManager.writePackageUnits(MetaDataManager.java:138)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writePackageUnits(DBStoreAccessor.java:826)
at
org.eclipse.emf.cdo.spi.server.StoreAccessor.doWrite(StoreAccessor.java:83)
at
org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:151)
at
org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:531)
at
org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:46)
at
org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
at
org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
at
org.eclipse.emf.cdo.internal.server.Repository.commitUnsynced(Repository.java:917)
at
org.eclipse.emf.cdo.internal.server.Repository.commit(Repository.java:910)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:295)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:97)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
at
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.h2.jdbc.JdbcSQLException: Unique index or primary key
violation: "I1371221176297_3 ON PUBLIC.CDO_PACKAGE_UNITS(ID)"; SQL
statement:
at org.h2.message.DbException.getJdbcSQLException(DbException.java:329)
at org.h2.message.DbException.get(DbException.java:169)
at org.h2.message.DbException.get(DbException.java:146)
at org.h2.index.BaseIndex.getDuplicateKeyException(BaseIndex.java:81)
at org.h2.index.PageBtree.find(PageBtree.java:121)
at org.h2.index.PageBtreeLeaf.addRow(PageBtreeLeaf.java:147)
at org.h2.index.PageBtreeLeaf.addRowTry(PageBtreeLeaf.java:100)
at org.h2.index.PageBtreeIndex.addRow(PageBtreeIndex.java:105)
at org.h2.index.PageBtreeIndex.add(PageBtreeIndex.java:96)
at org.h2.table.RegularTable.addRow(RegularTable.java:121)
at org.h2.command.dml.Insert.insertRows(Insert.java:124)
at org.h2.command.dml.Insert.update(Insert.java:84)
at org.h2.command.CommandContainer.update(CommandContainer.java:75)
at org.h2.command.Command.executeUpdate(Command.java:230)
at org.h2.jdbc.JdbcPreparedStatement.execute(JdbcPreparedStatement.java:194)
at
org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillSystemTables(MetaDataManager.java:250)
.... 24 more
Do you have in mind a H2 issue with CDO?
Best Regards.
FUDForum. Page generated in 0.03493 seconds
