Home » Modeling » TMF (Xtext) » Xtend 2.4.2 and static method access (regression?)
Xtend 2.4.2 and static method access (regression?) [message #1063804] Fri, 14 June 2013 06:21 Go to next message
I have Xtend 2.4.2 tested and oberserved a change to 2.4.1.
On javax.xml.datatype.DatatypeFactory:
DatatypeFactory::newInstance() -> calls newInstance on Class
DatatypeFactory.newInstance() -> calls newInstance on DatatypeFactory as expected.
Is this the intended behavior? And is there a work around which will work with both versions?
Benjamin
Re: Xtend 2.4.2 and static method access (regression?) [message #1063807 is a reply to message #1063804] Fri, 14 June 2013 06:48 Go to previous messageGo to next message
which Version do you use. i cannot reproduce that using 2.4.2.v201306120542
Re: Xtend 2.4.2 and static method access (regression?) [message #1063819 is a reply to message #1063807] Fri, 14 June 2013 07:19 Go to previous message
I had 2.4.2.v201306040922. I had a fresh installation and no idea, why it was so old. After an update the problem is solved.
Benjamin
Previous Topic:Scoping: Import EObjects from external java-written Provider
Next Topic:Configuring Scope Provider Error Handler
Current Time: Sat Jul 26 02:47:52 EDT 2025
Powered by FUDForum. Page generated in 0.04705 seconds
