Home » Modeling » EMF » EMF Validation Framework - Documentation
EMF Validation Framework - Documentation [message #1063589] Thu, 13 June 2013 09:09 Go to next message
I'm trying to figure out how implementation of validations for EMF models is intended. There is an "EMF Validation Framework", but tutorials and examples are not included in the eclipse documentation after the Helios release anymore. Does this mean that work on the Validation Framework has been discontinued? If so, is there any alternative / best practice available? Or is the old documentation still valid?
Off-Topic: I've got some problems to find the correct forum to post my questions regarding EMF and corresponding tools... could someone clarify which topic should be used? There's "EMF" and "EMF 'Technologoy'", for example. And in brackets behind "EMF 'Technologoy'" theres "Ecore Tools", but there's also another topic called "Ecore Tools" directly. Pretty confusing...
Re: EMF Validation Framework - Documentation [message #1063649 is a reply to message #1063589] Thu, 13 June 2013 11:16 Go to previous messageGo to next message
Till,
Comments below.
It looks like there are quite a few broken links because there aren't
redirects to the more recent release documents. So you're looking for this?
http://help.eclipse.org/juno/index.jsp?topic=/org.eclipse.emf.doc/references/overview/EMF.Validation.html
Yes, unfortunately it's kind of confusing. And in fact these two
container projects are both eliminated but we like to preserve the very
long forum history and can't migrate the newsgroups to better names. In
general you should feel free to use the EMF newsgroup rather than EMFT
and can prefix the topic with the "project" name, e.g., [cdo],
[ecoretools], if the project itself doesn't specify a more specific
newsgroup.
Re: EMF Validation Framework - Documentation [message #1063663 is a reply to message #1063649] Thu, 13 June 2013 12:18 Go to previous messageGo to next message
Ed Merks wrote on Thu, 13 June 2013 11:16
Yes, thanks. This overview sounds really good; validations seem to be integrated even better than I expected Smile The tutorial I found here didn't sound so good.
Re: EMF Validation Framework - Documentation [message #1063668 is a reply to message #1063663] Thu, 13 June 2013 12:50 Go to previous messageGo to next message
The framework provided by the EMF Validation project was developed just
before EMF provided the EValidator API.
The facilities of the EMF Validation project are appropriate if you want
batch or live validation.
EValidator is much simpler and (even) better integrated.
If you want to use OCL as the basis for validation then the OCLinEcore
editor will support direct syntax checked editing. You should not need
to edit OCL in XML these days as some of the old tutorials suggest.
Ed Willink
> integrated even better than I expected :) The tutorial I found
> http://help.eclipse.org/helios/index.jsp?topic=%2Forg.eclipse.emf.validation.doc%2Ftutorials%2FvalidationTutorial.html
Re: EMF Validation Framework - Documentation [message #1063677 is a reply to message #1063668] Thu, 13 June 2013 13:22 Go to previous message
Note that as of EMF 2.9, generated editors (and even the Sample Ecore
Editor) also support live validation:
http://ed-merks.blogspot.de/2013/01/decorating-with-emf.html
On 13/06/2013 6:50 PM, Ed Willink wrote:
> Hi
> just before EMF provided the EValidator API.
> want batch or live validation.
> Regards
> Ed Willink
Previous Topic:Consitency Check
Next Topic:[CDO] Custom query handlers on arbitrary container?
Current Time: Wed Jul 23 04:06:11 EDT 2025
Powered by FUDForum. Page generated in 0.65131 seconds
