Home » Archived » BIRT » Problem building BIRT Jars(How to build jars from modified source code)
Problem building BIRT Jars [message #1062708] Mon, 10 June 2013 08:52 Go to next message
We downloaded BIRT Version 3.7.1 and the corresponding sources. We were able to create a workspace and all the sources are compiled without errors.
After making extensions to the code to adapt BIRT to our needs we face the task to create jar-files for the runtime version.
Could anyone point out to us how this can be done?
Any help is appreciated.
Peter Fopma
Re: Problem building BIRT Jars [message #1062754 is a reply to message #1062708] Mon, 10 June 2013 11:42 Go to previous messageGo to next message
Take a look at this link it should be what you need to build thr jars. Let me know if you run into any problems!
Re: Problem building BIRT Jars [message #1062880 is a reply to message #1062754] Tue, 11 June 2013 04:55 Go to previous messageGo to next message
Kristopher,
thanks for your reply. The link you posted refers to building version 2.2 and 2.3.
In these versions BIRT was still using it's own OSGI framework. The latest version
of the FAQ states that this is no longer needed in version 3.7.
We are confused - why are there no instructions how to build the runtime jars!?
We managed to create a workspace according to the instructions from the FAQ
but somehow we just can't figure out how to build the jars once we modified the
sources.
Peter
Re: Problem building BIRT Jars [message #1062977 is a reply to message #1062880] Tue, 11 June 2013 11:04 Go to previous messageGo to next message
To integrate BIRT into our application we currently copy the jars from the 3.7.1 runtime download into our application.
We can then use the BIRT functionality to create reports.
We need to make some small modifications to the BIRT source code.
Now we are looking for instructions how to create the set of jar-files which we can copy to our application.
(as in the 3.7.1 runtime download)
Has anybody instructions or maybe a link to instructions how to create the jar?
Any help is appreciated,
Peter
Re: Problem building BIRT Jars [message #1063636 is a reply to message #1062977] Thu, 13 June 2013 10:52 Go to previous message
has anybody managed to build the jars from the source-code?
We must be missing a simple thing...
How can we create the jars as they are in the runtime version?
Thanks for any help
Peter
Previous Topic:birt chart not show
Next Topic:birt (svg) chart to show in old browser (as IE 8)
Current Time: Wed Jul 23 14:58:31 EDT 2025
Powered by FUDForum. Page generated in 0.03142 seconds
