Home » Eclipse Projects » Remote Application Platform (RAP) » Custom widget
Custom widget [message #106337] Thu, 25 September 2008 08:23 Go to next message
I am trying to insert the qooxdoo DateChooser widget into a RAP
application.
I registered the
qooxdoo-0.8-sdk/framework/source/class/qx/ui/control/DateCho oser.js from
the qooxdoo sdk as an API-Resource. When trying to instantiate a
qx.ui.control.DateChooser object the Browser tells me this:
Could not evaluate javascript response:
TypeError: qx.ui.control is undefined
So I think I got the part with registering the APIResource wrong.
What do I have to do to make it work?
Re: Custom widget [message #106351 is a reply to message #106337] Thu, 25 September 2008 08:34 Go to previous messageGo to next message
Originally posted by: ifurnadjiev.innoopract.com
the DateTime widget is available in RAP 1.1.1. You can have a look at it.
Best,
Ivan
Gunnar Wurl wrote:
> application.
> I registered the
> from the qooxdoo sdk as an API-Resource. When trying to instantiate a
Re: Custom widget [message #106365 is a reply to message #106351] Thu, 25 September 2008 08:39 Go to previous messageGo to next message
Thanks Ivan,
but my problem is more concerning implementing a custom widget, it is not
the DateTime widget in special. I have a general problem in understanding
what to do to implement an existing qooxdoo widget into a RAP application.
The GMaps example works, and I can use the qooxdoo widgets which are in
the RAP built, but no exterior widgets.
Re: Custom widget [message #106378 is a reply to message #106365] Thu, 25 September 2008 09:00 Go to previous messageGo to next message
Hi Gunnar,
I suppose that the problem is that the qooxdoo DateChooser relays on
some qooxdoo classes like GridLayout, Date and so on which are striped
from the qx.js used in RAP. You need to register all related classes as
well.
Best,
Ivan
Gunnar Wurl wrote:
> Thanks Ivan,
> not the DateTime widget in special. I have a general problem in
> understanding what to do to implement an existing qooxdoo widget into
> a RAP application. The GMaps example works, and I can use the qooxdoo
> widgets which are in the RAP built, but no exterior widgets.
Re: Custom widget [message #106406 is a reply to message #106337] Thu, 25 September 2008 09:16 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Gunnar,
RAP uses a subset of qx 0.7.3. The error you get is because the 0.8
DateChooser references thing that are not available in 0.7.3.
I doubt that it is possible to get widgets from 0.8 running in 0.7.3.
HTH
Rüdiger
Rüdiger Herrmann
Innoopract
http://innoopract.com
delivering eclipse technology
Gunnar Wurl wrote:
> application.
> I registered the
Re: Custom widget [message #106433 is a reply to message #106378] Thu, 25 September 2008 09:26 Go to previous messageGo to next message
be sure to use 0.7.3 classes. I don't think that qooxdoo 0.8 widgets
will work with RAP as it ships 0.7.3
Greets
Benny
Ivan Furnadjiev wrote:
> Hi Gunnar,
> well.
> Best,
> Ivan
> Gunnar Wurl wrote:
>> Thanks Ivan,
Re: Custom widget [message #106475 is a reply to message #106406] Thu, 25 September 2008 10:48 Go to previous message
Thanks for all your advices!
The Problem was that I used the 0.8 version of qooxdoo. I tried it with
the 0.73 version and it works.
Thanks again
Previous Topic:empty Coolbar
Next Topic:How to add Help Content
Current Time: Sat Nov 08 18:03:14 EST 2025
Powered by FUDForum. Page generated in 0.04252 seconds
