Home » Eclipse Projects » JFace » TreeViewer Node Listener
TreeViewer Node Listener [message #1063303] Wed, 12 June 2013 19:01 Go to next message
I'm starting with JFace,i have a treeView which is used as menu, i need to associate some part with each children node. When we doubleclick on the node it should open associated part
how could I, determine which part is associated with a given node, i dont have access to content model, to get the part Id
How should I proceed?
viewer.addDoubleClickListener(new IDoubleClickListener() {
   public void doubleClick(DoubleClickEvent event) {
	TreeViewer viewer = (TreeViewer) event.getViewer();
	IStructuredSelection thisSelection = (IStructuredSelection) event
		            .getSelection();
	 Object selectedNode = thisSelection.getFirstElement();
           //TODO somthing with selectedNode
thank's
[Updated on: Wed, 12 June 2013 19:07] by Moderator
Re: TreeViewer Node Listener [message #1063453 is a reply to message #1063303] Thu, 13 June 2013 04:34 Go to previous message
I solved my problem, finally the node is an instance of my object model, it was enough to cast the Selected node to my model object, like this
if (selectedNode instanceof NavigatorMenuItem) {
      NavigatorMenuItem o = (NavigatorMenuItem) selectedNode;
       System.out.println(o.getItemLibelle()) ;
Previous Topic:TreeViewer expand one top level element at once
Next Topic:XML databinding in SWT help
Current Time: Sun Jul 27 07:58:02 EDT 2025
Powered by FUDForum. Page generated in 0.05755 seconds
