Home » Eclipse Projects » Plugin Development Environment (PDE) » using JNA in plugin
using JNA in plugin [message #1063291] Wed, 12 June 2013 18:29 Go to next message
Recently I am trying to develop a plugin which will call some c++ functions, I tried to use JNA on Indigo Service Release 2.
First I tried the JNA sample code HelloWorld.java as an stand-alone java app. Add jna-3.5.2.jar from Project->Properties->Java Build Path->Libraries->Add External JARS tab. It worked very well.
package com.sun.jna.examples;
import com.sun.jna.Library;
import com.sun.jna.Native;
import com.sun.jna.Platform;
/** Simple example of JNA interface mapping and usage. */
public class HelloWorld {
    // This is the standard, stable way of mapping, which supports extensive
    // customization and mapping of Java to native types.
    public interface CLibrary extends Library {
        CLibrary INSTANCE = (CLibrary)
            Native.loadLibrary((Platform.isWindows() ? "msvcrt" : "c"),
                               CLibrary.class);
        void printf(String format, Object... args);
        CLibrary.INSTANCE.printf("Hello, World\n");
Then I tried to call the c function in plugin helloworld sample code, add the jna-3.5.2.jar as what I have done before. But this time it threw plenty of exceptions.
Two files, first one is the HelloWorld.java with minor change
package plugin_test.actions;
                               CLibrary.class);
    public void test() {
And the default helloworld plugin sample code with minor change
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.IWorkbenchWindowActionDelegate;
import org.eclipse.jface.dialogs.MessageDialog;
 * Our sample action implements workbench action delegate.
 * The action proxy will be created by the workbench and
 * shown in the UI. When the user tries to use the action,
 * this delegate will be created and execution will be
 * delegated to it.
 * @see IWorkbenchWindowActionDelegate
public class SampleAction implements IWorkbenchWindowActionDelegate {
	private IWorkbenchWindow window;
	 * The constructor.
	public SampleAction() {
	 * The action has been activated. The argument of the
	 * method represents the 'real' action sitting
	 * in the workbench UI.
	 * @see IWorkbenchWindowActionDelegate#run
	public void run(IAction action) {
		MessageDialog.openInformation(
			window.getShell(),
			"Plugin_test",
			"Hello, Eclipse world");
		HelloWorld obj = new HelloWorld();
		obj.test();
Error message looks like as followings:
!SESSION 2013-06-12 17:17:43.030 -----------------------------------------------
eclipse.buildId=M20120208-0800
java.version=1.6.0_45
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data C:\Users\allen\workspace/../runtime-EclipseApplication -dev file:C:/Users/allen/workspace/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.ui 4 0 2013-06-12 17:17:56.479
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError: com/sun/jna/Library
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:626)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:608)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:562)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:486)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:459)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at plugin_test.actions.HelloWorld.test(HelloWorld.java:21)
at plugin_test.actions.SampleAction.run(SampleAction.java:37)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.ClassNotFoundException: com.sun.jna.Library
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
... 48 more
I have been blocked by this issue for two days. What can I do to fix the issue or debug the code? I really appreciate for any help.
Re: using JNA in plugin [message #1063838 is a reply to message #1063291] Fri, 14 June 2013 08:33 Go to previous messageGo to next message
Did you add the jna jar to your bundle's manifest? Normally, bundles
(plug-ins) can only see classes that are in packages exported from other
bundles.
Alternatively, you would need to add the jna jar to the application
level classpath so it's available to all bundles (if that's something
that makes sense to do).
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse.platform.doc.isv/guide/workbench.htm
Re: using JNA in plugin [message #1063900 is a reply to message #1063838] Fri, 14 June 2013 16:58 Go to previous message
Hi Paul:
Thank you so much, the problem solved. I really appreciate for your help.
What I have done is:
1. Add this line at the bottom of the META-INF/MANIFEST.MF
Bundle-ClassPath: .,lib/jna-3.5.2.jar
2. Restart the Eclipse and it works.
Previous Topic:No images after deploying plugins
Next Topic:Create a plugin from java standalone file
Current Time: Sun Jul 27 16:18:08 EDT 2025
Powered by FUDForum. Page generated in 0.03879 seconds
