Home » Modeling » TMF (Xtext) » new import section mechanism
new import section mechanism [message #1063244] Wed, 12 June 2013 15:35 Go to next message
I'm using Xbase and the new XImportSection mechanism. The imports are
used both for Java types and names exported from other files. When an
import is used for (only) the latter case, I get a warning that it is
not used. Can't it check that a corresponding named DSL object is
referred to?
Hallvard
Re: new import section mechanism [message #1063249 is a reply to message #1063244] Wed, 12 June 2013 16:27 Go to previous message
did you try to hook into
org.eclipse.xtext.xbase.validation.XbaseJavaValidator.handleTypeUsageInCrossReference(Map<JvmType, XImportDeclaration>, Map<String, JvmType>, INode)
Previous Topic:Terminals with whitespace
Next Topic:I can "know" the error in my editor
Current Time: Sat Jul 26 06:14:54 EDT 2025
Powered by FUDForum. Page generated in 0.04463 seconds
