Home » Modeling » OCL » How to pass a java variable to OCL statement?
How to pass a java variable to OCL statement? [message #1063179] Wed, 12 June 2013 10:31 Go to next message
Hi there,
// set OCL context classifier
helper.setContext(ModelPackage.Literals.DEVICE);
Constraint invariant = helper.createInvariant("Module.allInstances()->size()<=6 ");
Query eval = ocl.createQuery(invariant);
validation = (Boolean) eval.evaluate(device);
A device has a set of modules. This is an example to validate a device object for the maximum number of modules. In here "Module.allInstances()->size()<=6 " is OCL syntax.
Problem:
Is it possible to define 6 in a java variable and call it in here?
such as,
int maxModules=6;
Constraint invariant = helper.createInvariant("Module.allInstances()->size()<=maxModules ");
I know this is not right.
Thanks in advance!
K
[Updated on: Wed, 12 June 2013 10:32] by Moderator
Re: How to pass a java variable to OCL statement? [message #1063180 is a reply to message #1063179] Wed, 12 June 2013 10:37 Go to previous messageGo to next message
Passing a variable to an invariant is a very wrong way of looking at things.
You may of course referebce properties within invraiants, so if you
arrange for your 'variable' to be in a suitable property you can use it.
Ed Willink
On 12/06/2013 15:31, Kosala Yapa wrote:
> Hi there,
> object for number of modules. In here
> Problem:
> such as,
> int maxModules=6;
> Thanks in advance!
> K
Re: How to pass a java variable to OCL statement? [message #1063197 is a reply to message #1063180] Wed, 12 June 2013 11:20 Go to previous messageGo to next message
TX Ed.
What do you mean properties in here?
Re: How to pass a java variable to OCL statement? [message #1063200 is a reply to message #1063197] Wed, 12 June 2013 11:27 Go to previous messageGo to next message
HI
A Package contains Classes and a Class contains Properties/Operations.
Ed Willink
On 12/06/2013 16:20, Kosala Yapa wrote:
> TX Ed.
> Cheers,
Re: How to pass a java variable to OCL statement? [message #1063426 is a reply to message #1063200] Thu, 13 June 2013 03:18 Go to previous messageGo to next message
TX.
if TorderNumber is a property in the class you define invariant, then invariant could be,
Constraint invariant = helper.createInvariant("HeadModule.allInstances()->exists(m:HeadModule|m.orderNumber=TorderNumber )");
Is that you mean?
I know, the above invariant cannot be right.
IMO, you probably meant property is a field in the model.
Of course, if TorderNumber is a field in the model, yes can access that in an invariant, but that is not my requirement.
My requirement is, Passing a java variable/constant (which is not in the model) to OCL invariant.
Is this possible in OCL?
K
[Updated on: Thu, 13 June 2013 05:08] by Moderator
Re: How to pass a java variable to OCL statement? [message #1063498 is a reply to message #1063426] Thu, 13 June 2013 06:11 Go to previous message
Yes
On 13/06/2013 08:18, Kosala Yapa wrote:
> TX.
> if maxModules is a property, then invariant could be,
> helper.createInvariant("Module.allInstances()->size()<= maxModules ");
> Is that you mean?
> Cheers,
> K
Previous Topic:OCL closure works properly with Interactive OCL, not Interactive Xtext OCL
Next Topic:[Announce] Eclipse OCL 4.1.0 (Kepler) RC4 is available.
Current Time: Sat Jul 19 02:55:13 EDT 2025
Powered by FUDForum. Page generated in 0.07858 seconds
