Urgent Help needed regarding CSS mechanism in rcp application [message #1062352] |
Fri, 07 June 2013 07:02  |
Hi all,
I have done the following steps to create an rcp application
1. Created a rcp application (3.x)
2. created extension point "org.eclipse.e4.ui.css.swt.theme" and added two themes in it and set
the respective css files for each theme.
3. Added a ViewerPreferencePage, which given the option to change theme.
Now, when i change theme , it work's fine and applied on all the swt controls which i have
specified in css file,
Now i have defined my own selector in the css file like "MySelector" and then specified it's
properties
like this
.MySelector
background-color:rgb(250,250,200);
i have debugged the code, the main class handling this is the "ThemeEngine", which reads this, one
thing for sure is that engine successfully read the whole css file including my own custom
selector, now what i want's is to get this selector and it's properties and values from the css
engine programmatically
Any idea/help/hint/clue/suggestion will be appreciated.
SDK
FUDForum. Page generated in 0.04387 seconds
