Home » Eclipse Projects » Eclipse Scout » How to create a Pop Up Form?(How to create a Pop Up Form?)
How to create a Pop Up Form? [message #1062769] Mon, 10 June 2013 12:23 Go to next message
I just wanted to know which is the simple way to create a Pop-Up with an input form, which pops up for example when selecting a menu option. If inside this Pop-UP the OK button is clicked the (*) SERVICES.getService(ILDAPOutlineService.class).methodXXX() will be called and the Pop-up will be closed.
Connected to the first one, I have another question: How to "communicate" with other parts of the 'Desktop' class like for example a menu, "menu Y", (implemented with "AbstractMenu"), after calling(*), and then calling for example ZZZZZClass.this.execAction()?
Thank you for your time.
Re: How to create a Pop Up Form? [message #1062852 is a reply to message #1062769] Tue, 11 June 2013 02:15 Go to previous messageGo to next message
Displaying a pop-up dialog from a menu
  1. Define the popup dialog as a normal form (let's assume it is called PopupDialogForm)
  2. in your menu's execAction method add the following code:
      PopupDialogForm form = new PopupDialogForm();
      form.startNew();
      form.waitFor();
      if (form.isFormStored()) {
        SERVICES.getService(ILDAPOutlineService.class).methodXXX();
I am not sure I understand what you want to do in your second part of the question, but if you need access to a ZZZZZClass instance, why don't you add a member var for it to Desktop and then use that to access execAction()?
[Updated on: Tue, 11 June 2013 02:16] by Moderator
Re: How to create a Pop Up Form? [message #1062866 is a reply to message #1062852] Tue, 11 June 2013 03:52 Go to previous messageGo to next message
An other possibility is to use MessageBox:
MessageBox.showOkMessage(TEXTS.get("MessageBoxTitle"), TEXTS.get("MessageBoxHeader"), TEXTS.get("MessageBoxInfo"))
There is different kind of message boxes (Ok, Yes/No, Yes/No/Cancel, delete confirmation, ...) Have a look at the different static methods on MessageBox.
Re: How to create a Pop Up Form? [message #1062963 is a reply to message #1062866] Tue, 11 June 2013 10:32 Go to previous message
Thank you both! Finally I have chosen the solution proposed by Urs, although the one by Jeremie could fit my requirements.
Previous Topic:Switching between table pages
Next Topic:How to access execAction() methods from Desktop outer class?
Current Time: Sat Jul 26 08:56:27 EDT 2025
Powered by FUDForum. Page generated in 0.05759 seconds
