Home » Modeling » UML2 » Opening UML meta-model using oclInEcore editor
Opening UML meta-model using oclInEcore editor [message #1062523] Sat, 08 June 2013 04:56 Go to next message
Hello everyone,
I try to open the UML ecore meta-model (imported from org.eclipse.uml2.uml) using oclInEcore editor and I got the following error:
Error
Sat Jun 08 10:11:13 CEST 2013
OCL in Ecore Editor linking error
	at org.eclipse.ocl.examples.pivot.utilities.PivotUtil.refreshList(PivotUtil.java:1021)
	at org.eclipse.ocl.examples.pivot.utilities.AbstractConversion.refreshList(AbstractConversion.java:72)
	at org.eclipse.ocl.examples.xtext.base.cs2pivot.BasePostOrderVisitor.visitAnnotationCS(BasePostOrderVisitor.java:131)
	at org.eclipse.ocl.examples.xtext.base.cs2pivot.BasePostOrderVisitor.visitAnnotationCS(BasePostOrderVisitor.java:1)
	at org.eclipse.ocl.examples.xtext.base.baseCST.impl.AnnotationCSImpl.accept(AnnotationCSImpl.java:219)
	at org.eclipse.ocl.examples.xtext.base.cs2pivot.CS2PivotConversion.visitInPostOrder(CS2PivotConversion.java:1295)
	at org.eclipse.ocl.examples.xtext.base.cs2pivot.CS2PivotConversion.visitInPostOrder(CS2PivotConversion.java:1293)
	at org.eclipse.ocl.examples.xtext.base.cs2pivot.CS2PivotConversion.update(CS2PivotConversion.java:1201)
	at org.eclipse.ocl.examples.xtext.base.cs2pivot.CS2Pivot.update(CS2Pivot.java:505)
	at org.eclipse.ocl.examples.xtext.base.utilities.CS2PivotResourceAdapter.refreshPivotMappings(CS2PivotResourceAdapter.java:129)
	at org.eclipse.ocl.examples.xtext.base.utilities.CS2PivotLinker.afterModelLinked(CS2PivotLinker.java:69)
	at org.eclipse.xtext.linking.impl.AbstractCleaningLinker.linkModel(AbstractCleaningLinker.java:44)
	at org.eclipse.xtext.resource.XtextResource.doLinking(XtextResource.java:279)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLinking(LazyLinkingResource.java:82)
	at org.eclipse.ocl.examples.xtext.essentialocl.utilities.EssentialOCLCSResource.doLinking(EssentialOCLCSResource.java:98)
	at org.eclipse.xtext.resource.XtextResource.updateInternalState(XtextResource.java:247)
	at org.eclipse.xtext.resource.XtextResource.updateInternalState(XtextResource.java:237)
	at org.eclipse.xtext.resource.XtextResource.update(XtextResource.java:218)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconcilerUnitOfWork.process(XtextReconcilerUnitOfWork.java:55)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconcilerUnitOfWork.process(XtextReconcilerUnitOfWork.java:1)
	at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:36)
	at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.modify(AbstractReadWriteAcces.java:49)
	at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.modify(XtextDocument.java:181)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.internalModify(XtextDocument.java:90)
	at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.reconcile(XtextDocumentReconcileStrategy.java:44)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.run(XtextReconciler.java:254)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Would you please point out what the problem is and how to fix it?
Many thanks.
Re: Opening UML meta-model using oclInEcore editor [message #1062528 is a reply to message #1062523] Sat, 08 June 2013 05:42 Go to previous messageGo to next message
The OCLinEcore editor is primarily intended for OCL embedded with an
Ecore file, either as an *.ecoire XMI file or as a *.oclinecore text file.
Upgrading the functionality to a textual view of UML classes with
embedded OCL is still on the to-do list.
If you want to editing support for OCL in UML use the Kepler
(pre-release) of Papyrus.
If you want to complement an existing UML model, use the Complete OCL
editor.
Ed Willink
On 08/06/2013 09:57, Capi Tali wrote:
> Hello everyone,
> error:
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Would you please point out what the problem is and how to fix it? Many
> thanks.
Re: Opening UML meta-model using oclInEcore editor [message #1062529 is a reply to message #1062528] Sat, 08 June 2013 06:39 Go to previous messageGo to next message
Thanks for your help. The Complete OCL editor works well for me. One more question please. I know that OCL is a side-effect free language which means that there is no dynamic creation of objects. However, I wonder if there's a support to create somehow a temporary meta-class (not existed in the meta-model) and evaluate some constraints on it?
[Updated on: Sat, 08 June 2013 06:41] by Moderator
Re: Opening UML meta-model using oclInEcore editor [message #1062532 is a reply to message #1062529] Sat, 08 June 2013 06:48 Go to previous messageGo to next message
No. If the meta-class does not exist, why would you want to constrain it.
It seems like you're doing something you haven't sensibly explained, so
I cannot give a helpful answer.
Ed Willink
> which means that there is no dynamic creation of objects. I wonder if
> there's a way to create a temporary meta-class (not existed in the
> Best regards,
Re: Opening UML meta-model using oclInEcore editor [message #1062534 is a reply to message #1062532] Sat, 08 June 2013 07:42 Go to previous messageGo to next message
Thank you for your answer.
Well, in some situations that I encountered, I have to evaluate some constraints on the concept that does not exist in the defined language. Let's say in the meta-model we have two groups of meta-classes: A1,A2,...,An and B1,B2,...,Bn. The notion of "group", which encompasses a set of meta-classes, obviously does not exist at the meta level but a possible constraint could be, let's say "GroupA must have certain relationships with GroupB". Do you have any idea on this?
If the dynamic addition of meta-class is impossible then I have another question: Imagine we have the meta-class Group at the meta-model. Could we somehow declare a new Group object at the model-level and evaluate some constraints on it? For instance, the syntax could be somehow like: let Group g = new Group(a1: A1, a2: A2,...) in evaluate(g).
Best regards.
Re: Opening UML meta-model using oclInEcore editor [message #1062734 is a reply to message #1062534] Mon, 10 June 2013 10:47 Go to previous messageGo to next message
Perhaps profiles and stereotypes are what you should use.
Ed Willink
> this?
> Best regards.
Re: Opening UML meta-model using oclInEcore editor [message #1062912 is a reply to message #1062734] Tue, 11 June 2013 07:38 Go to previous messageGo to next message
Actually I found this thread similar to what I asked:
http://www.eclipse.org/forums/index.php/m/668407/
According to that, I understand that with the actual version of OCL, we can not declare new objects but only new collections and tuples. Could you confirm on this point?
I think the Stereotypes of Profiles are good solutions for this problem in UML. However, the extension mechanism support of domain-specific languages is very limited.
Re: Opening UML meta-model using oclInEcore editor [message #1062918 is a reply to message #1062912] Tue, 11 June 2013 07:49 Go to previous messageGo to next message
The new Pivot-based OCL which is used in Papyrus, has a prototype
implementation of constructors as suggested by
http://www.omg.org/issues/ocl2-rtf#Issue13057. This re-uses the Tuple
syntax, so you may be able to do
Person{name='aName',age=20}
Ed Willink
> Could you confirm on this point? I think the Stereotypes of Profiles
> Best regards,
Re: Opening UML meta-model using oclInEcore editor [message #1062923 is a reply to message #1062918] Tue, 11 June 2013 08:06 Go to previous message
Many thanks.
Previous Topic:Loading UML-Model with papyrus-profile applied
Next Topic:UML profile with OCL constraints on stereotypes
Current Time: Thu Jul 24 17:18:18 EDT 2025
Powered by FUDForum. Page generated in 0.06592 seconds
