Weird RSE behavior, but only in recent version [message #1062830] |
Mon, 10 June 2013 21:27  |
I got a weird problem. I was using Eclipse Ganymede Version: 3.4.2 Build id: M20090211-1700 with RSE (from this version of Eclipse is says that everything is up to date) and it was nice, but I upgraded to Juno Version: 4.2.2 Build id: M20130204-1200 with RSE for HTML 5 support then trouble started.
I configured a SSH connection on both Eclipse using the same information.
I open a file to edit it, leave Eclipse alone for 2-3 min, then come back and edit the file and Save, Juno give me a error:
RSEF1002
Message reported from file system: java.io.IOException: Pipe closed
then I need to disconnect and reconnect
but Ganymede is fine.
as far as I know both configuration are the same, i even try to set the timeout to 30 sec with Juno without success.
What did I do wrong?
Thank you for the help
Sylvain Roy
FUDForum. Page generated in 0.03715 seconds
