Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Maven Dependencies?
Maven Dependencies? [message #106270] Sun, 06 January 2008 23:25 Go to next message
(I hope this does not come across twice - I don't see the first one so I'm keeping my fingers crossed)
I'm trying to get a basic setup working for Teneo and Hibernate. I was wondering if anyone knows of a maven 2 repository housing the necessary dependencies?
- Ole
Re: Maven Dependencies? [message #106287 is a reply to message #106270] Sun, 06 January 2008 23:40 Go to previous messageGo to next message
One more question...Does teneo 0.80 have to be run inside / depend on eclipse?
- Ole
Re: Maven Dependencies? [message #106301 is a reply to message #106287] Mon, 07 January 2008 00:56 Go to previous messageGo to next message
Hi Ole,
Teneo can be run outside of Eclipse. I use it myself in a webapp.
See here:
http://www.elver.org/hibernate/installation.html#Installing+ the+runtime+layer+in+a+non-plugin+EMF+project
In addition Teneo requires the following jars:
- org.eclipse.emf.ecore.jar, org.eclipse.emf.ecore.xmi.jar, org.eclipse.emf.common.jar. These jars
can be found in the plugins directory in your eclipse installation.
- the relevant hibernate or jpox jars
- commons-logging jar
As far as I know Teneo is not present in a maven respository, I do not know if the other
dependencies are present somewhere in maven repositories.
gr. Martin
> eclipse?
> - Ole
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Maven Dependencies? [message #106382 is a reply to message #106301] Mon, 07 January 2008 10:36 Go to previous messageGo to next message
Hi Martin,
Super - Thanks. I'll give it a go.
- Ole
Martin Taal wrote:
> Hi Ole,
> See here:
> org.eclipse.emf.common.jar. These jars can be found in the plugins
> know if the other dependencies are present somewhere in maven repositories.
> gr. Martin
>> eclipse?
>> Thanks,
>> - Ole
Can't load HbMapperException with Hibernate Setup [message #106766 is a reply to message #106382] Mon, 14 January 2008 12:46 Go to previous messageGo to next message
I'm trying to hibernate setup and the class loader does not see:
org.eclipse.emf.teneo.hibernate.HbMapperException;
I verified that these are on the class path:
* org.eclipse.emf.teneo
* org.eclipse.emf.teneo.annotations
* org.eclipse.emf.teneo.hibernate
Are there other dependencies needed?
- Ole
Re: Can't load HbMapperException with Hibernate Setup [message #106782 is a reply to message #106766] Mon, 14 January 2008 15:16 Go to previous messageGo to next message
OK - I think I found it. It's in the org.eclipse.emf.teneo.hibernate.mapper_0.8.0.v200712280940 plugin. I'll be glad to update library tutorial, etc. as I'm going along. Please let me know of any additional steps I can take to contribute.
- Ole
Ole Ersoy wrote:
> - Ole
Re: Can't load HbMapperException with Hibernate Setup [message #106818 is a reply to message #106782] Tue, 15 January 2008 00:57 Go to previous messageGo to next message
Hi Ole,
Contributions are always appreciated! If you want to update the docs there are two ways:
- create a bugzilla and mark all the things you missed/want to change in the docs in that bugzilla
then I can add it in the docs myself, or
- check out the org.eclipse.emf.teneo.website project, the docs are in apache forest. When you
change them just make a patch and send it as a bugzilla
gr. Martin
> Cheers,
> - Ole
> Ole Ersoy wrote:
>> Hi,
>> Thanks,
>> - Ole
The Netherlands
Re: Can't load HbMapperException with Hibernate Setup [message #106878 is a reply to message #106818] Tue, 15 January 2008 15:23 Go to previous messageGo to next message
Hi Martin,
Super - Thanks for the heads up. I'll submit a patch asap.
- Ole
Martin Taal wrote:
> Hi Ole,
> there are two ways:
> the docs in that bugzilla then I can add it in the docs myself, or
> apache forest. When you change them just make a patch and send it as a
> bugzilla
> gr. Martin
>> Cheers,
>> - Ole
>> Ole Ersoy wrote:
>>> Hi,
>>> Thanks,
>>> - Ole
Setting VARCHAR Length by EAnnotation? [message #106890 is a reply to message #106878] Tue, 15 January 2008 21:06 Go to previous messageGo to next message
Just wondering if anyone knows whether it's possible to change the default VARCHAR length through the use of an EAnnotation? The "Developer Use Case" would be the creation of a dynamic model and generating the corresponding database schema.
- Ole
Re: Setting VARCHAR Length by EAnnotation? [message #106958 is a reply to message #106890] Wed, 16 January 2008 05:15 Go to previous messageGo to next message
Hi Ole,
For each individual eattribute you can set a column annotation with a length.
However, there is currently no global default varchar length setting. I tried to find a global
hibernate parameter to set the column length but I could not find it.
Can you enter a bugzilla feature request for this?
gr. Martin
Ole Ersoy wrote:
> - Ole
The Netherlands
Re: Setting VARCHAR Length by EAnnotation? [message #107070 is a reply to message #106958] Wed, 16 January 2008 10:37 Go to previous message
Hi Martin,
Super - I'll give the column annotation a shot. I looked around for a global varchar default for hibernate as well, and came up short, so I guess it's hard coded. I did put in a bugzilla feature request for a global teneo varchar limit default.
Thanks again,
- Ole
Martin Taal wrote:
> Hi Ole,
> length.
> tried to find a global hibernate parameter to set the column length but
> gr. Martin
> Ole Ersoy wrote:
>> Hi,
>> Thanks,
>> - Ole
Re: Maven Dependencies? [message #613934 is a reply to message #106270] Sun, 06 January 2008 23:40 Go to previous message
- Ole
Re: Maven Dependencies? [message #613935 is a reply to message #106287] Mon, 07 January 2008 00:56 Go to previous message
Hi Ole,
See here:
gr. Martin
> eclipse?
> - Ole
The Netherlands
Re: Maven Dependencies? [message #613949 is a reply to message #106301] Mon, 07 January 2008 10:36 Go to previous message
Hi Martin,
- Ole
Martin Taal wrote:
> Hi Ole,
> See here:
> gr. Martin
>> eclipse?
>> Thanks,
>> - Ole
Can't load HbMapperException with Hibernate Setup [message #613981 is a reply to message #106382] Mon, 14 January 2008 12:46 Go to previous message
- Ole
Re: Can't load HbMapperException with Hibernate Setup [message #613982 is a reply to message #106766] Mon, 14 January 2008 15:16 Go to previous message
- Ole
Ole Ersoy wrote:
> - Ole
Re: Can't load HbMapperException with Hibernate Setup [message #613985 is a reply to message #106782] Tue, 15 January 2008 00:57 Go to previous message
Hi Ole,
gr. Martin
> Cheers,
> - Ole
> Ole Ersoy wrote:
>> Hi,
>> Thanks,
>> - Ole
The Netherlands
Re: Can't load HbMapperException with Hibernate Setup [message #613989 is a reply to message #106818] Tue, 15 January 2008 15:23 Go to previous message
Hi Martin,
- Ole
Martin Taal wrote:
> Hi Ole,
> there are two ways:
> bugzilla
> gr. Martin
>> Cheers,
>> - Ole
>> Ole Ersoy wrote:
>>> Hi,
>>> Thanks,
>>> - Ole
Setting VARCHAR Length by EAnnotation? [message #613990 is a reply to message #106878] Tue, 15 January 2008 21:06 Go to previous message
- Ole
Re: Setting VARCHAR Length by EAnnotation? [message #613995 is a reply to message #106890] Wed, 16 January 2008 05:15 Go to previous message
Hi Ole,
gr. Martin
Ole Ersoy wrote:
> - Ole
The Netherlands
Re: Setting VARCHAR Length by EAnnotation? [message #614003 is a reply to message #106958] Wed, 16 January 2008 10:37 Go to previous message
Hi Martin,
Thanks again,
- Ole
Martin Taal wrote:
> Hi Ole,
> length.
> gr. Martin
> Ole Ersoy wrote:
>> Hi,
>> Thanks,
>> - Ole
Previous Topic:Porblem by using ecore tool
Next Topic:[Teneo] Problem with update site
Current Time: Thu Jul 24 21:40:15 EDT 2025
Powered by FUDForum. Page generated in 0.21870 seconds
