Home » Eclipse Projects » Remote Application Platform (RAP) » [ANN] RAP 2.1 RC3 is available
Re: [ANN] RAP 2.1 RC3 is available [message #1062519 is a reply to message #1062336] |
Sat, 08 June 2013 04:12   |
i have a problem.
Eclipse RAP 2.0(rap-2.0.0-R-20130205-1849) version using.
Eclipse RAP 2.1 RC3 have updated.
Where do you have to check?
Comes the following message.
Client Error
Details:
Error: Error: Operation "create" on target "w19" of type "rwt.widgets.MenuItem" failed:
root is null
Properties:
parent = w18
style = CASCADE
index = 0
text = File
mnemonicIndex = 0
menu = w20
Script: {"head":{"requestCounter":3},"operations":[["destroy","w2"],["create","w17","rwt.widgets.Shell",{"style":["NO_TRIM"]}],["listen","w17",{"Move":true,"Resize":true,"Activate":true,"Close":true}],["set","w17",{"text":"Tadpole DB Hub 1.0.0 SRAlpha","active":true,"mode":"maximized","minimumSize":[80,2],"activeControl":"w25","bounds":[0,0,984,972],"children":["w25","w52","w60","w65"],"tabIndex":-1,"visibility":true}],["listen","w17",{"Help":true}],["create","w18","rwt.widgets.Menu",{"style":["BAR"]}],["create","w19","rwt.widgets.MenuItem",{"parent":"w18","style":["CASCADE"],"index":0,"text":"File","mnemonicIndex":0,"menu":"w20"}],["create","w21","rwt.widgets.MenuItem",{"parent":"w18","style":["CASCADE"],"index":1,"text":"Window","mnemonicIndex":0,"menu":"w22"}],["create","w23","rwt.widgets.MenuItem",{"parent":"w18","style":["CASCADE"],"index":2,"text":"Help","mnemonicIndex":0,"menu":"w24"}],["create","w20","rwt.widgets.Menu",{"style":["DROP_DOWN"]}],["listen","w20",{"Show":true,"Hide":true}],["create","w22","rwt.widgets.Menu",{"style":["DROP_DOWN"]}],["listen","w22",{"Show":true,"Hide":true}],["create","w24","rwt.widgets.Menu",{"style":["DROP_DOWN"]}],["listen","w24",{"Show":true,"Hide":true}],["create","w99","rwt.widgets.Menu",{"style":["POP_UP"]}],["listen","w99",{"Show":true,"Hide":true}],["create","w145","rwt.widgets.Menu",{"style":["POP_UP"]}],["listen","w145",{"Show":true,"Hide":true}],["create","w25","rwt.widgets.Composite",{"parent":"w17","style":["NONE"],"bounds":[2,2,982,22],"children":["w26","w27"],"tabIndex":1,"clientArea":[0,0,0,0]}],["create","w26","rwt.widgets.Sash",{"parent":"w25","style":["VERTICAL"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["create","w27","rwt.widgets.Composite",{"parent":"w25","style":["NONE"],"bounds":[0,0,982,22],"children":["w28"],"tabIndex":-1,"clientArea":[0,0,982,22]}],["create","w28","rwt.widgets.CoolBar",{"parent":"w27","style":["FLAT","HORIZONTAL"],"bounds":[0,0,982,22],"children":["w29","w50"],"tabIndex":-1}],["create","w47","rwt.widgets.CoolItem",{"parent":"w28","style":["DROP_DOWN"],"bounds":[0,0,982,22],"control":"w29"}],["create","w29","rwt.widgets.ToolBar",{"parent":"w28","style":["FLAT","HORIZONTAL"],"bounds":[10,0,972,22],"children":[],"tabIndex":4}],["listen","w29",{"MenuDetect":true}],["create","w30","rwt.widgets.ToolItem",{"parent":"w29","style":["PUSH"],"index":0,"bounds":[0,0,24,22],"toolTip":"데이터베이스 추가","image":["rwt-resources/generated/f28fe3ed.png",16,16]}],["listen","w30",{"Selection":true}],["create","w31","rwt.widgets.ToolItem",{"parent":"w29","style":["SEPARATOR"],"index":1,"bounds":[24,0,4,22]}],["create","w32","rwt.widgets.ToolItem",{"parent":"w29","style":["PUSH"],"index":2,"bounds":[28,0,24,22],"enabled":false,"toolTip":"Save (S)","image":["rwt-resources/generated/57340c0d.gif",16,16]}],["listen","w32",{"Selection":true}],["create","w33","rwt.widgets.ToolItem",{"parent":"w29","style":["SEPARATOR"],"index":3,"bounds":[52,0,4,22]}],["create","w34","rwt.widgets.ToolItem",{"parent":"w29","style":["PUSH"],"index":4,"bounds":[56,0,24,22],"enabled":false,"toolTip":"Edit SQL","image":["rwt-resources/generated/3a823856.png",16,16]}],["listen","w34",{"Selection":true}],["create","w35","rwt.widgets.ToolItem",{"parent":"w29","style":["PUSH"],"index":5,"bounds":[80,0,24,22],"enabled":false,"toolTip":"ERD 보기","image":["rwt-resources/generated/951ce9b4.png",16,16]}],["listen","w35",{"Selection":true}],["create","w36","rwt.widgets.ToolItem",{"parent":"w29","style":["SEPARATOR"],"index":6,"bounds":[104,0,4,22]}],["create","w37","rwt.widgets.ToolItem",{"parent":"w29","style":["PUSH"],"index":7,"bounds":[108,0,24,22],"enabled":false,"toolTip":"리소스 삭제","image":["rwt-resources/generated/c191bc8b.png",16,16]}],["listen","w37",{"Selection":true}],["create","w38","rwt.widgets.ToolItem",{"parent":"w29","style":["SEPARATOR"],"index":8,"bounds":[132,0,4,22]}],["create","w39","rwt.widgets.ToolItem",{"parent":"w29","style":["PUSH"],"index":9,"bounds":[136,0,24,22],"toolTip":"User Manager","image":["rwt-resources/generated/fbfa5d26.png",16,16]}],["listen","w39",{"Selection":true}],["create","w40","rwt.widgets.ToolItem",{"parent":"w29","style":["SEPARATOR"],"index":10,"bounds":[160,0,4,22]}],["create","w41","rwt.widgets.ToolItem",{"parent":"w29","style":["PUSH"],"index":11,"bounds":[164,0,24,22],"toolTip":"Preferences","image":["rwt-resources/generated/36b6588b.png",16,16]}],["listen","w41",{"Selection":true}],["create","w42","rwt.widgets.ToolItem",{"parent":"w29","style":["SEPARATOR"],"index":12,"bounds":[188,0,4,22]}],["create","w43","rwt.widgets.ToolItem",{"parent":"w29","style":["PUSH"],"index":13,"bounds":[192,0,24,22],"toolTip":"버그, 기능 추가요청","image":["rwt-resources/generated/81944b16.png",16,16]}],["listen","w43",{"Selection":true}],["create","w44","rwt.widgets.ToolItem",{"parent":"w29","style":["PUSH"],"index":14,"bounds":[216,0,23,22],"toolTip":"About Tadpole for DB Hub","image":["rwt-resources/generated/8bed9527.png",15,15]}],["listen","w44",{"Selection":true}],["create","w45","rwt.widgets.ToolItem",{"parent":"w29","style":["SEPARATOR"],"index":15,"bounds":[239,0,4,22]}],["create","w46","rwt.widgets.ToolItem",{"parent":"w29","style":["PUSH"],"index":16,"bounds":[243,0,24,22],"toolTip":"Log out","image":["rwt-resources/generated/1c36eae8.png",16,16]}],["listen","w46",{"Selection":true}],["create","w50","rwt.widgets.ToolBar",{"parent":"w28","style":["FLAT","HORIZONTAL"],"bounds":[-17,0,25,22],"children":[],"tabIndex":-1,"visibility":false,"background":[255,255,255,255]}],["create","w51","rwt.widgets.ToolItem",{"parent":"w50","style":["PUSH"],"index":0,"bounds":[0,0,16,22],"image":["rwt-resources/generated/4e7aad48.gif",8,16]}],["listen","w51",{"Selection":true}],["create","w52","rwt.widgets.Composite",{"parent":"w17","style":["NONE"],"bounds":[0,0,0,0],"children":["w53","w54","w56"],"tabIndex":5,"visibility":false,"clientArea":[0,0,0,0]}],["create","w53","rwt.widgets.Label",{"parent":"w52","style":["NONE"],"appearance":"clabel","bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"foreground":[74,74,74,255],"text":""}],["create","w54","rwt.widgets.ToolBar",{"parent":"w52","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":7,"visibility":false}],["create","w55","rwt.widgets.ToolItem",{"parent":"w54","style":["PUSH"],"index":0,"bounds":[0,0,24,22],"toolTip":"Cancel Current Operation","visible":false,"image":["rwt-resources/generated/cb52ad0b.gif",16,16]}],["listen","w55",{"Selection":true}],["create","w56","rwt.widgets.Composite",{"parent":"w52","style":["NONE"],"bounds":[0,0,0,0],"children":["w57"],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w57","rwt.widgets.Composite",{"parent":"w56","style":["NONE"],"bounds":[0,0,0,0],"children":["w58","w59"],"tabIndex":9,"visibility":false,"clientArea":[0,0,0,0]}],["create","w58","rwt.widgets.ProgressBar",{"parent":"w57","style":["HORIZONTAL"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["create","w59","rwt.widgets.ProgressBar",{"parent":"w57","style":["HORIZONTAL","INDETERMINATE"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["create","w60","rwt.widgets.Composite",{"parent":"w17","style":["NONE"],"bounds":[0,0,32,22],"children":["w61"],"tabIndex":10,"toolTip":"Show View as a fast view","visibility":false}],["listen","w60",{"MenuDetect":true}],["set","w60",{"clientArea":[0,0,32,22]}],["create","w61","rwt.widgets.ToolBar",{"parent":"w60","style":["FLAT","HORIZONTAL"],"bounds":[0,0,32,22],"children":[],"tabIndex":11}],["listen","w61",{"MenuDetect":true}],["create","w65","rwt.widgets.Composite",{"parent":"w17","style":["NONE"],"bounds":[4,26,976,942],"children":["w66"],"tabIndex":-1,"clientArea":[0,0,976,942]}],["create","w66","rwt.widgets.Composite",{"parent":"w65","style":["NONE"],"bounds":[0,0,976,942],"children":["w118","w117","w93","w92","w67","w80","w105","w146","w147"],"tabIndex":-1,"clientArea":[0,0,976,942]}],["create","w118","rwt.widgets.ToolBar",{"parent":"w66","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false}],["listen","w118",{"Activate":true,"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["create","w117","rwt.widgets.Composite",{"parent":"w66","style":["NONE"],"bounds":[3,311,286,628],"children":["w119"],"tabIndex":-1}],["listen","w117",{"Activate":true}],["set","w117",{"clientArea":[0,0,286,628]}],["create","w119","rwt.widgets.Composite",{"parent":"w117","style":["NONE"],"bounds":[0,0,286,628],"children":["w120","w123"],"tabIndex":-1,"clientArea":[0,0,286,628]}],["create","w120","rwt.widgets.Composite",{"parent":"w119","style":["NONE"],"bounds":[1,0,284,28],"children":["w121","w122"],"tabIndex":-1,"clientArea":[0,0,284,28]}],["create","w121","rwt.widgets.Label",{"parent":"w120","style":["NONE"],"bounds":[2,5,15,17],"tabIndex":-1,"text":"필터"}],["create","w122","rwt.widgets.Text",{"parent":"w120","style":["LEFT","SINGLE","SEARCH","ICON_CANCEL","ICON_SEARCH","BORDER"],"bounds":[19,2,263,24],"tabIndex":-1}],["listen","w122",{"KeyDown":true}],["create","w123","rwt.widgets.Composite",{"parent":"w119","style":["NONE"],"bounds":[1,28,284,600],"children":["w124"],"tabIndex":-1,"clientArea":[0,0,284,600]}],["create","w124","rwt.widgets.CTabFolder",{"parent":"w123","style":["MULTI"],"toolTipTexts":["Minimize","Maximize","Restore","Show List","Close"],"bounds":[2,2,280,596],"children":["w125","w127"],"tabIndex":-1}],["listen","w124",{"FocusIn":true,"FocusOut":true}],["set","w124",{"tabHeight":18,"selection":"w126","selectionBackground":[220,223,228,255],"selectionBackgroundGradient":[[[133,135,140,255],[167,166,170,255],[167,166,170,255],[220,223,228,255]],[0,100,100,100],false]}],["listen","w124",{"Selection":true,"DefaultSelection":true}],["create","w126","rwt.widgets.CTabItem",{"parent":"w124","index":0,"style":["NONE"],"bounds":[0,0,53,19],"text":"Tables"}],["create","w125","rwt.widgets.Composite",{"parent":"w124","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w127","rwt.widgets.Composite",{"parent":"w124","style":["NONE"],"bounds":[2,22,276,572],"children":["w128"],"tabIndex":-1,"clientArea":[0,0,276,572]}],["create","w128","rwt.widgets.Composite",{"parent":"w127","style":["NONE"],"bounds":[2,2,272,568],"children":["w129","w135","w148"],"tabIndex":-1,"clientArea":[0,0,272,568]}],["create","w129","rwt.widgets.Grid",{"parent":"w128","style":["SINGLE","FULL_SELECTION","BORDER"],"appearance":"table","indentionWidth":0,"treeColumn":-1,"markupEnabled":false}],["create","w130","rwt.widgets.ScrollBar",{"parent":"w129","style":["HORIZONTAL"]}],["create","w131","rwt.widgets.ScrollBar",{"parent":"w129","style":["VERTICAL"]}],["set","w129",{"bounds":[0,0,272,282],"children":[],"tabIndex":-1,"menu":"w145"}],["listen","w129",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w129",{"itemHeight":23,"itemMetrics":[[0,0,125,0,0,0,0],[1,125,145,0,0,0,0]],"columnCount":2,"headerHeight":18,"headerVisible":true,"linesVisible":true}],["listen","w129",{"Selection":true,"DefaultSelection":true}],["set","w129",{"enableCellToolTip":true}],["listen","w130",{"Selection":true}],["listen","w131",{"Selection":true}],["create","w134","rwt.widgets.DragSource",{"control":"w129","style":["DROP_COPY","DROP_MOVE"],"transfer":["3556653"]}],["listen","w134",{"DragStart":true,"DragEnd":true}],["create","w132","rwt.widgets.GridColumn",{"parent":"w129","text":"Name","width":125}],["listen","w132",{"Selection":true}],["create","w133","rwt.widgets.GridColumn",{"parent":"w129","text":"Comment","index":1,"left":125,"width":145}],["listen","w133",{"Selection":true}],["create","w135","rwt.widgets.Grid",{"parent":"w128","style":["SINGLE","FULL_SELECTION","VIRTUAL","BORDER"],"appearance":"table","indentionWidth":0,"treeColumn":-1,"markupEnabled":false}],["create","w136","rwt.widgets.ScrollBar",{"parent":"w135","style":["HORIZONTAL"]}],["create","w137","rwt.widgets.ScrollBar",{"parent":"w135","style":["VERTICAL"]}],["set","w135",{"bounds":[0,285,272,283],"children":[],"tabIndex":-1}],["listen","w135",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w135",{"itemHeight":23,"itemMetrics":[[0,0,120,0,0,0,0],[1,120,90,0,0,0,0],[2,210,50,0,0,0,0],[3,260,100,0,0,0,0],[4,360,50,0,0,0,0],[5,410,50,0,0,0,0],[6,460,50,0,0,0,0]],"columnCount":7,"headerHeight":18,"headerVisible":true,"linesVisible":true}],["listen","w135",{"Selection":true,"SetData":true,"DefaultSelection":true}],["set","w136",{"visibility":true}],["listen","w136",{"Selection":true}],["listen","w137",{"Selection":true}],["create","w138","rwt.widgets.GridColumn",{"parent":"w135","text":"Field","width":120}],["listen","w138",{"Selection":true}],["create","w139","rwt.widgets.GridColumn",{"parent":"w135","text":"Type","index":1,"left":120,"width":90}],["listen","w139",{"Selection":true}],["create","w140","rwt.widgets.GridColumn",{"parent":"w135","text":"Key","index":2,"left":210,"width":50}],["listen","w140",{"Selection":true}],["create","w141","rwt.widgets.GridColumn",{"parent":"w135","text":"Comment","index":3,"left":260,"width":100}],["listen","w141",{"Selection":true}],["create","w142","rwt.widgets.GridColumn",{"parent":"w135","text":"Null","index":4,"left":360,"width":50}],["listen","w142",{"Selection":true}],["create","w143","rwt.widgets.GridColumn",{"parent":"w135","text":"Default","index":5,"left":410,"width":50}],["listen","w143",{"Selection":true}],["create","w144","rwt.widgets.GridColumn",{"parent":"w135","text":"Extra","index":6,"left":460,"width":50}],["listen","w144",{"Selection":true}],["create","w148","rwt.widgets.Sash",{"parent":"w128","style":["HORIZONTAL"],"bounds":[0,282,272,3],"tabIndex":-1}],["create","w93","rwt.widgets.ToolBar",{"parent":"w66","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false}],["listen","w93",{"Activate":true,"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["create","w92","rwt.widgets.Composite",{"parent":"w66","style":["NONE"],"bounds":[3,26,286,253],"children":["w94"],"tabIndex":-1}],["listen","w92",{"Activate":true}],["set","w92",{"clientArea":[0,0,286,253]}],["create","w94","rwt.widgets.Composite",{"parent":"w92","style":["NONE"],"bounds":[0,0,286,253],"children":["w95"],"tabIndex":-1,"clientArea":[0,0,286,253]}],["create","w95","rwt.widgets.Composite",{"parent":"w94","style":["NONE"],"bounds":[0,0,286,253],"children":["w96"],"tabIndex":-1,"clientArea":[0,0,286,253]}],["create","w96","rwt.widgets.Grid",{"parent":"w95","style":["SINGLE","VIRTUAL","BORDER"],"appearance":"tree","selectionPadding":[3,5],"indentionWidth":16,"markupEnabled":true}],["create","w97","rwt.widgets.ScrollBar",{"parent":"w96","style":["HORIZONTAL"]}],["create","w98","rwt.widgets.ScrollBar",{"parent":"w96","style":["VERTICAL"]}],["set","w96",{"bounds":[5,5,276,243],"children":[],"tabIndex":-1,"menu":"w99"}],["listen","w96",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w96",{"itemCount":1,"itemHeight":22,"itemMetrics":[[0,0,1648,0,16,22,1618]]}],["listen","w96",{"Selection":true,"SetData":true,"DefaultSelection":true,"Expand":true,"Collapse":true}],["set","w97",{"visibility":true}],["listen","w97",{"Selection":true}],["listen","w98",{"Selection":true}],["create","w100","rwt.widgets.GridItem",{"parent":"w96","index":0,"itemCount":3,"texts":["Other Group"],"images":[["rwt-resources/generated/c518f8f5.png",16,16]],"expanded":true}],["create","w102","rwt.widgets.GridItem",{"parent":"w100","index":0,"texts":["[D] Sample MariaDB 5.5 (tester@tester)"],"images":[["rwt-resources/generated/9769815d.png",22,16]]}],["create","w103","rwt.widgets.GridItem",{"parent":"w100","index":1,"texts":["[D] Sample SQLite 3.7.2 (@/Users/hangum/Documents/workspace-tadpole-1.0.0/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/configuration/tadpole/db/tadpole-system.db)"],"images":[["rwt-resources/generated/7c301a5b.png",16,16]]}],["create","w104","rwt.widgets.GridItem",{"parent":"w100","index":2,"texts":["[D] Sample MongoDB 2.0.2 (@test)"],"images":[["rwt-resources/generated/28906458.png",16,16]]}],["create","w67","rwt.widgets.Composite",{"parent":"w66","style":["NONE"],"bounds":[295,0,681,942],"children":["w150","w68"],"tabIndex":-1,"clientArea":[0,0,681,942]}],["create","w79","rwt.widgets.DropTarget",{"control":"w67","style":["DROP_COPY","DROP_LINK"]}],["create","w150","rwt.widgets.Composite",{"parent":"w67","style":["NONE"],"bounds":[3,26,675,913],"children":["w151"],"tabIndex":-1}],["listen","w150",{"Activate":true}],["set","w150",{"clientArea":[0,0,675,913]}],["create","w151","rwt.widgets.Composite",{"parent":"w150","style":["NONE"],"bounds":[0,0,675,913],"children":["w152","w155","w157"],"tabIndex":-1,"clientArea":[0,0,675,913]}],["create","w152","rwt.widgets.Composite",{"parent":"w151","style":["NONE"],"bounds":[1,1,673,34],"children":["w153","w154"],"tabIndex":-1,"clientArea":[0,0,673,34]}],["create","w153","rwt.widgets.Label",{"parent":"w152","style":["NONE"],"bounds":[5,8,37,17],"tabIndex":-1,"text":"URL "}],["create","w154","rwt.widgets.Text",{"parent":"w152","style":["LEFT","SINGLE","BORDER"],"bounds":[47,5,621,24],"tabIndex":27}],["listen","w154",{"KeyDown":true}],["set","w154",{"text":"https://sites.google.com/site/tadpolefordb/home"}],["create","w155","rwt.widgets.Composite",{"parent":"w151","style":["BORDER"],"bounds":[1,36,673,740],"children":["w156"],"tabIndex":-1,"clientArea":[0,0,671,738]}],["create","w156","rwt.widgets.Browser",{"parent":"w155","style":["NONE"],"bounds":[5,5,661,728],"children":[],"tabIndex":29,"url":"https://sites.google.com/site/tadpolefordb/home"}],["create","w157","rwt.widgets.Group",{"parent":"w151","style":["BORDER"],"bounds":[1,777,673,135],"children":["w158","w159","w160","w161","w162","w163"],"tabIndex":-1,"text":"기부자"}],["create","w158","rwt.widgets.Label",{"parent":"w157","style":["NONE"],"appearance":"clabel","markupEnabled":true,"bounds":[8,22,179,75],"children":[],"tabIndex":-1,"image":["rwt-resources/generated/d900d492.png",173,69]}],["create","w159","rwt.widgets.Label",{"parent":"w157","style":["NONE"],"appearance":"clabel","bounds":[192,22,185,75],"children":[],"tabIndex":-1,"image":["rwt-resources/generated/d09b6431.png",179,69]}],["create","w160","rwt.widgets.Label",{"parent":"w157","style":["NONE"],"appearance":"clabel","bounds":[382,22,179,75],"children":[],"tabIndex":-1,"image":["rwt-resources/generated/ab0433e.png",173,69]}],["create","w161","rwt.widgets.Label",{"parent":"w157","style":["NONE"],"appearance":"clabel","markupEnabled":true,"bounds":[8,102,163,21],"children":[],"tabIndex":-1,"text":"http://www.cubrid.org"}],["create","w162","rwt.widgets.Label",{"parent":"w157","style":["NONE"],"appearance":"clabel","markupEnabled":true,"bounds":[192,102,88,21],"children":[],"tabIndex":-1,"text":"www.osci.kr"}],["create","w163","rwt.widgets.Label",{"parent":"w157","style":["NONE"],"appearance":"clabel","markupEnabled":true,"bounds":[382,102,171,21],"children":[],"tabIndex":-1,"text":"http://www.xenonix.com"}],["create","w68","rwt.widgets.CTabFolder",{"parent":"w67","style":["MULTI","BORDER"],"toolTipTexts":["Minimize","Maximize","Restore","Show List","Close"],"bounds":[0,0,681,942],"children":["w75","w77","w69","w70"],"tabIndex":15,"font":[["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false]}],["listen","w68",{"Activate":true,"FocusIn":true,"FocusOut":true,"MenuDetect":true}],["set","w68",{"tabHeight":22,"minimizeBounds":[642,2,18,18],"minimizeVisible":true,"maximizeBounds":[660,2,18,18],"maximizeVisible":true,"selection":"w149","selectionBackground":[76,166,210,255],"selectionForeground":[0,0,0,255],"selectionBackgroundGradient":[[[210,232,243,255],[76,166,210,255]],[0,75],true],"borderVisible":true}],["listen","w68",{"Selection":true,"DefaultSelection":true,"Folder":true}],["create","w149","rwt.widgets.CTabItem",{"parent":"w68","index":0,"style":["CLOSE"],"toolTip":"홈페이지","bounds":[0,0,80,23],"text":"홈페이지","image":["rwt-resources/generated/42eb7c13.png",16,16],"showClose":true}],["create","w75","rwt.widgets.ToolBar",{"parent":"w68","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":16,"visibility":false}],["create","w76","rwt.widgets.ToolItem",{"parent":"w75","style":["PUSH"],"index":0,"bounds":[0,0,19,22],"toolTip":"Menu","visible":false,"image":["rwt-resources/generated/90970f9f.gif",11,16]}],["listen","w76",{"Selection":true}],["create","w77","rwt.widgets.Label",{"parent":"w68","style":["NONE"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["listen","w77",{"Activate":true,"MenuDetect":true}],["create","w69","rwt.widgets.Composite",{"parent":"w68","style":["NONE"],"bounds":[80,1,561,22],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,561,22]}],["create","w70","rwt.widgets.Composite",{"parent":"w68","style":["NONE"],"bounds":[3,26,675,913],"children":["w71","w72","w73","w74","w78"],"tabIndex":18}],["listen","w70",{"Activate":true,"MenuDetect":true}],["set","w70",{"clientArea":[0,0,675,913]}],["create","w71","rwt.widgets.Composite",{"parent":"w70","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w72","rwt.widgets.Composite",{"parent":"w70","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w73","rwt.widgets.Composite",{"parent":"w70","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w74","rwt.widgets.Composite",{"parent":"w70","style":["NONE"],"bounds":[-200,-200,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w78","rwt.widgets.Composite",{"parent":"w70","style":["NONE"],"bounds":[0,0,675,913],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,675,913]}],["create","w80","rwt.widgets.CTabFolder",{"parent":"w66","style":["MULTI","BORDER"],"toolTipTexts":["Minimize","Maximize","Restore","Show List","Close"],"bounds":[0,0,292,282],"children":["w87","w89","w81","w82"],"tabIndex":-1,"font":[["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false]}],["listen","w80",{"Activate":true,"FocusIn":true,"FocusOut":true,"MenuDetect":true}],["set","w80",{"tabHeight":22,"minimizeBounds":[253,2,18,18],"minimizeVisible":true,"maximizeBounds":[271,2,18,18],"maximizeVisible":true,"unselectedCloseVisible":false,"selection":"w91","selectionBackground":[255,255,255,255],"selectionForeground":[74,74,74,255],"selectionBackgroundGradient":[[[255,255,255,255],[255,255,255,255]],[0,100],true],"borderVisible":true}],["listen","w80",{"Selection":true,"DefaultSelection":true,"Folder":true}],["create","w91","rwt.widgets.CTabItem",{"parent":"w80","index":0,"style":["NONE"],"bounds":[0,0,95,23],"text":"데이터베이스 목록","image":["rwt-resources/generated/f6e6bd97.png",16,16]}],["create","w87","rwt.widgets.ToolBar",{"parent":"w80","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false}],["create","w88","rwt.widgets.ToolItem",{"parent":"w87","style":["PUSH"],"index":0,"bounds":[0,0,19,22],"toolTip":"Menu","visible":false,"image":["rwt-resources/generated/90970f9f.gif",11,16]}],["listen","w88",{"Selection":true}],["create","w89","rwt.widgets.Label",{"parent":"w80","style":["NONE"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["listen","w89",{"Activate":true,"MenuDetect":true}],["create","w81","rwt.widgets.Composite",{"parent":"w80","style":["NONE"],"bounds":[95,1,157,22],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,157,22]}],["create","w82","rwt.widgets.Composite",{"parent":"w80","style":["NONE"],"bounds":[3,26,286,253],"children":["w83","w84","w85","w86","w90"],"tabIndex":-1}],["listen","w82",{"Activate":true,"MenuDetect":true}],["set","w82",{"clientArea":[0,0,286,253]}],["create","w83","rwt.widgets.Composite",{"parent":"w82","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w84","rwt.widgets.Composite",{"parent":"w82","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w85","rwt.widgets.Composite",{"parent":"w82","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w86","rwt.widgets.Composite",{"parent":"w82","style":["NONE"],"bounds":[-200,-200,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w90","rwt.widgets.Composite",{"parent":"w82","style":["NONE"],"bounds":[0,0,286,253],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,286,253]}],["create","w105","rwt.widgets.CTabFolder",{"parent":"w66","style":["MULTI","BORDER"],"toolTipTexts":["Minimize","Maximize","Restore","Show List","Close"],"bounds":[0,285,292,657],"children":["w112","w114","w106","w107"],"tabIndex":-1,"font":[["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false]}],["listen","w105",{"Activate":true,"FocusIn":true,"FocusOut":true,"MenuDetect":true}],["set","w105",{"tabHeight":22,"minimizeBounds":[253,2,18,18],"minimizeVisible":true,"maximizeBounds":[271,2,18,18],"maximizeVisible":true,"unselectedCloseVisible":false,"selection":"w116","selectionBackground":[255,255,255,255],"selectionForeground":[74,74,74,255],"selectionBackgroundGradient":[[[255,255,255,255],[255,255,255,255]],[0,100],true],"borderVisible":true}],["listen","w105",{"Selection":true,"DefaultSelection":true,"Folder":true}],["create","w116","rwt.widgets.CTabItem",{"parent":"w105","index":0,"style":["NONE"],"bounds":[0,0,88,23],"text":"오브젝트 탐색기","image":["rwt-resources/generated/54822c43.png",16,16]}],["create","w112","rwt.widgets.ToolBar",{"parent":"w105","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false}],["create","w113","rwt.widgets.ToolItem",{"parent":"w112","style":["PUSH"],"index":0,"bounds":[0,0,19,22],"toolTip":"Menu","visible":false,"image":["rwt-resources/generated/90970f9f.gif",11,16]}],["listen","w113",{"Selection":true}],["create","w114","rwt.widgets.Label",{"parent":"w105","style":["NONE"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["listen","w114",{"Activate":true,"MenuDetect":true}],["create","w106","rwt.widgets.Composite",{"parent":"w105","style":["NONE"],"bounds":[88,1,164,22],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,164,22]}],["create","w107","rwt.widgets.Composite",{"parent":"w105","style":["NONE"],"bounds":[3,26,286,628],"children":["w108","w109","w110","w111","w115"],"tabIndex":-1}],["listen","w107",{"Activate":true,"MenuDetect":true}],["set","w107",{"clientArea":[0,0,286,628]}],["create","w108","rwt.widgets.Composite",{"parent":"w107","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w109","rwt.widgets.Composite",{"parent":"w107","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w110","rwt.widgets.Composite",{"parent":"w107","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w111","rwt.widgets.Composite",{"parent":"w107","style":["NONE"],"bounds":[-200,-200,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w115","rwt.widgets.Composite",{"parent":"w107","style":["NONE"],"bounds":[0,0,286,628],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,286,628]}],["create","w146","rwt.widgets.Sash",{"parent":"w66","style":["VERTICAL","SMOOTH"],"bounds":[292,0,3,942],"tabIndex":-1}],["create","w147","rwt.widgets.Sash",{"parent":"w66","style":["HORIZONTAL","SMOOTH"],"bounds":[0,282,292,3],"tabIndex":-1}],["set","w1",{"focusControl":"w25"}],["listen","w1",{"Resize":true}],["set","rwt.client.ServerPush",{"active":true}],["set","w1",{"activeKeys":["ALT+#39","CTRL+#45","CTRL+SHIFT+#106","ALT+#34","SHIFT+#45","CTRL+#69","CTRL+#32","ALT+#37","CTRL+SHIFT+#117","CTRL+#117","CTRL+#77","#123","CTRL+#121","ALT+-","CTRL+,","CTRL+.","CTRL+#78","CTRL+#87","CTRL+#119","CTRL+SHIFT+#119","CTRL+SHIFT+#111","ALT+#118","ALT+SHIFT+#118","CTRL+SHIFT+#118","CTRL+#118","CTRL+#89","CTRL+#90","ALT+#13","CTRL+#80","#113","CTRL+SHIFT+#83","CTRL+#83","CTRL+SHIFT+#115","CTRL+SHIFT+#87","CTRL+#115","SHIFT+#46","CTRL+#70","CTRL+SHIFT+#69","CTRL+SHIFT+#32","ALT+#33"],"cancelKeys":["ALT+#39","CTRL+#45","CTRL+SHIFT+#106","ALT+#34","SHIFT+#45","CTRL+#69","CTRL+#32","ALT+#37","CTRL+SHIFT+#117","CTRL+#117","CTRL+#77","#123","CTRL+#121","ALT+-","CTRL+,","CTRL+.","CTRL+#78","CTRL+#87","CTRL+#119","CTRL+SHIFT+#119","CTRL+SHIFT+#111","ALT+#118","ALT+SHIFT+#118","CTRL+SHIFT+#118","CTRL+#118","CTRL+#89","CTRL+#90","ALT+#13","CTRL+#80","#113","CTRL+SHIFT+#83","CTRL+#83","CTRL+SHIFT+#115","CTRL+SHIFT+#87","CTRL+#115","SHIFT+#46","CTRL+#70","CTRL+SHIFT+#69","CTRL+SHIFT+#32","ALT+#33"]}],["call","rwt.client.TextSizeMeasurement","measureItems",{"items":[["t-904310924","필터",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t1439015495","기부자",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t1302237179","www.osci.kr",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,true],["t261035298","[D] Sample SQLite 3.7.2 (@/Users/hangum/Documents/workspace-tadpole-1.0.0/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/configuration/tadpole/db/tadpole-system.db)",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t-1640854697","데이터베이스 목록",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t-2035080233","URL ",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t-1892110009","https://sites.google.com/site/tadpolefordb/home",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t-1472933364","[D] Sample MariaDB 5.5 (tester@tester)",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t1761469227","오",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t-763994721","http://www.cubrid.org",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,true],["t1756867959","데",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t-1328706181","http://www.xenonix.com",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,true],["t-13588908","[D] Sample MongoDB 2.0.2 (@test)",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t-767870090","Other Group",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t-327311903","오브젝트 탐색기",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t1712723464","",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t291840547","홈페이지",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t1715414264","Wg",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false],["t881963852","Tables",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false]]}]]}
fileName: http://127.0.0.1:10081/rwt-resources/rap-client.js
lineNumber: 69343
columnNumber: 4
Stack: rwt.remote.MessageProcessor._processError@http://127.0.0.1:10081/rwt-resources/rap-client.js:69343
rwt.remote.MessageProcessor.processOperationArray@http://127.0.0.1:10081/rwt-resources/rap-client.js:69199
rwt.remote.MessageProcessor.processMessage@http://127.0.0.1:10081/rwt-resources/rap-client.js:69161
.members._handleSuccess@http://127.0.0.1:10081/rwt-resources/rap-client.js:69807
@http://127.0.0.1:10081/rwt-resources/rap-client.js:36154
rwt.remote.Request.prototype._onReadyStateChange@http://127.0.0.1:10081/rwt-resources/rap-client.js:36205
.statics.bind/wrap@http://127.0.0.1:10081/rwt-resources/rap-client.js:5725
Debug: on
Request: {"head":{"requestCounter":2},"operations":[["set","w2",{"activeControl":"w13"}],["notify","w13","Selection",{"shiftKey":false,"ctrlKey":false,"altKey":false}],["set","w1",{"cursorLocation":[461,529],"focusControl":"w13"}]]}
Re: [ANN] RAP 2.1 RC3 is available [message #1062521 is a reply to message #1062519] |
Sat, 08 June 2013 04:45   |
please open a bugzilla [1] and attach a snippet to reproduce the
problem. We will have a look on it asap.
[1] http://eclipse.org/rap/bugs/
Best,
Ivan
On 6/8/2013 11:12 AM, Cho Hyun Jong wrote:
> i have a problem.
> Client Error
> Details:
> root is null
> Properties: parent = w18
> style = CASCADE
> index = 0
> text = File
> mnemonicIndex = 0
> menu = w20
> Script:
> ["CASCADE"],"index":1,"text":"Window","mnemonicIndex":0,"menu":"w22"}], ["create","w23","rwt.widgets.MenuItem",{"parent":"w18","style":
> ["VERTICAL"],"bounds": [0,0,0,0],"tabIndex":-1,"visibility":false}],
> ["PUSH"],"index":7,"bounds": [108,0,24,22],"enabled":false,"toolTip":"
> Tadpole for DB
> Current
> View as a fast
> ["listen","w118",
> Sample MariaDB 5.5
> Sample SQLite 3.7.2
> ["w158","w159","w160","w161","w162","w163"],"tabIndex":-1,"text":" 기
> ["listen","w68",
> ["listen","w68",
> ["listen","w80",
> ["listen","w80",
> ["listen","w105",
> ["listen","w105",
> Sample SQLite 3.7.2
> Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false], ["t-
> lineNumber: 69343
> columnNumber: 4
> Stack:
> Debug: on
> Request:
Ivan Furnadjiev
Twitter: @EclipseRAP
Current Time: Fri Jul 18 22:12:45 EDT 2025
Powered by FUDForum. Page generated in 0.05933 seconds
