Home » Modeling » ATL » Change Source Element
Change Source Element [message #1062393] Fri, 07 June 2013 10:05 Go to next message
Is there a way to change an attribute in the source model using a rule or a helper or anything?
Re: Change Source Element [message #1062429 is a reply to message #1062393] Fri, 07 June 2013 12:13 Go to previous messageGo to next message
No, the principle of ATL is that you can only navigate your input model (which is not editable).
Elements creations and modifications are only possible on the output model.
Only the specific new refining mode is implementing an in-place transformation approach, but in that case the input and output models are actually the same.
Re: Change Source Element [message #1062476 is a reply to message #1062429] Fri, 07 June 2013 18:21 Go to previous message
OK.
Thank you.
Previous Topic:Launch ATL transformation programmatically
Next Topic:Higher order transformation
Current Time: Sun Jul 27 09:56:11 EDT 2025
Powered by FUDForum. Page generated in 0.03376 seconds
