Home » Modeling » ATL » Higher order transformation
Higher order transformation [message #1062391] Fri, 07 June 2013 10:00 Go to next message
I have several metamodels imported from XML schemas. I would like to use XML extractor to save models conforming to those metamodels to XML files.
But I do not want to define a transformation for each of the metamodels. The rules to transform to XML metamodel are actually all the same and are based on information in the metamodels.
Is it possible to create a single transformation that would do that. Something like:
create OUT : XML from METAIN : ECORE, IN : METAIN;
Michal
Re: Higher order transformation [message #1062428 is a reply to message #1062391] Fri, 07 June 2013 12:08 Go to previous messageGo to next message
If your metamodel (in Ecore) has been directly created from an XML schema, then EMF itself is already able to import corresponding XML documents as models and to export back such models as XML documents.
You should take a look to the EMF documentation to get more info about this.
Re: Higher order transformation [message #1062547 is a reply to message #1062428] Sat, 08 June 2013 12:48 Go to previous messageGo to next message
Hugo Bruneliere wrote on Fri, 07 June 2013 12:08
The problem really is I could not find any way to automate loading/saving instance documents (eg. an ant task).
Re: Higher order transformation [message #1062676 is a reply to message #1062547] Mon, 10 June 2013 06:51 Go to previous message
You could do this via Java code to automate the full process/chain.
Previous Topic:Change Source Element
Next Topic:ArrayIndexOutOfBoundsException with ->at(1) although size is 2
Current Time: Fri Jul 25 22:19:11 EDT 2025
Powered by FUDForum. Page generated in 0.03764 seconds
