Home » Eclipse Projects » NatTable » Data Validation(Data validation when loading data from xls file)
Data Validation [message #1062362] Fri, 07 June 2013 08:18 Go to next message
I have a screen where i have added a file dialog to select a excel file and load the data into natTable.This works fine and able to load the data into nattable and also able to edit the cell.
The problem is, how do i validate the data when data is loaded first time.Is there any option to have a data source attached to the natTable which validates the data.
Re: Data Validation [message #1062379 is a reply to message #1062362] Fri, 07 June 2013 08:57 Go to previous message
Well that sounds more like an issue with your import rather than a NatTable question.
You would need to perform your validation and add labels to the cells that contain invalid data. This is more a concept of weak validation rather than typical edit validation in NatTable.
Have a look at this blog post to learn about weak validation: http://blog.vogella.com/2013/03/02/crossweak-validation-in-nattable-by-dirk-fauth/
Previous Topic:[SOLVED] Problem with ColumGroupHeaderLayer and SortHeaderLayer
Next Topic:exportMultipleNatTables()
Current Time: Thu Jul 24 20:47:18 EDT 2025
Powered by FUDForum. Page generated in 0.05286 seconds
