Generating custom made href values when saving a model [message #1062360] |
Fri, 07 June 2013 08:01  |
I have a question about how I can refer to my own cutom made proxy href pointers instead of the pre-generated hrefs by EMF. Hopefully I manage to explain the case below.
I have two models loaded into my own ResourceImpl class in my application. The two models are loaded locally from two different XML files locally on my computer.
Model1 has the name: Structure.xml
Model2 has the name: Semantic.xml
I try to edit model1 and refer to an element in model2. I save the model to a new file, and when I have a look at the href pointer in the new element I created it says: href="Semantic.xml#a13". This is fine, but I want to make my own custom made href value, meaning that I want to replace the href value with my own customized value.
My question is therefore: how can I generate my own customized href value and add it to the href attribute of a newly added or changed element? If someone could point me to the class/method where the href value is being generated when I save a model, that would help me alot!
Thanks in advance!
Magnus
Re: Generating custom made href values when saving a model [message #1062377 is a reply to message #1062360] |
Fri, 07 June 2013 08:49  |
Magnus,
Comments below.
On 07/06/2013 2:01 PM, Magnus Stuhr wrote:
It generates needs to be of the form <Resource-URI>#<Fragment-in-Resource>
XMLHelperImpl computes it but there are limitations on what you can
change it too, i.e., it must contain a # to be considered a cross
document reference.
What are you trying to accomplish exactly and why?
> Thanks in advance!
> Regards,
> Magnus
FUDForum. Page generated in 0.05859 seconds
