Home » Eclipse Projects » Eclipse 4 » Urgent Help needed regarding CSS mechanism in rcp application
Urgent Help needed regarding CSS mechanism in rcp application [message #1062353] Fri, 07 June 2013 07:04 Go to next message
Hi all,
I have done the following steps to create an rcp application
1. Created a rcp application (3.x)
2. created extension point "org.eclipse.e4.ui.css.swt.theme" and added two themes in it and set
the respective css files for each theme.
3. Added a ViewerPreferencePage, which given the option to change theme.
Now, when i change theme , it work's fine and applied on all the swt controls which i have
specified in css file,
Now i have defined my own selector in the css file like "MySelector" and then specified it's
properties
like this
.MySelector
background-color:rgb(250,250,200);
i have debugged the code, the main class handling this is the "ThemeEngine", which reads this, one
thing for sure is that engine successfully read the whole css file including my own custom
selector, now what i want's is to get this selector and it's properties and values from the css
engine programmatically
Any idea/help/hint/clue/suggestion will be appreciated.
SDK
Re: Urgent Help needed regarding CSS mechanism in rcp application [message #1062785 is a reply to message #1062353] Mon, 10 June 2013 13:30 Go to previous message
I am not sure, why you need this. The API only offers to retrieve the
Style for a widget. A hack possible would be to create a widget and
assign the selector as css class to it.
Cheers
Jonas
Am 07.06.2013 13:04, schrieb SD Khan:
> Hi all,
> then specified it's
> properties
> like this
> MySelector
> Regards,
> SDK
Previous Topic:[CSS] Changing the size of Radio Buttons and CheckButtons
Next Topic:@Optional resource not being injected
Current Time: Wed Jul 23 11:44:28 EDT 2025
Powered by FUDForum. Page generated in 0.03243 seconds
