Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and Tabris
RAP and Tabris [message #1060616] Mon, 27 May 2013 06:36 Go to next message
Hi all,
from this page
http://developer.eclipsesource.com/tabris/docs/architecture/
I see that Tabris is the mobile client for RAP Server.
Now I followed the Tabris tutorial here
http://eclipsesource.com/blogs/2013/05/14/how-to-bootstrap-a-tabris-application-with-maven-and-eclipse/
which should (if I'm not mistaken) end up with a RAP Server and a mobile client, that is Tabris.
Is there a Browser RAP Web client for the same deployed application, as depicted in the first link above?
Thank you
Vincenzo
[Updated on: Mon, 27 May 2013 06:38] by Moderator
Re: RAP and Tabris [message #1060729 is a reply to message #1060616] Tue, 28 May 2013 05:23 Go to previous messageGo to next message
Hi Vincenzo,
Yes you are right. Tabris provides mobile clients for RAP and additional API to fulfill mobile requirements. The tutorial you have linked describes an App that is build with a small framework called "Tabris UI" (http://eclipsesource.com/blogs/2013/02/19/inside-the-tabris-ui/). You can compare it to the Eclipse RCP but less powerful and tailor made for mobile devices. Thus there is currently no implementation of this framework for the web client.
The message box that pops up when accessing a Tabris UI app with the browser comes from TabrisUIEntryPoint. It is created within the createContent method. The TabrisUIEntryPoint is just convenience. You can provide your own EntryPoint that just creates the Tabris UI and handles the web client differently.
Hope this helps.
Cheers Holger
Re: RAP and Tabris [message #1062270 is a reply to message #1060729] Thu, 06 June 2013 17:25 Go to previous messageGo to next message
Hi Holger,
thank you for the explanation.
My question in the end is: given the message stated at page
http://eclipse.org/rap/
("Enabling modular business apps for desktop, browser and mobile")
how can I set up a minimal application which can be run both on the browser and mobile? Is there some tutorial or sample project to show this approach?
Thank you very much
Cheers
Vincenzo
Re: RAP and Tabris [message #1062322 is a reply to message #1062270] Fri, 07 June 2013 04:19 Go to previous message
Hi Vincenzo,
the examples you asked for are the Tabris demos (https://github.com/eclipsesource/tabris-demos) except for the UI demo which I already said is based on the Tabris UI.
It does not make any sense to bring a full feature RAP application to a mobile device. But small pieces from a full app are a good fit for mobile devices. So, to be able to reuse your code you need to encapsulate small parts of your UI which can run as a mobile App.
The Tabris UI is based on Pages. So, creating your encapsulated UI parts in a page would be a good start.
Unfortunately we do not have an example online for this because it's just a question how you structure your application.
Hope this helps.
Cheers Holger
Previous Topic:[2.1] add a project to multiuser workspace
Next Topic:Buttons not removed from Table
Current Time: Sat Jul 26 19:20:31 EDT 2025
Powered by FUDForum. Page generated in 0.04822 seconds
